VW T4 2.5 2002 Diesel Engine Overhaul: Fuel Pump and Injector Issues, Missing Relay and Fuse Diagram
dani15202 9585 8
  • #1 16295028
    dani15202
    Hello, my friend did me a major overhaul of the engine after putting it in, I can not start it on Plaku. I will add that the fuel does not give the injections, but comes to the pump and returns. I also have a diagram where and what the relay should be, maybe someone has a diagram with fuses and relays for the t4 2.5 diesel 2002 (because after the purchase there was no relay and fuse) I bought it for heating candles and for the fuel pump, but the pump does not fit anywhere Can someone advise what is wrong with him? (I will add that there is no front belt) What may be the reason that I do not want to start. The pump and injectors were handed over to a specialist.
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Diagnostics was?
    Any mistakes?
    Relay 109 is?
    The glow plug indicator goes on for a second?
  • #3 16297528
    dani15202
    I fired it was missing + has the pump and did not open the valve. Does anyone know what this is for? VW T4 2.5 2002 Diesel Engine Overhaul: Fuel Pump and Injector Issues, Missing Relay and Fuse Diagram
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    For activating the radiator fans.
  • #5 16360168
    dani15202
    VW T4 2.5 2002 Diesel Engine Overhaul: Fuel Pump and Injector Issues, Missing Relay and Fuse Diagram VW T4 2.5 2002 Diesel Engine Overhaul: Fuel Pump and Injector Issues, Missing Relay and Fuse Diagram
    Hello, does anyone know if there should be a rubber inside, is it to be only metal works in this 1 of the balls from the pick. I was in the store said they don't have something like that
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Inside, a plastic ball from the selector works.
    Nothing to be there except grease :)
  • #7 16360201
    dani15202
    Oki thanks so much for your help. I still had to paint tomorrow and assemble the front belt and drive as if someone needed some parts for the T4 2.5 diesel, write it is possible that I have
  • #8 16364682
    dani15202
    Hello, I come back with another question, what could be the reason, it does not reverse and the 5th gear is new clutch and clutch release, I do not know what the condition of the gearbox is
  • #9 16364722
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The issue of regulation?
The discussion revolves around issues faced after an engine overhaul of a 2002 VW T4 2.5 Diesel. The user reports that the engine does not start, with fuel reaching the pump but not activating the injectors. They seek assistance with a relay and fuse diagram, as the vehicle was missing these components upon purchase. Responses include inquiries about diagnostics, the function of Relay 109, and the glow plug indicator. Additional follow-ups mention problems with the gearbox, specifically regarding reverse and 5th gear functionality, and the condition of the clutch and gearbox is questioned. Suggestions include checking the activation of the fuel pump and ensuring proper assembly of components.
