iPhone 6 Plus Network Issue & Speaker Failure: Baseband Reballing Repair Worth It?
vento1982 13080 7
  • #1 16386516
    vento1982
    Hello, I have an iPhone 6 plus that works but I can not find the network and does not work speakers since I have read a lot about Baseband reballing whether it is to fix it and whether it pays to repair I do not have how to diagnose it because I'm abroad a problem like the movie
    https://www.youtube.com/watch?v=mkDhzqq3Yuk
  • #2 16386618
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    1. You have imei and modem firmware in settings >>> general >>> this device ???
    2. You have imei after entering the number selection on the keyboard: * # 06 # ???
  • #3 16386622
    vento1982
    I do not have only imei after entering the code, nothing is displayed and the settings are imei and everything only where I write the network is not available and where the operator writes play.
  • #4 16386679
    gsmowiec
    Help: 27
    Rate: 128
    Well, you do not have such a condition as in the movie because you searching does not show in the place of coverage since the firmware in the settings is present.
    The gsm track is very extensive, so it's hard to say anything at a distance because it's about 250 elements, but I would leave the entire baseband in the past for now.
    If you do not know it is only a GOOD service can help but apple >>> iphone is the most expensive model for maintenance will also not be cheap.
  • #5 16387129
    vento1982
    I noticed the slit tape in iphon.
    3.1.13. Take care of linguistic correctness and keep netiquette rules.
    I have corrected the post.
    MOD. nutergsm
    • iPhone 6 Plus Network Issue & Speaker Failure: Baseband Reballing Repair Worth It? 17690854_772274109603218_301631035_n.jpg (54.85 KB) You must be logged in to download this attachment.
  • #6 16387712
    gsmowiec
    Help: 27
    Rate: 128
    If it's damaged, replace it.
  • #7 16387722
    vento1982
    how tight the screen next to the tape it loads tewlfon but still jumps out looking for a network I will not have to give a diagnosis but it's only in 2 weeks because I'm not in the country
  • #8 16388166
    ArcziGSM
    Replace the charging module and the headphone jack along with this you have a built-in GSM antenna. Recently I had 6 without range and such exchange helped.
The discussion revolves around an iPhone 6 Plus experiencing network connectivity issues and speaker failure. The user is inquiring about the viability of baseband reballing as a repair solution. Responses indicate that the absence of network signals may not be solely due to baseband issues, as the device still shows IMEI in settings. Suggestions include checking the charging module and headphone jack, which also houses the GSM antenna, as potential culprits for the connectivity problem. The consensus is that a professional service is recommended for diagnosis and repair, especially given the complexity of the GSM circuitry in the device.
