MAN TGX 440 - Error ZBR 03500, ABS Semi-Trailer Issue & Yellow ABS Control Light
magii 32124 2
  • #1 17125941
    magii
    Rate: 48
    Hello, I was looking for information about this error in the forum but I found nothing interesting. I will add that during this time the information "ABS semi-trailer" popped up and the yellow ABS control without one glowed. After turning the ignition off and on again, it returned to normal. I have a new semi-trailer for two weeks and there was no such information on the old one
    Thank you in advance for your reply
  • #2 17126511
    dare23
    Level 19  
    Help: 32
    Rate: 242
    Hello, code 3500 in the ZBR controller tells us about the failure of the EBS system of the semi-trailer / trailer. Check the trailer braking system and rectify the fault.
  • #3 17126710
    magii
    Rate: 48
    Thanks, buddy, for such a quick response, in that case, when I am on the service review of the semi-trailer, I will mention this is finally under warranty, but on the other hand that such things in the new semi-trailer :(
