Citroen C2 1.4 HDI Brake Pedal Issue: Rear Stop Lamp, Sash & Registration Plate Lights Only
beavis1978 19035 8
  • #1 16389379
    beavis1978
    The problem is that when the brake pedal is pressed, only the 3 stop lamp lights up and the rear sash turns on and the rear registration plate lights up, but of course the feet do not light.
    It looks like an obvious mass problem.
    Does anyone have a schematic of installing this car or information about where is the common mass point for the wipers, alloys and registration plate?
  • #2 16389487
    boguslaw robak
    Help: 35
    Rate: 53
    Hi, yes, this problem probably with a lot of defective contacts plugs in the lamps at the beginning greetings.
  • #3 16389511
    beavis1978
    And what do the contacts of the lamp plug have (something that connects the "+" and "-" circuit with the light bulb) with the lack of mass in the circuit?
    Where are the mass points in this car?
  • #4 16389528
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    Boy, you probably have a problem with the tailgate beam and do not expect someone ready to give you a prescription. Did you check the tailgate beam ?? Finding the mass is a moment of work. First, check the basic parameters and then ask questions.
  • #5 16389533
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I would also put on the wires in a harmonica between the flap and the car's hut.
  • Measured missing ground at tailgate wiper motor
    #6 16391197
    beavis1978
    Gentlemen, it's not like when you do not light your feet, the first thing I do is sit in front of the computer and write a thread on the forum.
    The bundles in the tailgate and rear fenders at the lights have been checked. The measurements on the wiper motor show that there is no weight. I do not want to blindly poke up the upholstery in search of a mass point, so I asked a question on the forum about a diagram or information where the mass point is.
    I'm afraid it will be in front of the car.
  • #7 16391360
    emeryt2
    Help: 717
    Rate: 2302
    Fuses for stop lamps good? There are two, for the third lamp a separate one.
    There are two mass points for the rear stop lamps, each one common for one combined lamp, where you also have other lights. Are other lights working properly?
    Take out the lamp and see the common mass contact for the lamps and the thread to the ball.
    I do not think the mass point is in front of the car.
  • #8 16401437
    beavis1978
    Indeed, it is not mass.
    Where are the fuses from the stop lights in this vehicle?
    It turned out that these are two independent faults. The wiper and registration light have been repaired. There were upholstered these wires.
    The feet are still not working. I checked the pedal stop switch and it's OK. bulb lamps ok
    Where to find the fuses of these lights?
    According to the instructions there are two fuse boxes. Under the steering wheel and under the hood next to the battery. Unfortunately, none of these fuses are in any of them. in general there are no fuses for any lights in them, so I assume that there must be 3 fuse boxes. Where is she located?
  • #9 16403749
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    Well, you have like the bull shown F20 and F21 under the steering wheel.
    And under the hood you have to the other lights.
    Oh, German, bowing.
The discussion revolves around a brake pedal issue in a Citroen C2 1.4 HDI, where pressing the brake pedal activates only the stop lamps, rear sash, and registration plate lights, while the footwell lights do not illuminate. Users suggest potential causes, including defective contacts in the lamp plugs and issues with the tailgate beam. The author confirms that the wiring in the tailgate and rear fenders has been checked, and measurements indicate a lack of ground connection. The conversation also touches on the location of fuses for the stop lights, with users indicating that there are two independent faults and discussing the locations of multiple fuse boxes. The author seeks a schematic for the vehicle to locate the common ground points for the affected components.
