Skoda Octavia II (2008) 1.9 TDI: Encoding Immo with VCDS, IMMO Pin, and Precoded Transponder
oktawian89 10461 7
  • Identifying the correct precoded transponder for Octavia II
    #1 16355877
    oktawian89
    Help: 52
    Rate: 444
    I have the 2008 Octavia II skoda-model before FL with 1.9 TDI. The only key lost. After making the arrowhead from the ignition and inserting a new tablet am I able to program the immo to fire it? I have VCDS in stock, I understand I need a pin immo?
    From what I see I need a transponder precoded under the skoda:
    SKODA OCTAVIA 2007 2011 Transponder Megamos Crypto precoded by VIN / Component Security (dealer key)
    Anyone know any exact markings for this transponder?
  • #2 16356221
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    There probably should be ID48 TP24.
    I don't know if you can do it.
    It is better to make a file from the batch only then you need to read SB from the counter.
    Talk to your friend Pati because he used to solve this problem.
  • #3 16356289
    oktawian89
    Help: 52
    Rate: 444
    SKODA OCTAVIA 2004 2006 Transponder MEGAMOS Crypto CAN ? Abritus TA4 ? JMA TP24
    So the one you provide is for the older version.
  • #4 16356402
    bodzio012
    Help: 161
    Rate: 780
    Is it not easier to cut the key from the cylinder? Immo I don't think you can handle vcds
  • #5 16356544
    oktawian89
    Help: 52
    Rate: 444
    So what if it does not start the engine?
  • #6 16356597
    bodzio012
    Help: 161
    Rate: 780
    You will have a cut key because you won't miss it anyway
  • #7 16356611
    oktawian89
    Help: 52
    Rate: 444
    There are no more inserts. One I damaged to get into the car and the other someone with a similar attempt. I have already bought an ignition with inserts for PLN 130, so cheaper than making a key with an insert. Now just a matter of coding or immo off on edc16
  • #8 16413384
    oktawian89
    Help: 52
    Rate: 444
    The key was made as original without immo off.
    ID48 TP24 lozenge pre-coded works.
    I close.
The discussion revolves around programming the immobilizer (immo) for a 2008 Skoda Octavia II 1.9 TDI after losing the only key. The user inquires about using VCDS for immo programming and the necessity of an IMMO PIN. Responses indicate that a Megamos Crypto transponder, specifically ID48 TP24, is required for the 2007-2011 Octavia models. Some participants suggest alternative methods, such as cutting a key from the ignition cylinder, while others confirm that a pre-coded transponder can be used without needing to disable the immo. The final confirmation states that the ID48 TP24 transponder works effectively when pre-coded.
