Jeep Grand Cherokee 4.7 - Erratic Oil Pressure Gauge & Check Gauges Light Issue
RYCHU555 15093 4
  • #1 16633700
    RYCHU555
    Hello everyone. I have a problem with Cherokee 4.7 - it's about the oil pressure gauge. It goes a bit crazy, sometimes it drops to zero and the "check gages" light comes on. After a while it returns to normal. Who can tell me something about this?
  • #2 16633788
    Heinzek
    Help: 554
    Rate: 494
    Check oil level.
    Connect the clock and check the current pressure. Maybe only the sensor "cheats".
  • #3 16634128
    RYCHU555
    Oil is a condition it started to happen when I poured oil. The oil is the same because I have some oil left. Previously, the state was between min and max so I wanted to top it up now is max and while driving the tip drops suddenly and returns in a moment.
  • #4 16961790
    novax
    Rate: 24
    Did you find a solution? I have exactly the same symptom after the last refill. I added to the max and it was 1/3 of the scale. Since then, the indicator goes crazy.
  • #5 17705873
    spider19447
    Rate: 27
    I have the same someone know something ??
