Locating Firmware Updates for D-Link DWR-960 LTE Router Not Listed on Website
medex 19215 20
Where can I find official firmware updates for a D-Link DWR-960 LTE router if it is not listed on the D-Link website?
You should look for firmware on the operator’s official support site rather than D-Link’s website, because the DWR-960 is a Plus-supplied model and D-Link Polska does not provide local support for it [#16384439] One reply says the latest official firmware available was from May 2017 for Plus and CP [#16663995] Another later reply points to the latest software from 2019 coming from the official CP website [#18993923]
  • #1 16384311
    medex
    does anyone of you know where you can find technical support (new firmware updates) for this router (you can not see it on the D-Link website)?
  • #2 16384361
    jimasek
    Help: 3783
    Rate: 2681
    Personally, I do not think about downloading updates from unreliable torrent or hamster sources. We only download updates from the manufacturer's website.
  • Seeking official firmware for unlisted D-Link DWR-960
    #3 16384402
    medex
    I agree - the problem is that the manufacturer (D-Link) does not have this model - my uncle Google also does not tell me much about this topic, so I count on the electrodes ;) maybe someone has this router and somehow managed to get the firmware update
    matek451
    Help: 4352
    Rate: 5808
    And what purpose do you want to do this and how do you know that FW is out of date? This DWR-960 comes from Plus and the operator probably will give an update if it appears. D-Link DWR-966 and DWR-960 are not offered for sale in Poland, there is no D-Link Polska support. DWR-960 is such a depleted version of DWR-966.
  • #5 16387817
    medex
    Thanks for the info.
    I wanted to update the firmware because the router does not work correctly, it shows the SNIR value at 45464566 dBm, and the link speed test shows less than 1 Mbps dowlnoad and upload. Another LTE modem connected to the same antenna (Huawei B315) shows the SNIR value at level 8 and the link speed test is 30-40 Mbps. I wrote to Plus in this regard that the router is probably damaged and recommended to return to warranty service ....
  • #6 16482158
    tomekw_76
    There are more problems, eg you can not change the Administrator's password
    (error message is completely meaningless: Please check the settings again !!
    and: Please enter IP address '0.0.0.0' to allow access to the device from any IP address.)
    Everything about.
    I think that such an error is enough motivation to look for a new WF.
    I was looking for FW on D-Link websites other than PL, there is nothing there.
  • #7 16483693
    medex
    I filed a complaint with D-Link, I described the problem, I sent the device. They sent new ones from a warehouse in the UK. I am curious if it will work correctly ;)
  • #8 16505116
    adrspach7
    Medex, in general, how do you see this router? The contract ends up in the plus and I am just wondering about this model (mainly due to 300mb)
  • Huawei B315 lacks port forwarding rule descriptions
    #9 16505486
    medex
    Since I received the new equipment after the complaint, I have not yet had the opportunity to test it for good.
    In general, what has struck me in the eyes of the Huawei B315 is the inability to add descriptions when port forwarding, which in the case of a large number of rules can be troublesome.
    I will let you know how to fire up the equipment permanently and will work better in terms of catching the LTE signal.
  • #10 16506023
    adrspach7
    I am waiting impatiently, because they want to push me in the plus :)
  • #11 16506080
    matek451
    Help: 4352
    Rate: 5808
    This is unfortunately a worse router than the one offered earlier in Plus DWR-966 but the only stationary from LTE-A. The cost in a 24x25,50 subscription or 612 PLN is not adequate to its potential, worth from PLN 300-400. For PLN 400-600, you can buy Huawei B618, B525 or E5186. Well, do not count on 300Mb / s in Plus. This is a theory and you would have to use the LTE2600 + LTE1800 aggregation, ie be within the LTE2600Plusa and LTE1800Aero2 network (both on the same BTS). Plus it has a trace amount of LTE2600 BTSs operating.
  • #12 16506158
    adrspach7
    This router will work in T-mobile. On the plus side, I only take the subscription and equipment, and the plus card will fly to B315.
  • #13 16506763
    matek451
    Help: 4352
    Rate: 5808
    The prolongation of the Plus contract is best negotiated with DUK after termination, and then the equipment is owned and paid for. Alternatively, the SIM itself, eg 40GB for PLN 19.99. .
  • #14 16512991
    adrspach7
    That's what I've done for years, D gave me 70gb + unlimited LTE for 35 PLN and this dlinka for 49 PLN. I know that it was possible to draw more, for example, 40 gb for 25 PLN and installment for this dlinka 3 PLN / month. Only that I often have some strange lte failures and I prefer to have 70gb if necessary.
  • #15 16513004
    matek451
    Help: 4352
    Rate: 5808
    Offer with this D-Link for PLN 49 good, worth PLN 500. If you were dissatisfied with it, it's Allegro and you can buy the Huawei mentioned above for that kind of money.
  • #16 16513103
    adrspach7
    We will see, I will definitely let you know, because there is not much information about this equipment on the net. Although I do not have any big expectations about him :)
    Foxtrott
    Help: 253
    Rate: 944
    The latest official firmware from May 2017 for "plus and cp"
    • DWR-960-A1-CP-V01.02.3.036-2017-05-02.bin.zip (11.06 MB) You must be logged in to download this attachment.
  • #18 16705507
    medex
    Many thanks for the new firmware. Pytanko where can it be obtained (so for the future)?
    Returning to the previous discussion about the DWR-960 router and problems with the parameter SINR ..
    As I wrote, I sent a router for a complaint, they sent a new one.
    Only on Saturday I had time to install it, I connected the 1800 MHz antenna and what turned out:
    1. On automatic WAN connection (apn: Internet and access number * 99 * ...) theoretically works correctly (SINR shows on level 10)
    2. I use public IP, which requires changing apn and setting the connection manually, and here again it starts to be interesting because for about 4 hours after starting the router keeps the signal correctly and then there is a return to the history from which I started this topic, that is some nonsense in the field SINR ...
    can any of you have any ideas where to look for causes and solutions?
  • Ethernet access to router page is unreliable
    #19 16925725
  • Peak-hour speed reveals overloaded mobile network
    #20 16925742
    matek451
    Help: 4352
    Rate: 5808
    Did you read what you wrote? The measure of how the internet works is speed in the evening and on holidays, that is at internet rush hour. Apart from them, it does not matter. You're probably using Urine's urine, so it's normal. This worst mobile operator has not modernized the network properly for a long time and the BTSs are clogged and overloaded to the max. Good mobile internet 50Mb / s during peak hours and 200Mb / s at night. In Plus, most locations are unattainable.
  • #21 18993923
    KOCUREK1970
    Help: 3861
    Rate: 5489
    Here the latest soft from 2019, soft comes from the official CP website:
    • DWR-960-A1-CP-V01.02.3.041-2019-02-25.bin (11.31 MB) You must be logged in to download this attachment.
The discussion revolves around locating firmware updates for the D-Link DWR-960 LTE router, which are not available on the D-Link website. Users express concerns about the router's performance, including issues with SINR values and slow internet speeds compared to other models. Some participants suggest that firmware updates may be provided by the service provider, Plus, as the router is often bundled with their service. Others report difficulties in changing the administrator password and accessing the router's settings. A few users have successfully filed complaints with D-Link, resulting in replacements. The conversation also touches on comparisons with other models like the Huawei B315 and DWR-966, highlighting the DWR-960's limitations and performance issues.
