Key Coding for Audi A3 1.9 TDI 2007: Micronas and EEPROM Reading with Xprog
oktawian89 13857 17
How can I add a key to a 2007 Audi A3 1.9 TDI when all keys are lost and Abrites cannot read the cluster without a working key?
You need to read the cluster’s Micronas and EEPROM, then process those dumps to extract the PIN/CS and generate a new immo chip; the modified EEPROM is written back to the instrument cluster, and the key then works [#17180916][#17182535][#17256565] For this 2007 A3, OBD reading without a working key is not enough because the meter can go into safe mode, so a programmer and dump-based work are required [#17180916][#17182535] One proposed workflow was to pull PIN and CS, precode an ID48 transponder with 7-byte CS, then encode it with VCDS [#17182626] The thread’s final resolution was that reading Micronas and EEPROM, then using Abrites to create the immo chip and modify the EEPROM, solved the problem [#17256565]
  • #1 17178926
    oktawian89
    Help: 52
    Rate: 444
    Patient Audi A3 1.9 TDI 2007, lost all the keys, a new key on the base of the lock added.
    Abrites, he can't read the clocks without the key working.
    I understand that I have to read micronas and eeprom using e.g. xprog?
    Then work it, including coding the tablet and upload the modified eeprom to the clocks?
    best regards
  • #2 17179081
    szymitsu21
    Help: 343
    Rate: 1300
    best regards
    You just need a PIN. And you'll add a key.
  • #3 17179091
    oktawian89
    Help: 52
    Rate: 444
    There since 2003 there is a dealer key, abrites without immo function.
  • #4 17179146
    szymitsu21
    Help: 343
    Rate: 1300
    Original key? With ASO?
    Do you have an odis?
  • #5 17179169
    oktawian89
    Help: 52
    Rate: 444
    The plastic key is only cut, the stone must be prepared. Now the question is how to do this.
  • #6 17179343
    sk700
    Help: 173
    Rate: 420
    Carprog should be able to add a tablet to the file, but I don't know if it will read immo without key authorization, there was a trick to write FF immo to get authorization and then restore the batch after OBD and adding a stone, maybe it will work?
  • #7 17179354
    szymitsu21
    Help: 343
    Rate: 1300
    So I ask if you have ORI and the odisa would go online.
  • #8 17179382
    oktawian89
    Help: 52
    Rate: 444
    No write back, yellow carprog, and possibly someone who can read the counter in terms of memory and micronas.
    This trick probably does not fly on micronas vdo, here is 2007 and resetting the immo in the meter is from 2009, I think.
  • #9 17179397
    szymitsu21
    Help: 343
    Rate: 1300
    I don't know, I don't fly like that. And when I have a problem, I go to guests who make additional keys based on the color of the car :D
  • #10 17180830
    miler80
    Help: 272
    Rate: 1395
    There are devices that will make the key when all key is lost in this car. But it is not CarProg.
  • #11 17180857
    szymitsu21
    Help: 343
    Rate: 1300
    Online.
    Or an ASO that will get VIN ...
    Aaaa someone wrote that the services in the warehouse abroad have such a backup :D
  • #12 17180916
    oktawian89
    Help: 52
    Rate: 444
    Gentlemen, the topic says it all. I do not see anything like there - I lost the key or the cable from the Allegro for PLN 20 I will add immo to my Łałdi. And the answer about ASO is already a hit :D
    Specific to specific people. The counter after 8/2006 in A3 can not do without a working key after OBD. Only on the basis of dump plus flash micronas.
    So theoretically, the only option is to read it, process it in eg Abrites AVDI. And now the question is whether, based on what I get, I can do a key dealer, in the sense of whether there will be a pin (it should be without a favor) and SC bytes.
    In newer ones after 2009, you have to upload FF to the meter to unlock it. then restore the ori dump. It's 2007 here.
    best regards
  • #13 17181387
    szymitsu21
    Help: 343
    Rate: 1300
    Well hit that's true. Because you are going, you pay, I think 600/800 and you have a new ori key.
    And you will take out the counters, try to read something there. Probably something in the meantime will go into space and the whole operation will cost about 3 times the value of this key and take a month.
    There is a guest in your vicinity, who improves such topics, you will probably see each other :D
  • #14 17181400
    oktawian89
    Help: 52
    Rate: 444
    Those who do not risk do not lose.
    I would say a typical car, 3rd gen immo with dealer key, i.e. 7 bytes SC, must be entered in the CAN ID 48 TP25 transponder. Only after 2006 in A3, when reading the meter after the OBD without a working key, the meter is in safe mode without the possibility of removing immo data and config data. only the programmer.
    The whole myk is about removing the pin and SC.
    If you have nothing more to write about specifically dump and flash micronas, I don't see any reason to continue to post stuff.
    In the case of W for posterity, I will only write that when sending the meter to a specific company, they will make a tablet for PLN 80. And you do not have to contact the ASO and pay PLN 600/800.
    I see that this is the knowledge of a tayman with this meter reading :D If I find out something, I will complete the topic with what and how to read it and then how to add the key.
    Best regards.
    Anything more about?
    Added after 3 [hours] 27 [minutes]:
  • #15 17182535
    OskiA3
    Help: 5
    Rate: 37
    You can bite it with a dragon and a jtag, pull out pin, immoid, cs, mac etc. FFowanie immo will not do anything, it does not work in A3.
  • #16 17182626
    oktawian89
    Help: 52
    Rate: 444
    I just need to pull pin CS, precode ID48 7 bytes CS with carprog and encode with vcds
  • #17 17184080
    OskiA3
    Help: 5
    Rate: 37
    I didn't have Carprog in my hands, so I won't say anything. If it is able to pull out the pin and cs and recode the pit, your problem is solved. Pre-coded, you even add vcdsem.
  • #18 17256565
    oktawian89
    Help: 52
    Rate: 444
    The read micronas and eeprom, on the basis of this abrites made an immo chip and modified the eeprom, which must be uploaded back to the meter.
    Everything works as it should be.
The discussion revolves around key coding for a 2007 Audi A3 1.9 TDI after losing all keys. The main approach involves reading the Micronas and EEPROM using tools like Xprog or Carprog to extract the PIN and other necessary data for key programming. Users mention that without a working key, accessing the immo data through OBD is not possible, and suggest alternative methods such as sending the meter to a specialized service. The conversation highlights the importance of having the correct tools and knowledge to handle the immo system, particularly for models post-2006, where specific procedures must be followed to unlock and program new keys.
TL;DR: For a 2007 Audi A3, budget ~PLN 80 for mail‑in chip prep; "7 bytes SC must be entered in the CAN ID 48 TP25 transponder." Read Micronas+EEPROM, compute CS/PIN, precode ID48, write back. [Elektroda, oktawian89, post #17181400]
Why it matters: This helps locksmiths and Audi owners solve all‑keys‑lost on VDO Micronas clusters without unnecessary dealer spend.
Can I add a key via OBD on a 2007 Audi A3 without a working key?
No. On A3 units after 08/2006, the cluster locks immo data over OBD without a working key. You must bench‑read the VDO Micronas MCU and EEPROM, then compute PIN and 7‑byte CS from the dump. Proceed with key precoding and adaptation. [Elektroda, oktawian89, post #17180916]
What data must I extract to pre‑code the transponder?
Extract the 7‑byte CS (also called SC) and the PIN from the cluster dump. Then pre‑code a CAN ID48 TP25 transponder with the CS. As one expert notes, "7 bytes SC must be entered in the CAN ID 48 TP25 transponder." [Elektroda, oktawian89, post #17181400]
Which transponder chip do I need for this A3?
Use an ID48 TP25 transponder. Pre‑code it with the 7‑byte CS from the cluster before attempting adaptation. Without correct precoding, immobilizer matching will fail on this dealer‑key platform. [Elektroda, oktawian89, post #17181400]
Will “FF‑ing” the immobilizer area unlock the A3 Micronas cluster?
No. On A3 Micronas clusters, FF‑ing the immo region does not provide authorization. Use a proper read to extract PIN/CS/MAC instead. As stated, "FFowanie immo will not do anything, it does not work in A3." [Elektroda, OskiA3, post #17182535]
What tools can pull PIN/CS/MAC on these VDO Micronas clusters?
Use a Dragon tool with a JTAG connection to the cluster. It can extract the PIN, immoid, CS, and MAC directly. Avoid FF‑based tricks; they won’t work on A3 Micronas. This approach supports all‑keys‑lost situations. [Elektroda, OskiA3, post #17182535]
Can CarProg do an all‑keys‑lost key on this model?
No. Practitioners report that while devices exist for this job, CarProg is not the right tool for all‑keys‑lost on this A3. Choose hardware that can read Micronas/EEPROM and handle dealer‑key precoding. [Elektroda, miler80, post #17180830]
How much does a dealer (ASO) key cost for a 2007 Audi A3?
Expect approximately PLN 600–800 for a new original key at the dealership. This route is fast but expensive compared to bench coding. Verify identity and ownership before ordering. [Elektroda, szymitsu21, post #17181387]
What does a mail‑in transponder preparation service cost?
Around PLN 80 if you send the cluster to a specialist. They prepare the transponder (“stone/tablet”) and return it, avoiding an ASO visit. This is a budget‑friendly path for all‑keys‑lost. [Elektroda, oktawian89, post #17181400]
Can I adapt a pre‑coded key with VCDS on this car?
Yes. Once the ID48 TP25 is correctly pre‑coded with CS, you can add it using VCDS. As one expert put it, "Pre‑coded, you even add vcdsem." Ensure immobilizer data matches before adaptation. [Elektroda, OskiA3, post #17184080]
How do I solve it step‑by‑step if all keys are lost?
Confirmed working path:
  1. Read the cluster’s Micronas MCU and EEPROM on the bench.
  2. Use Abrites AVDI to compute immo data and generate the transponder.
  3. Write the modified EEPROM back to the cluster and test start. This sequence restored operation for the case discussed. [Elektroda, oktawian89, post #17256565]
Is the PIN alone enough to add a key on a 2007 A3?
No. This dealer‑key platform needs the 7‑byte CS to pre‑code the ID48 TP25. The PIN supports adaptation, but precoding fails without CS. Precode, then adapt; PIN alone will not prepare the chip. [Elektroda, oktawian89, post #17181400]
What if Abrites can’t read the cluster over OBD?
On this model, Abrites cannot read the cluster without a working key. Proceed by reading the Micronas and EEPROM on the bench, then process the dump to prepare the transponder and update the EEPROM. [Elektroda, oktawian89, post #17178926]
Can ODIS online or an ASO solve it without opening the cluster?
Yes. ODIS online or an ASO can provide and program a new key by VIN after verification. This avoids cluster disassembly, at higher cost, and depends on online access. [Elektroda, szymitsu21, post #17180857]
Does the “FF” unlock trick apply after 2009 clusters?
The OP notes FF unlocking applies on post‑2009 units, then restore the original dump. However, the 2007 A3 requires a programmer and bench read. Confirm cluster type and year before attempting. [Elektroda, oktawian89, post #17180916]
