Focus 1.8 TDDI: Adding New IMMO Key with Launch X431, IDS VCM MINI Ford & ID60 Seed
spinacz 4506 5
  • #1 16378034
    spinacz
    Help: 1206
    Rate: 2658
    Colleagues, how to add a new key?
    The following situation is most likely a car bought with one key and possibly not from this car.
    It enters the ignition switch quite reluctantly and reluctantly turns it, the immo flashes the starter is blocked.
    This is the mother's key, but it may turn out not to be from him.
    Is there an option to add a mother? Possibly a new ID60 seed.
    If so, what do you need to do?
    I have a launch x431, and an IDS VCM MINI Ford
    MobilTruck
    Help: 139
    Rate: 966
    I do not know about this mini vcm, but a normal IDsem will be fine. If you have elma, download forscana (it's free) and register it (also legal and free) you can find everything on the website Forscan , and try if you don't have an idsa.
    You got the in / out code calculator at PW.
  • #3 16378062
    spinacz
    Help: 1206
    Rate: 2658
    I have elm and forscan but how to register? Program to register?
    MobilTruck
    Help: 139
    Rate: 966
    http://forscan.org/forum/extlic.php
    You need to register (no worries), and on this page you generate a file which you then point to the program.
    spinacz
    Help: 1206
    Rate: 2658
    Immo added forscan, thank you for your help.
    I close the topic.
    Moderated By T5:
    We appreciate that you provided a solution to the problem, your topic may be helpful to others. We award "He helped".
  • #6 16384957
    spinacz
    Help: 1206
    Rate: 2658
    For information, let me add that you can add immo with Forscan from Elm, even if the program can calculate the code itself, I used an external calculator. To add seeds, you need to add 2 pieces after deleting them immediately for the procedure to be successful. Pips can be added several times, for example from another car, they are not saved once.
    I close the topic.
