LG G Pad8.0 tablet Exclamation mark in yellow triangle next to the battery while
Kamisko 6096 1
  • #1 16326602
    Kamisko
    Hey. I'll start with the fact that so far the tablet has been great. However, today after discharging it I connected it to charging. Apparently everything is ok, but when it was about to turn on next to the battery an exclamation mark in a yellow triangle pops up. I will add that the tablet has never been wet. I checked other chargers and connected to a computer via USB, still the same. What can be about? I can't remove the battery and do a hard reset because I don't know the up down key combination. ; /
  • #2 16328146
    Butcher696
    Rate: 8
    This symbol indicates a problem with the battery - usually it is when the battery is no longer charging - to be replaced. Hard reset does not help in this case. The easiest way is to either desolder the cables from the board and charge the batteries from the outside for a while, wait 30-1m and then check if the tab will fire like plugging a normal charger and check if it will charge something by how many percent and how long it holds - you can just wake it up not a replacement for 2 batteries a new cost of 10-20 PLN depends where you buy
