VW Touran 1.9 TDI BKC 2006: Fuel Pump Power Discrepancy After Meter Disconnection
waves79 21075 15
Why does the fuel pump on a VW Touran 1.9 TDI not receive power after disconnecting the instrument cluster?
The pump is not getting supply at relay terminal 30, so the fault is most likely in the feed from the fuse/terminal 30 to the relay, not in the pump itself or the immobilizer [#16387960][#16388188] Check the under-hood fuse and verify the correct fuses, including F10 from terminal 30 and F15 for the pump, then trace the harness for a broken wire or any cut-off/alarm module [#16387850][#16388157] One reply notes that an immobilizer fault would let the engine start and then die, which does not match this symptom [#16387851] In the end, the poster fed the pump from another terminal and it ran, confirming a wiring/feed problem that still needs proper repair [#16533706]
  • #1 16387798
    waves79
    Hello, after disconnecting the meter for a while, he stopped feeding fuel.
    I changed the fuel filter, flooded it with fresh fuel, twisted it a little and fell again.
    There was no pump in the tank, so I checked the relay.
    Ticking ticked, but I don't know if it touched, so I changed it with a horn, but nothing better.
    So I got to the pump, unplugged the plug and on external cables pins 1 and 5 after turning the key I have about 0.02V sometimes to 0.06V
    (when setting the multimeter to a range of up to 20V DC so that nobody has any doubts)
    Disconnecting the pressure sensor immediately after the fuel filter does not cause any difference in the voltage readings.
    To make sure that there are no more than one reasons, I pulled the pump out of the tank and after giving it 12V, the pump motor works.
    Writing this I came up with the idea to check the voltage meter on the relay, I eliminate the problem with cables, what I'm going to do now.
    It looks like this from my amateur point of view ...
    Any other ideas?
  • #2 16387845
    sly_1978
    Help: 34
    Rate: 284
    Immo probably has done something. Someone can improve me?
  • #3 16387848
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    At immo it will start and go off.
  • #4 16387850
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    A fuse under the hood, probably check 27 (terminal 30 of the fuel pump relay) but I'm not sure.
  • #5 16387851
    spinacz
    Help: 1204
    Rate: 2654
    As if the immo would fire up for 5 seconds and go out, the problem may be completely different.
    The basis for checking the fuses, relay and voltages on its contacts, then the continuity of the wires.
  • #6 16387863
    waves79
    Voltage on the relay:
    11.8V on the control side
    0.02V on the supply side
    Of course, we are talking about the momentary state after turning the key, or at start
    11.8V battery (got a little wind up during rehearsals but keeps turning - I'm charging it tonight)
  • #7 16387871
    spinacz
    Help: 1204
    Rate: 2654
    what does it mean because i don't understand
    Describe what voltages do you have on which pins of the relay
  • #8 16387878
    waves79
    I have already checked fuses, many times.
    I'm going to watch the cables now ...
    11.8V on thin cables
    0.02V on coarse that go to the pump
    Regardless of whether the pump is connected or not, in both cases the relay has the same readings.
  • #9 16387886
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    One wire marked on relay 87 goes to the pump !!!!!!!
    Look for voltage at relay contact 30.
  • #10 16387924
    waves79
    There is no voltage at contact 30.
    Only when closing the circuit does the previously mentioned 0.02V appear
    (perhaps by the phenomenon of induction, but this is not related to the topic)
  • #11 16387937
    spinacz
    Help: 1204
    Rate: 2654
    Do you want to check the fuse from the pump? How does it work if there is no voltage on the relay?
  • #12 16387959
    sly_1978
    Help: 34
    Rate: 284
    This counter made me think.
  • #13 16387960
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    And here you have the cause of your fault. Maybe you have an alarm or a cut-off if you say that the fuses are definitely ok.
  • #14 16388157
    waves79
    Unfortunately, I don't know anything about any additional alarms or shut-offs ...
    Fuses F10 from terminal 30 and F15 from the pump are good. Anything else, anyway :)
    I even checked the voltage on the F10 fuse and it has those 12V what it has to have.
    What should I do with this? Ride the harness and look for a damaged cable?
    Maybe some connector somewhere along the way is what may not touch?
  • #15 16388188
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    Well, rather, since there is voltage on one end of the cable and there is no on the other. Provided that you check the correct fuse.
  • #16 16533706
    waves79
    Unfortunately, I haven't had time to get to this beam yet, but I stole the current from another terminal and the pump was running. If it's time I'll fix it right. Thank you for your help.
The discussion revolves around a fuel pump power issue in a 2006 VW Touran 1.9 TDI BKC after the fuel meter was disconnected. The user reports that after changing the fuel filter and checking the relay, the pump still does not receive adequate voltage, showing only 0.02V to 0.06V at the pump connector. Various suggestions are made, including checking the immobilizer (immo), fuses, and relay contacts. The user confirms that fuses are intact and voltage readings indicate a problem with the relay or wiring. Ultimately, the user finds that powering the pump directly from another terminal allows it to run, indicating a wiring issue that needs further investigation.
