Renault Laguna 2 - Brake Pedal Protection & Stop Lights Issues: Fault Detection & Repair
FINIX_47 7677 12
How do I fix brake lights that stay on all the time after the brake pedal trim/cover fell off on a Renault Laguna 2?
The brake light switch is self-adjusting: with the pedal released it must press the switch so the lights go out, and when you press the pedal the plunger comes out so the lights turn on [#16762286] Pull the switch/plunger toward you until you hear it ratchet, then fit it back into the socket and release the pedal so it sets the correct position automatically [#16761911][#16762207] If the pedal still does not reach the switch after reinstalling the trim, compare it with another car or a mechanic to check whether the switch or its adjustment is wrong [#16762207][#16762095] The sound like a “mattress pump” and the pedal getting hard after several presses with the engine off is the brake servo losing vacuum, which is normal [#16762399]
  • #1 16761887
    FINIX_47
    Help: 24
    Hello, I have a request for you to locate my fault, repair my fault that I have had for several days. The situation is as follows: the protection on the brake pedal has fallen (a piece of the sleeve with the plate) since then, the stop lights are on for me all the time and the pedal itself with the rod from the (pump?) it takes him so much and the mushroom closes, the lights do not shine. What is the problem. [/at]
    leonov
    Help: 1039
    Rate: 2248
    FINIX_47 wrote:
    my protection on the brake pedal fell off (a piece of a sleeve with a badge)
    Then put it back on, and write the rest of the post again but IN POLISH.
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    If you put everything together correctly, then the stop automatics often have, let's say, preliminary adjustment (something like a rattle) on this spindle, I don't know if I am explaining what is going on (your automat may not have this adjustment, which should be checked) Try to pull this spindle towards you (you should hear a rattling sound, as if something is jumping, and it should come out). Then, by mounting the regulator in the socket, and releasing the brake pedal, the spindle sets the correct position by hand. yourself to make sure it is not pressed lightly as the wheels may brake over time.
  • #4 16762073
    FINIX_47
    Help: 24
    I put it back on, but the pedal is 10 mm too short, when the protection is on the pedal, it lacks this centimeter to press the stop light sensor button.
    Added after 4 [minutes]:
    nikusert: As I put this protection, it can only be put in one position, also it is put on correctly when I pull this rod from the vago? Because I do not know well how it is built and what is it called professionally, it will not damage it?
    nikusert
    Help: 699
    Rate: 1755
    Not seeing the machine, it is hard to say whether its mushroom is adjustable. Give it a close-up photo of the machine.
    andrzej20001
    Help: 1578
    Rate: 6669
    There is a push-in sensor all the way without adjusting the tit. If something is not kicked, the brakes are no joke with this pedal. Take a peek, for example, in a commission shop, at a mechanic in another, how it looks, take a photo with your cell
    leonov
    Help: 1039
    Rate: 2248
    But here something works the other way around, if the pedal does not reach the switch, it shouldn't light up after pressing STOP, right? and here it shines all the time, so how does it work? unless, on the contrary, the pedal presses the switch all the time and then releases it when pressed.
    andrzej20001
    Help: 1578
    Rate: 6669
    How does it work? classic, the pedal released and presses on the tit there are no lights, the pedal pressed on the tit comes out and shortens the pins and the lights are there.
    nikusert
    Help: 699
    Rate: 1755
    This is how stop automatics work.
  • #10 16762395
    FINIX_47
    Help: 24
    Exactly pressing the pedal releases the mushroom and the lights are shining, now it is like that I unscrewed the equalizing reservoir and pulled the brake pedal with all my strength, nothing leaking, nothing leaks, if I did it right I don't know, but for sure I know that the pedal presses a little mushroom so much that the lights go out, but it still needs a bit to close it completely, but I do not know if it has such a task and need or if it only has to turn off the lights and that's it, besides the margin, there is such a play on the pedal before the pump works. But I am surprised that without the ignition on, pressing the pedal works 3.4 times and the cover sounds like a mattress pump and stops. Unless this is normal and it should be so, the pedal is harder without ignition longer with the ignition faster also the pump is ok? I am asking you because I am a young driver, not a mechanic.
  • #11 16762399
    nikusert
    Help: 699
    Rate: 1755
    This sound (mattress pump as you have specified) is the sound of the servo. It is known that with the engine off, pressing the brake pedal several times makes the pedal harder.
  • #12 16762401
    andrzej20001
    Help: 1578
    Rate: 6669
    FINIX_47 wrote:
    with all my might pull the brake pedal up
    have these brakes repaired in the workshop! This is not a joke!
  • #13 16762449
    FINIX_47
    Help: 24
    I understand and I am aware that the brakes are not a joke, but if we buy shoes in a store and the shoelaces untie us, are we going to tie them? First, I have to regenerate two calipers at the back. But then I will think about the workshop after regeneration.
The discussion revolves around a malfunction in the brake system of a Renault Laguna 2, specifically concerning the brake pedal protection and stop light issues. The user reports that after a protective sleeve on the brake pedal fell off, the stop lights remain constantly illuminated, and the brake pedal does not fully engage the stop light sensor. Various suggestions are provided, including checking the adjustment of the spindle connected to the brake pedal, ensuring proper installation of the protective sleeve, and verifying the functionality of the stop light switch. The user expresses concerns about the pedal's length and its ability to activate the switch correctly. Additional advice includes consulting a mechanic for a thorough inspection and repair, emphasizing the importance of addressing brake issues promptly for safety.
TL;DR: If the pedal bumper falls off and leaves a 10 mm gap, the brake lights can stay on; “This is how stop automatics work.” [Elektroda, nikusert, post #16762329] Why it matters: Continuous brake lights drain the battery, mask real braking, and may indicate unsafe pedal or switch alignment. This FAQ is for Renault Laguna II owners who ask how to fix always-on stop lights and adjust the brake-pedal switch.
How does the Renault Laguna II brake‑light switch actually work?
At rest, the pedal holds the switch plunger in, keeping lights off. Pressing the pedal releases the plunger and closes the lamp circuit. This “normally closed when released” behavior often confuses owners during diagnosis. “This is how stop automatics work.” [Elektroda, nikusert, post #16762329]
Why are my stop lights on all the time after the pedal protector fell off?
The missing grommet shortens the effective pedal height by about 10 mm, so the plunger never gets pressed. The switch then reads “brake applied” continuously. Replace the pedal bumper or an equivalent spacer and recheck the switch engagement. [Elektroda, FINIX_47, post #16762073]
How do I adjust the brake‑light switch on Laguna II?
Some switches self‑set. Pull the spindle outward until it clicks. Fit the switch in its socket. Release the pedal so the plunger sets the gap. This ratchet action prevents light braking or constant lights. 1. Pull spindle. 2. Install switch. 3. Release pedal. [Elektroda, nikusert, post #16761911]
What is the ‘servo’ sound I hear when pumping the brake with the engine off?
That is the brake booster (servo) exhausting stored vacuum. After several presses, assist fades and the pedal stiffens. The behavior is normal during diagnosis and helps confirm vacuum integrity without starting the engine. [Elektroda, nikusert, post #16762399]
How many pedal presses should it take for the pedal to go hard with ignition off?
Expect roughly 3–4 presses before the pedal firms up as vacuum assistance depletes. A much higher or lower count suggests leaks or abnormal booster reserve. “Sounds like a mattress pump” accurately describes the exhaust noise. [Elektroda, FINIX_47, post #16762395]
Could misadjustment cause dragging brakes or premature wear?
Yes. If the switch or pedal stop leaves the pedal slightly applied, the system can preload and cause gradual brake drag. As one expert notes, ensure it is not pressed lightly, or wheels may start braking over time. [Elektroda, nikusert, post #16761911]
Which part should I inspect first when the stop lights won’t go out?
Inspect the pedal rubber/nylon bumper that contacts the switch, then the switch plunger alignment. A missing or displaced bumper creates a gap and leaves lights on. Restore the bumper before adjusting the switch. [Elektroda, FINIX_47, post #16762073]
Is there any adjustment on every Laguna II stop‑light switch?
No. Some switches push fully home without a separate screw, while others use a ratcheting spindle. If the design lacks adjustment, fix pedal geometry first, then replace the switch if necessary. [Elektroda, andrzej20001, post #16762207]
What’s the safe approach if the pedal feels wrong or geometry changed?
Do not drive until inspected. A mislocated pedal or incorrect free play risks poor braking and warning‑light confusion. “Have these brakes repaired in the workshop! This is not a joke!” [Elektroda, andrzej20001, post #16762401]
What is the brake‑light switch in simple terms?
It’s a small plunger‑type electrical sensor on the pedal bracket that turns the brake lamps on when released by the pedal. When the pedal returns and presses the plunger, it turns the lamps off. [Elektroda, andrzej20001, post #16762286]
How do I test the switch quickly without tools?
With ignition on, push the plunger manually. Lights should go off when depressed and on when released. If behavior is opposite or intermittent, replace or adjust the switch and check the pedal bumper. [Elektroda, nikusert, post #16762329]
My pedal has free play before the brakes bite. Is that normal?
Some free play is typical, but it must not hold the switch open unintentionally. Verify the bumper is present and the plunger is fully depressed at rest after self‑adjustment. [Elektroda, FINIX_47, post #16762395]
Can I drive while my stop lights stay on due to the switch?
Avoid driving. Constant brake lamps obscure real braking to drivers behind and drain the battery. Fix the pedal bumper and adjust or replace the switch first. [Elektroda, andrzej20001, post #16762401]
What tools or parts might I need for this repair?
You may need a replacement pedal bumper/grommet, a new stop‑light switch if worn, and basic trim tools. Visual confirmation and correct alignment matter more than special equipment for this task. [Elektroda, andrzej20001, post #16762207]
What edge case should I watch for after refitting the bumper?
If the switch is over‑extended, it may not self‑retract. Pull the spindle to reset the ratchet, refit, and let the pedal set the gap again. [Elektroda, nikusert, post #16761911]
