HTC Desire D820N Not Powering On - Red Light Flashing: Possible Battery Issue?
JaroFon 9018 6
  • #1 16897294
    JaroFon
    Help: 11
    Rate: 355
    Hello. I have a phono like in the subject. It can not be started. When I connect the charger, the red light flashes constantly. As I connect to a PC, this computer will install the drivers and generally the phon is seen in the PC. In the net I have read that in this model the flashing of the red control is most likely a sign of a damaged battery. However, before I cut the phon (and as you know to get to it, you have to break it) I want to make sure it can be a faulty battery?
  • #2 16897583
    Krzysiek756
    I had such a problem ... And it's a battery
  • #3 16897727
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Unscrew and check the voltage on the battery.
  • #4 16897743
    JaroFon
    Help: 11
    Rate: 355
    Thanks to my friend for the hint, but as I mentioned this phone must be rozkleić to get to him, so my question before I rozkleję
  • #5 16897807
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Well, what about the fact that you have to break it ?? In this situation, you have no other choice. If you want to repair it at the beginning with such symptoms, the voltage on the battery always works. And the fact that it is glued is nothing scary, half of the phones are like that now.
  • #6 16897827
    JaroFon
    Help: 11
    Rate: 355
    For me, breaking up the phone is a breeze, but I wanted to make sure it could be the battery before I split it.
  • #7 16905348
    JaroFon
    Help: 11
    Rate: 355
    Unfortunately, the option of damaged battery falls out. Mom's phone opened, I bought a new battery and replaced it. Unfortunately, but nothing has changed that. Everything is like in previous posts, that is: the red light blinks, the phone connects to the PC. Any other ideas?
The HTC Desire D820N is experiencing a power issue characterized by a constant flashing red light when connected to a charger. Users suggest that this symptom typically indicates a faulty battery. One user recommends checking the battery voltage, although accessing the battery requires disassembling the device, which is a concern for the original poster. After replacing the battery, the issue persisted, leading to further inquiries about potential solutions, as the phone still connects to a PC but does not power on.
