Jeep Grand Cherokee WK 2008 - QuadraDrive II Service 4WD System Message & No Fault Codes
kubas10 24579 9
Why does my 2008 Jeep Grand Cherokee WK with QuadraDrive II display "SERVICE 4WD SYSTEM" at ignition even though no fault codes are stored?
The message is often caused by the 4WD control/module needing a reset or software reload, or by a module fault under the passenger seat behind the driver, rather than by a stored fault code [#20221205] You can try a home reset by switching the engine off and removing fuse no. 20 in the under-hood fuse box, the one marked FDCM EDIFF [#20221205] Start the car, drive about 5 m forward and then 5 m back, switch the car off, and put the fuse back in place [#20221205] After this procedure, the error disappeared and QuadraDrive II could be restarted [#20221205] If that does not help, the module may need a software reflash or replacement with a used/new unit with the amendments installed [#20221205]
  • #1 16387980
    kubas10
    Help: 42
    Rate: 1547
    Hello, after switching on the ignition in the kilometers display field appears SERVICE 4WD SYSTEM, the jeep has QuadraDrive II. No fault codes. What could be the failure? engine on the transfer case?
  • #2 16389090
    waldek1106
    Help: 6
    Rate: 59
    Maybe the diagnoscope is inappropriate ... is there communication with the 4WD system
  • #3 16390132
    kubas10
    Help: 42
    Rate: 1547
    Yes, there is communication with 4WD and no fault codes. MegaMacs 66 reading.
  • #4 16390151
    manta
    Help: 463
    Rate: 1533
    Gutek talks badly about it.
  • #5 17387759
    talar123
    Rate: 25
    I have the same problem I was able to do something about it
  • #6 17401342
    MaciekBra
    Rate: 48
    I also have this message. Do you think that with such a car you can drive a few kilometers to the service? Do you drive with this message? Do you have any strange car behavior - delicate vibrations, vibrations etc.?
  • #7 18490452
    Robert_Moro
    Rate: 24
    Hello. Someone coped with this problem? I have wk4 and a group I need your help ...
  • #8 18756839
    macias920
    Rate: 19
    is there a solution to this problem?
  • #9 18763006
    kubas10
    Help: 42
    Rate: 1547
    You go with it.
  • QuadraDrive II reset by pulling fuse 20
    #10 20221205
    PrzemSo
    Rate: 9
    I know this post is old but I had the same problem.
    The solution is to reset the electronics / upload new software to the computer module (the one under the passenger seat behind the driver) or replace it with a used / new module with installed amendments.
    You can do the reset yourself at home:
    1. with the engine off, find and remove fuse no. 20 in the electrical box under the hood (the one described as FDCM EDIFF);
    2. start the car and drive about 5 m forward and then 5 m back, turn the car off;
    3. put the fuse back in its place.
    after this procedure, the error in my car disappeared and it was possible to restart the Quadradrive II.
    Maybe it will help someone.
    Kisses,
    P.
The discussion revolves around a 2008 Jeep Grand Cherokee WK experiencing a "SERVICE 4WD SYSTEM" message without any fault codes. Users confirm communication with the 4WD system and share similar experiences. One suggested solution involves resetting the electronics by removing fuse no. 20, driving the vehicle briefly, and then reinserting the fuse, which reportedly resolved the issue for one user. Concerns about driving with the warning message and potential vehicle behavior, such as vibrations, were also raised.
