Swapping Out Dual Amplifiers for Single TDA7564b in CD30 mp3 Radio: How-To?
filip377 12453 4
  • Dual amplifier replacement and TDA7564b fitment questions
    #1 16384774
    filip377
    Rate: 9
    I would like to replace the power amplifier for TDA7564b on my radio (CD30 mp3). I read on a foreign forum that it significantly improves the quality of music, but after dismantling the radio I noticed that it has two smaller power amplifiers. Here the question arises, should I both desolder and replace them with one TDA7564 or two? Going further, the width of the tip that I want to insert is greater and I do not know how to solve it, because there are not so many holes in the plate. Below I upload photos of the situation.
    Swapping Out Dual Amplifiers for Single TDA7564b in CD30 mp3 Radio: How-To? Swapping Out Dual Amplifiers for Single TDA7564b in CD30 mp3 Radio: How-To? Swapping Out Dual Amplifiers for Single TDA7564b in CD30 mp3 Radio: How-To?
    goldi74
    Help: 1367
    Rate: 1539
    Both systems are not directly interchangeable with each other. Soldering TDA7564B directly onto the original board is not possible.
  • #3 16384996
    filip377
    Rate: 9
    And which system would be better than the factory? Will the TDA7294V fit and the difference will be felt?
  • #4 16385284
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    The TDA7375 sound very good, there is no need to replace them.
    This is not a car radio tip. Start with speakers, door damping, etc.
  • Questioning replacement of two amplifiers with one TDA7564B
    #5 16385390
    398216 Usunięty
    Help: 3925
    Rate: 9453
    You've hurried a bit with this joke - April Fool's Day is only today.
    But if it was serious, then I will ask deadly seriously - Did you take something that you can't think logically? How can you ask such questions at all - you have two, and you want to insert one - and in addition a completely different one?
