Comparing TDA7388 and TDA7850 Amplifiers: Sound Quality, Bass, and Heat Dissipation
LENIWIEC_PL 19182 2
  • #1 16681326
    LENIWIEC_PL
    Help: 119
    Rate: 322
    I warmly welcome.
    Well, for a long time I have been planning to build a simple amplifier powered by automotive voltage. I read a lot of topics and the choice fell on one of the TDA chips mentioned in the title. However, apart from the output power, how do they differ exactly? Which, in your opinion, has better sound and bass quality (I care about bass the most)?
    Reading the datasheets of both, I noticed that the TDA7850 chip has "MOSFET quad bridge power amplifier" in its name instead of "car radio ampliefier", does that mean it is not intended for car audio applications?
    The next question is the thermal power dissipated by both systems, which is 80W. What do you propose to use a heat sink to cool it down?
  • #2 16681380
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Both cubes are for the same purpose.
  • #3 16691341
    LENIWIEC_PL
    Help: 119
    Rate: 322
    Thank you for your answer.
    And will aluminum sheet with dimensions of 15x4x2 cm be able to cool one of these cubes?
