Focus MK1 1.8 TDDI - FoCOM Program: Pump Coding Adaptation, Driver Replacement, K-Line vs CAN
mbohun 7977 11
Can FoCOM adapt the pump after replacing the driver on a Focus Mk1 1.8 TDDI, and is it connected via K-line or CAN?
Yes, the replies say FoCOM can adapt the VP44 pump after the driver is replaced, and one user says there are no in/out codes on this pump—only a 10-minute time delay—and that FoCOM does it without problems [#16647103][#16646481] Another reply says the procedure is done via OBD, with KTS used for the job [#17311151] A later user also confirms that several Focus cars were successfully handled after pump replacement [#16647335]
  • #1 16645846
    mbohun
    Rate: 43
    Hello. I am looking for a specific, unambiguous answer to the question whether the FoCOM program is able to adapt the pump after replacing the driver? Some say that it is possible and others that not. Has anyone done the focom adaptation. If it can be done, I would ask for information on how to connect to the pump. Some say that after k-line, others that after CAN.
  • #2 16646303
    AuKElMe
    Help: 17
    Rate: 36
    focom will take over, by no means the Transit 2.4 with such a pump, time about 10 minutes and the generator needed for in-out codes
  • #3 16646357
    mbohun
    Rate: 43
    Well, this is a problem because I do not have a code generator
  • #4 16646481
    adrian1201
    Help: 128
    Rate: 416
    No generator is needed for the pump.
  • #5 16646671
    adam7009
    Help: 656
    Rate: 1636
    it depends which year in terms of codes.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #6 16647103
    adrian1201
    Help: 128
    Rate: 416
    None on the vp44 pump required in / out, only a 10min time delay, and FOCOM will do it without a problem.
  • #7 16647335
    zubereq
    Help: 13
    Rate: 89
    I confirm, a few focuses after replacing the pump in this engine were overwhelmed.
  • #8 17310537
    Jaroszek10
    Have you made the pump adaptations using the standard OBD2 connector?
    Do you need any special?
  • #9 17311151
    mbohun
    Rate: 43
    Unfortunately, due to the lack of the program, I had to lose 150 PLN and give someone to rip immo. From what ki is known, it is via obd. Taken with kts
  • #10 17311177
    Jaroszek10
    Can Focom do it?
  • #11 17311264
    mbohun
    Rate: 43
    As my colleagues wrote above, I am going to do it. I couldn't do it, because the program failed and I gave it up. There was no time
  • #12 17934689
    js83
    Rate: 9
    Hello, I have a broken pump driver in the 1.8 tddi focus and I have a second driver from another
    I have an elm 327 interface and the fa com program will try to reset the pump
    If so, someone will suggest how to do it. Thanks in advance
    Best regards.
The discussion centers around the capability of the FoCOM program to adapt the fuel pump after replacing the driver in a Focus MK1 1.8 TDDI. Users express varying opinions on whether a code generator is necessary for this process, with some confirming that FoCOM can handle the adaptation without one, particularly for the VP44 pump. The connection method for the pump adaptation is debated, with suggestions of using either K-Line or CAN protocols. Several users report successful adaptations using standard OBD2 connectors, while others mention challenges faced due to program failures or lack of equipment.
TL;DR: Focus MK1 1.8 TDDI VP44 pump adaptation with FoCOM takes about 10 minutes; “FOCOM will do it without a problem.” [Elektroda, adrian1201, post #16647103]
Can FoCOM adapt the VP44 pump after a driver replacement on Focus MK1 1.8 TDDI?
Yes. Users report FoCOM completes VP44 pump adaptation after a built‑in ~10‑minute delay, with no in/out codes required. “FOCOM will do it without a problem.” [Elektroda, adrian1201, post #16647103]
Do I need an in/out code generator for this Focus VP44 pump?
No. For the VP44 on Focus MK1, adaptation proceeds without an in/out code generator; only the timed delay applies. [Elektroda, adrian1201, post #16647103]
Is the standard OBD2 connector enough, or do I need a special lead?
A standard OBD2 diagnostic connector was used in-thread. One user notes the task was performed via OBD using a KTS tool. [Elektroda, mbohun, post #17311151]
What if FoCOM fails during adaptation—what’s the fallback?
One user abandoned adaptation due to program issues and paid for immobilizer removal. Expect about 150 PLN if you outsource. [Elektroda, mbohun, post #17311151]
Does the model year change the code requirements?
Yes. Participants note that code behavior depends on production year, so plan accordingly before starting. [Elektroda, adam7009, post #16646671]
Were there successful real-world adaptations after pump replacement?
Yes. A member confirms completing several Focus pump swaps that adapted correctly afterward using diagnostic tools. [Elektroda, zubereq, post #16647335]
Can I do this with an ELM327 interface and FoCOM?
One user intended to try FoCOM with an ELM327. The thread does not confirm success or compatibility for this combo. [Elektroda, js83, post #17934689]
Does Transit 2.4 behave differently for this pump type?
An edge case notes Transit 2.4 may require in/out code generation despite a ~10‑minute window. Verify tool support first. [Elektroda, AuKElMe, post #16646303]
K‑line or CAN—how does FoCOM connect for this job?
The discussion contrasts K‑line vs CAN, but users completed the task through the vehicle’s OBD2 port in practice. [Elektroda, mbohun, post #17311151]
What’s a quick 3‑step how‑to for FoCOM pump adaptation?
  1. Connect FoCOM to the OBD2 port and turn ignition ON.
  2. Start the pump adaptation function and wait the ~10‑minute delay.
  3. Confirm synchronization, clear faults, and test start. [Elektroda, adrian1201, post #16647103]
Can a general scan tool like Bosch KTS handle this over OBD?
Yes. A user reports the procedure was “taken with KTS” via OBD, indicating capability with pro-grade scanners. [Elektroda, mbohun, post #17311151]
