D-Link DWR-116 Wi-Fi / LAN router - I can't access the router
joe555 8895 13
How can I regain access to a D-Link DWR-116 router if I cannot log in or reset it?
To regain access to the DWR-116, connect to it by cable, set your network card manually to IP 192.168.2.10 with 255.255.255.0 and leave DNS empty, then open the router’s address (usually 192.168.2.1) and try the default login admin/admin. [#16634879] [#16631938] If 192.168.0.1 does not work, check your PC’s default gateway with `ipconfig` because that will show the router address. [#16634201] If the router still does not respond, make sure it is powered on and hold the reset button for 5 seconds to restore factory settings. [#16631768] After a reset or firmware change, the login details may have reverted to factory defaults. [#16631815]
  • #1 16631712
    joe555
    Hello, I have a router dwr 116 can not enter the router
    Added after 57 [seconds]:
    I can't reset it
  • #3 16631771
    joe555
    I did thread and I used to do soft hair
  • #4 16631815
    g107r
    Help: 811
    Rate: 993
    Have you updated your router software? So maybe.
    Are you logging in as an admin to the router? The old login details have probably been restored to the factory defaults.
  • #5 16631827
    joe555
    I can't get on the router at all
    Added after 9 [minutes]:
    how I wanted to restart it and from then on something stupid
    Added after 22 [minutes]:
    192.168.0.1 I entered it from another forum and it entered but the password does not enter I do not know what happened
    dwr116_106plb05
  • #6 16631938
    simhak
    Help: 109
    Rate: 336
    Behind the operating instructions:
    192.168.2.1
    admin admin
  • #7 16634201
    mazi292
    Help: 8
    Rate: 14
    To be sure, enter CMD and enter ipconfig, the default gateway will come out and this will be the router's address
  • #8 16634879
    KOCUREK1970
    Help: 3862
    Rate: 5490
    joe555 wrote:
    I used to do soft, maybe he
    What soft, where is it downloaded from?
    Perhaps the router is already a brick.
    192.168.2.1
    admin admin
    You connect to this router with a cable, but you need to set the parameters of your network card beforehand.
    Her IP address is 192.168.2.10
    Gateway: 255.255.255.0
    DNS: you don't enter anything
  • #9 16635185
    joe555
    I just entered that now there is a problem the range before was ok with Playa. I had a speed of 5.5 mb
    and now I have 123 kbps
  • #10 16635197
    matek451
    Help: 4352
    Rate: 5808
    And what does DWR-116 have to do with Play speeds? After all, he is not responsible for the connection to the 3G / LTE Play network.
  • #11 16635199
    joe555
    Oh, maybe not and you can do something
  • #12 16635232
    matek451
    Help: 4352
    Rate: 5808
    Buddy, you didn't write much, we practically don't know for what purpose you changed FW and for what, you don't know what modem you are using with this router. It is not known what the card and offer on Play is. What are your signal parameters and do you use 3G or LTE in Play, on what band and in what location, how far to BTS and do you use an external antenna?
  • #13 16639696
    joe555
    I'm using a 4 g LTE modem huaway, but I don't remember the model
    Added after 40 [seconds]:
    I have a piece for BTS.
  • Need exact modem and LTE band details
    #14 16639753
    matek451
    Help: 4352
    Rate: 5808
    You don't have to remember, the modem is described and just provide this data, I don't know the measure of the distance a piece. there is no room for guesses, I use specific data and, unlike the nonsense and promises made by consultants in salons, they are needed to obtain the correct signal and transfers on the mobile internet. Together with this weak router, Play offered an E3272 and E3372 modem. The e3272s-153 modem is available in regular and HiLink versions. and E3372 in two hardware versions s-153 and h-153 and each as HiLink and regular version. Play uses LTE on four bands, LTE2600, LTE1800, LTE2100 and LTE800.
The discussion revolves around issues accessing the D-Link DWR-116 router. The user reports being unable to log into the router and having trouble resetting it. Various suggestions are provided, including checking the router's IP address (192.168.0.1 or 192.168.2.1), ensuring the correct admin login credentials (default: admin/admin), and updating the router's firmware. There are also inquiries about the user's modem and network settings, as well as concerns regarding internet speed after a firmware change. The conversation highlights the importance of specific modem details and network configurations for optimal performance.
TL;DR: Can’t access your D‑Link DWR‑116? Browse to 192.168.2.1 and log in with “admin admin”. Adjust your PC settings if required. [Elektroda, simhak, post #16631938]
Why it matters: This FAQ helps DWR‑116 owners quickly restore access and avoid avoidable LTE/USB‑modem pitfalls.
How do I access the DWR‑116 admin page?
Connect via Ethernet, open a browser, and go to 192.168.2.1. Use username admin and password admin. [Elektroda, simhak, post #16631938]
What are the default login and IP after a reset?
After restoring defaults, the router listens at 192.168.2.1. The default credentials are admin/admin. [Elektroda, simhak, post #16631938]
How do I factory‑reset the DWR‑116 correctly?
Verify the router is powered. Press and hold the front restart button for 5 seconds. Wait for it to reboot, then log in. [Elektroda, g107r, post #16631768]
I can’t find the router’s address. What’s the quickest way?
On Windows, open Command Prompt, run ipconfig, and read the Default Gateway. Use that IP in your browser. [Elektroda, mazi292, post #16634201]
The login page loads but my password fails—what now?
If you updated firmware or reset, factory credentials may apply. Try admin/admin as the admin login. [Elektroda, g107r, post #16631815]
What PC network settings help when the page won’t load?
Set a static IPv4 on your NIC: IP 192.168.2.10, mask 255.255.255.0, leave DNS blank. Connect by cable. [Elektroda, KOCUREK1970, post #16634879]
Could a bad firmware flash brick the router?
Yes. If the wrong software was used, the device can become a brick and stop responding. Recovery may require reflash tools. [Elektroda, KOCUREK1970, post #16634879]
My LTE speed dropped after I “fixed” the router. Is the DWR‑116 to blame?
No. “He is not responsible for the connection to the 3G/LTE Play network.” Check your USB modem and signal. [Elektroda, matek451, post #16635197]
Which Huawei USB modems were commonly paired with the DWR‑116?
Play often bundled Huawei E3272 and E3372 models. Variants include regular and HiLink versions. [Elektroda, matek451, post #16639753]
What does HiLink mean on Huawei modems?
HiLink models run their own web UI and act like network adapters. Regular versions use dial‑up control from the router. [Elektroda, matek451, post #16639753]
What info should I share to get help with slow mobile internet?
Provide modem model, SIM/offer, signal details, 3G or LTE band, location, distance to BTS, and antenna use. [Elektroda, matek451, post #16635232]
192.168.0.1 opens something—should I use 192.168.2.1 instead?
Yes. DWR‑116 factory settings use 192.168.2.1 with admin/admin. Some networks use 192.168.0.1, which may confuse discovery. [Elektroda, simhak, post #16631938]
Does the DWR‑116 control my LTE connection or only route it?
It routes traffic. The USB modem and mobile network determine attachment and throughput. Test with the modem directly. [Elektroda, matek451, post #16635197]
How do I set a static IP to reach the router? (3‑step quick guide)
  1. Connect your PC to the DWR‑116 with an Ethernet cable.
  2. Set IPv4: IP 192.168.2.10, mask 255.255.255.0, DNS blank.
  3. Browse to 192.168.2.1 and log in as admin. [Elektroda, KOCUREK1970, post #16634879]
