LG K500N Black Screen, Battery Icon with Flashing Red Question Mark - New Battery Installed
napster2 3333 7
  • #1 16383888
    napster2
    Rate: 9
    Gentlemen, as in the topic, I have LG K500N, if I want to turn it on, it is a black screen and shows the battery in the middle and a red question mark flashes in the middle of the battery, the phone does not respond to anything, whether connected to a computer or charging. The battery is new because I bought a new one and I don't know anymore. Can anyone help??
  • #2 16383992
    actin
    Help: 187
    Rate: 799
    Looks like damage inside the battery. If it is new, give it back and take another.
  • #3 16384077
    napster2
    Rate: 9
    NO yes, I have already tried 2 others and the same. And does the micro socket have anything to do with it?
  • #4 16384505
    actin
    Help: 187
    Rate: 799
    Is it damaged? Broken or something?
  • #5 16384563
    napster2
    Rate: 9
    No no, the socket is not torn, but this is what I ask because there is no power for this phone, I have already tried to connect the battery directly, but then the same symptoms, the phone does not turn on and the battery is shown and the question mark flashes inside. I would ask for help.
  • #6 16385248
    actin
    Help: 187
    Rate: 799
    What happened with the first battery?
  • #7 16386837
    napster2
    Rate: 9
    The same problem happened with the first battery. It shows 4.89V on the charging connector and 4.16Volt on the battery connector, and when I connect the charger to 4.04 I charge and then discharge the battery. So I guess the charging system or what? But if there was a charging system, at least the batteries would be detected.
  • #8 16460827
    hubertus1988
    I have the same and I have no idea to go on? Similar measurements. Even a battery charged by another k500 does not help, the one that does not turn on still sleeps.
The discussion revolves around an LG K500N smartphone that displays a black screen with a flashing red question mark over the battery icon, indicating a power issue despite having a new battery installed. The user has attempted multiple batteries and direct connections but continues to experience the same symptoms. Responses suggest potential internal damage to the battery or issues with the charging system, as the phone does not respond to charging or connection attempts. The user reports voltage readings from the charging and battery connectors, indicating possible malfunction in the charging circuitry.
