Comparing Wireless 2in1 Vacuum Cleaners: HOOVER RA22AFG 011 RHAPSODY vs DIRT DEVIL DD698-1 CAVALIER
Anai 9783 12
  • #1 17514982
    Anai
    I want to buy a vertical vacuum cleaner but I don't know what.
    Please help...
    Preferably 2in1.
    It is important that it has high power and good batteries and not like it is in the case of ergorapido where batteries fall very often.
    What do you think about
    Vacuum cleaner HOOVER RA22AFG 011 RHAPSODY
    https://mediamarkt.pl/agd-male/odkurzacz-hoover-ra22afg-011-rhapsody
    And
    DIRT DEVIL DD698-1 CAVALIER vacuum cleaner
    https://mediamarkt.pl/agd-male/odkurzacz-dirt-devil-dd698-1-cavalier
    https://obrazki.elektroda.pl/1983879800_1540396474.jpg
  • #2 17515135
    teskot
    Rest in Peace
    Help: 420
    Rate: 951
    Some time ago I bought a used Philips FC6161 from one of the electrode pads. I have never trusted this type of vacuum cleaner, but it honestly surprised me. I temporarily skip the fact that I have changed it quite hard; among others I replaced the lithium batteries (while increasing the voltage by about 15%). Nevertheless, it surprised me positively with the suction power and I think that this is due to the use of a hepa filter in the form of a cone (as in the case of car air filters). All in all, nothing new - the larger the filtering surface, the lower the flow resistance and the longer the cleaning time. Unfortunately, no filter of this size will work in vacuuming very small impurities (it clogs up quickly). Also cleaning up spilled ash or dust after drilling a hole in the wall for a dowel equals immediate filter cleaning. Here, generally disliked by me Philips surprised with a sensible filter shaking system. Just turns the mechanism, which bends and rapidly releases the filter fins causing dirt to fall off them.
    It's hard to say about working time on one charge. Original batteries were used and the vacuum cleaner worked effectively for up to 10 minutes. On lithium 21.6V 2.5Ah it works effectively about 20 minutes. I suppose the new ones will only have lithium batteries. A big plus when cleaning the carpet (for me it is only a walkway 2.5mx1m) n is an electric brush.
    In summary, I can speak in superlatives, realizing the limitations of wireless vacuum cleaners. First of all, I do not recommend buying online. It is worth going to the store and see the equipment in real life. If such information is available, I will say that the minimum engine power that guarantees some reasonable cleaning effect is 150-250W. And note that although current technology makes it possible, vacuum cleaners of this power are rare.
    If the manufacturer / seller does not provide this type of information, the power can be calculated to some extent. The battery voltage in V multiplied by its capacity in Ah will give the capacity in Wh. So if it is stated that the vacuum cleaner works after charging for half an hour, its power is twice the capacity expressed in Wh.
  • #3 17515375
    Anai
    10 minutes is a bit too short ...
    It is best that it lasts much longer, especially since these vacuum cleaners work very briefly on the electric brush.
  • #4 17515473
    Zbigniew 400
    Help: 283
    Rate: 792
    Look at Dyson
  • #5 17515964
    Anai
    Dysons too expensive, unfortunately ..
  • #6 17516047
    Zbigniew 400
    Help: 283
    Rate: 792
    But also a working time of about 20 minutes.
  • #7 17516127
    Anai
    And of those I gave none of?
    There is nothing worthy of attention apart from the dissonant?
  • #8 17516825
    teskot
    Rest in Peace
    Help: 420
    Rate: 951
    I haven't had contact with either brand, so I won't speak. But maybe it's better to look for something more dedicated to the European market? Bosch, Philips, LG I don't know, I shoot. Hoover is strongly associated with the USA where it comes from. You may also pay attention to operating costs. Filters are very expensive for both models. See if, for example, in a year when the battery will fall, you can buy it in reasonable money.
  • #9 17517056
    Anai
    I was also thinking about it ...
    I like ergorapido but I'm a bit afraid of reviews ...
    Added after 36 [minutes]:
    Now I have no idea what ?
  • #10 17517301
    teskot
    Rest in Peace
    Help: 420
    Rate: 951
    There are some Tefale looking reasonable on euro.com.pl. There is also Black & Decker and Sharp. Take a look at them, try to find more detailed technical data on manufacturers' websites.
  • #12 17951446
    teskot
    Rest in Peace
    Help: 420
    Rate: 951
    In my opinion a little weak, but for the price you can try. It's worth to get spare filters right away. On the site I saw that they are around 18 PLN. They may no longer be available in a year or two. This brush does not inspire my trust. The panels can be cleaned and cleaned, but for a rug or carpet it is a joke. The brush should have stiff bristles so that it penetrates between the fibers and sweeps away the dirt.
  • #13 17951479
    kost2
    Help: 18
    Thanks for the specific answer. As for filters, I thought that they would easily fit in with other models sold in Poland.
✨ The discussion revolves around the comparison of two 2-in-1 vertical vacuum cleaners: the HOOVER RA22AFG 011 RHAPSODY and the DIRT DEVIL DD698-1 CAVALIER. Users express concerns about battery life and suction power, with some mentioning the short operational time of around 10-20 minutes for similar models. Recommendations include considering alternatives like Bosch, Philips, LG, and Tefal, as well as the Dibea T6, which has received mixed reviews regarding its performance and filter availability. The importance of filter costs and maintenance is also highlighted, as well as the potential issues with battery longevity in certain models.
TL;DR: Expect about 20 minutes on a 21.6V/2.5Ah pack; "the larger the filtering surface, the lower the flow resistance." Choose 150–250W motors, check filter/battery costs, and test brush performance before picking HOOVER Rhapsody or Dirt Devil Cavalier. [Elektroda, teskot, post #17515135]
Why it matters: This FAQ is for shoppers comparing 2‑in‑1 cordless sticks who want reliable runtime, suction, and lower ownership costs.
Which is better: HOOVER RA22AFG 011 Rhapsody or Dirt Devil DD698-1 Cavalier?
Pick based on core metrics, not nameplates. Look for declared motor power near 150–250W. Multiply battery voltage by capacity to get watt‑hours. Expect roughly 10–20 minutes of effective cleaning. Prefer a motorized brush for rugs. Test suction and handling in-store before buying. These checks reveal more than promo specs. [Elektroda, teskot, post #17515135]
How long can I expect a cordless 2‑in‑1 to run per charge?
Realistic effective time is 10–20 minutes. Original packs in one user’s unit gave about 10 minutes. With 21.6V 2.5Ah lithium cells, it ran about 20 minutes. Plan cleaning in short sessions. [Elektroda, teskot, post #17515135]
Do motorized brushes drain the battery faster?
Yes, users report shorter runtime when using the electric brush. Expect noticeably briefer sessions with the brush engaged. [Elektroda, Anai, post #17515375]
Are HEPA cone filters worth it on stick vacuums?
They help stick vacs keep suction because of large surface area. As one user put it, “the larger the filtering surface, the lower the flow resistance.” Avoid vacuuming ash or drilling dust; it requires immediate filter cleaning. [Elektroda, teskot, post #17515135]
How can I estimate real motor power from the spec sheet?
Use this quick method:
  1. Multiply battery voltage (V) by capacity (Ah) to get watt‑hours (Wh).
  2. Use stated runtime. For 30 minutes, average draw ≈ 2 × Wh.
  3. Compare to 150–250W. Closer to that range, stronger real suction. [Elektroda, teskot, post #17515135]
Should I buy online or test in-store first?
Test in-store before ordering. Hands-on checks reveal suction, ergonomics, and brush effectiveness. Online specs rarely show the whole picture. [Elektroda, teskot, post #17515135]
What operating costs should I check before buying?
Check filter prices and battery replacement availability. One user found filters very expensive for HOOVER and Dirt Devil. Make sure a replacement battery is purchasable within a year. [Elektroda, teskot, post #17516825]
Which EU‑focused brands are practical alternatives?
Look at models aimed at the European market. Suggestions included Bosch, Philips, and LG. Local support often improves parts availability. [Elektroda, teskot, post #17516825]
Any other budget options to research?
Users also suggested Tefal, Black & Decker, and Sharp. Check manufacturer sites for detailed specs before deciding. [Elektroda, teskot, post #17517301]
Is the Dibea T6 good enough for small flats?
It is a little weak, but acceptable for the price. Buy spare filters immediately; they cost around 18 PLN. The included brush suits panels but disappoints on carpets. [Elektroda, teskot, post #17951446]
Should I buy spare filters up front?
Yes. Stock filters early, especially for budget brands. They may be unavailable after a year or two. This small spend avoids downtime. [Elektroda, teskot, post #17951446]
Any gotchas when vacuuming ash or drilling dust?
Avoid it. Such fine dust clogs the filter immediately and forces cleaning. Expect to stop and clean the filter right away. [Elektroda, teskot, post #17515135]
