Best 1800W Vacuum Cleaners: AMICA VM 2041 Nortes Alternatives for Powerful Cleaning
pkrl5758 20925 16
How do I choose a vacuum cleaner with strong suction, and what are good alternatives to the Amica VM 2041 Nortes?
Don't choose by 1800 W alone; check the energy/performance label, especially vacuuming efficiency and dust re-emission classes, because wattage is mostly power taken from the mains and not suction [#16392419] For a flat and a few carpets, aim for at least class C for carpets, class A for hard floors, energy class A/B, and noise below 80 dB [#16393377] The Amica VM 2041 Nortes was criticized for class G carpet cleaning and class G dust re-emission, and its 30 l/s airflow was described as not especially high [#16392419] As alternatives, look at Zelmer models such as Aquos ZVC722SP or Jupiter ZVC425HT, which were suggested as better options [#16391086][#16392419][#16392911] Another reply noted that EU regulations make 1800 W less meaningful today and mentioned the Tefal TW6886 as an interesting model with spare-part availability [#16786230]
  • #1 16389542
    pkrl5758
    Rate: 10
    I am looking for a vacuum cleaner with a large engine power; today's can not cope with cleaning, because the maximum power is 700W and the older ones have at least twice as much.
    I found the AMICA Vacuum Cleaner VM 2041 Nortes, but it is 100% Chinese. I am getting paid if you can advise me about a better power?
    Greetings,
    Paul
  • #4 16391281
    Piotr2608
    Help: 851
    Rate: 4487
    Water because it uses a water filter that can be used interchangeably with standard bags.
    ZimTech Piotr Zimny
  • #5 16391586
    pkrl5758
    Rate: 10
    OK, so you recommend this model, because of the strong pull, among other things, right?
  • #6 16391594
    Piotr2608
    Help: 851
    Rate: 4487
    Tan is an example of a powerful vacuum cleaner. I wrote that you would look around the ZELMER brand.
    ZimTech Piotr Zimny
  • #7 16391615
    pkrl5758
    Rate: 10
    I like this model, I just looked for something that has a specific suction and extracts from the carpet various crumbs, sypses, etc.
  • #8 16391643
    Ryszard49
    Help: 312
    Rate: 1011
    Before you buy, read reviews:
    link
    For me, this advice, never again vacuum cleaners without sack and water.
  • #9 16391646
    Piotr2608
    Help: 851
    Rate: 4487
    I do not recommend reading reviews. This is ordinary shamr marketing and has nothing to do with reality. I warn. You can always advertise equipment - warranty law.
    ZimTech Piotr Zimny
  • #10 16391675
    pkrl5758
    Rate: 10
    I read. They are 2, they are positive.
  • #11 16392419
    dzi_dziuś
    Home appliances specialist
    Help: 341
    Rate: 1170
    You're looking at the wrong parameter. You are interested in suction power or efficiency class of vacuuming. Power 1800W is the power taken from the network (in large part converted into heat), and the turbine efficiency, housing design, etc., influences the pulling force, hence the 2000W vacuum cleaner can have 300W suction power (as decent), and a better-conceived model can have 330W at 1300W.
    E.g:
    http://www.zelmer.pl/dla-domu/odkurzacze/tradycyjne/ekspert-od-dywanow/jupiter-zvc425ht
    On the energy label you have given: class of C vacuum cleaning efficiency (as far as), class of vacuum hard floor cleaning efficiency A (super). And on such parameters I would concentrate, if there is no such card at all, the oil would buy the equipment.
    Amica:
    http://www.mediaexpert.pl/odkurzacze-standard...gclsrc=aw.ds&dclid=CIen8ZK_i9MCFUvJsgodJckC6A
    The efficiency class on G rugs, so much less, class A on the floors, but also the dust re-emission class G, that is, the anti-allergy wheel did not even stand.
    On this basis, you can choose a model for yourself, any company, although the 4-year Zelmer's warranty still tempts you.
    This aquos, despite the fact that it has a single engine, does not have a given card, but only an air flow of 30l / s, which is not a very high value.
  • #12 16392453
    pkrl5758
    Rate: 10
    Ok, could you give any specific models that have a strong suck? For me, it's black magic ....
  • #13 16392911
    dzi_dziuś
    Help: 341
    Rate: 1170
    As I wrote, you have to determine what will be vacuumed and choose the highest efficiency class for this application. In addition, if good filtration is important to you, you also need to pay attention to its class.
    Jupiter seems to have good parameters at a decent price, but look at other models and see the parameters I wrote about, you will surely find some compromise.
  • #14 16393110
    pkrl5758
    Rate: 10
    Vacuum will usually be a flat, or a few carpets plus floors.
    I do not know completely about these parameters, that's why I ask those who know each other.
  • #15 16393377
    dzi_dziuś
    Help: 341
    Rate: 1170
    Because you do not read what I write, I practically wrote everything, it was enough to open the first store and set filters.
    I set the store search (the first shop from the edge, so it is not any advertisement) the class of removing the carpet dust as A, here are the suggestions:
    https://mediamarkt.pl/agd-male/dom-czystosc-i...e-standardowe?filter%5B19463%5D%5B0%5D=729909
    For class B:
    https://mediamarkt.pl/agd-male/dom-czystosc-i...e-standardowe?filter%5B19463%5D%5B0%5D=729911
    For class C:
    https://mediamarkt.pl/agd-male/dom-czystosc-i...e-standardowe?filter%5B19463%5D%5B0%5D=729913
    Below Class C, I would not go down, the trade-off between price and efficiency may be parameters A - hard floors, C-carpets, energy class A / B and noise level not more than 80dB. I will not look for specific offers for you, finding the best models at the best prices is yours.
    https://mediamarkt.pl/agd-male/dom-czystosc-i...lter%5B19461%5D%5B0%5D=729923&filter%5B19463% 5D% 5B0% 5D = 729913
  • #16 16395111
    pkrl5758
    Rate: 10
    I read but I do not want to spend 6 hours finding the average quality of equipment that will allow me to vacuum my apartment without any problem. Last time just looking in this way I bought a crappy Zelmer, who has sucking on the level of kindergarten and I am looking for a vacuum cleaner that has a strong pull or high engine power. And that's it.
  • #17 16786230
    enforces
    Rate: 69
    If you want something reliable, you can always repair it and there is an option to buy parts, eg in the home appliances clinic, Tefal in the TW6886 model guarantees 10 years of availability of spare parts.
    Regarding 1,800 W of power - since changes in regulations in the EU, it is probably no use to suggest such powers. It's better to look at the performance label. The mentioned Tefal TW6886 on paper looks quite interesting.
The discussion revolves around finding a powerful vacuum cleaner, specifically seeking alternatives to the AMICA VM 2041 Nortes, which is noted for its Chinese origin. Participants recommend considering Zelmer vacuum cleaners, particularly the Aquos ZVC722SP and Jupiter ZVC425HT models, which utilize water filtration systems for enhanced suction power. The conversation emphasizes the importance of suction efficiency over mere wattage, suggesting that a vacuum's performance is better indicated by its efficiency class rather than its power rating. Users are advised to focus on models with high efficiency ratings for carpet cleaning and good filtration systems. The Tefal TW6886 is also mentioned as a reliable option with a long availability of spare parts.
