[Solved] Amica VM3043 Vacuum Cleaner: Loss of Suction Power After Few Uses - Filter Replacement Ineffective
Eidems 27636 12
Why does my Amica VM3043 vacuum cleaner lose suction after a few uses, and why doesn’t replacing the filter help?
The suction loss is most likely caused by the inlet/filter assembly clogging up, and on this model the intake EPA12 filter needs to be cleaned properly rather than just blown out. The EPA12 filter also has a seal that affects the vacuum’s tightness, so removing it makes suction weaker because air is drawn in from the sides [#17872387] The thread’s original poster reported that after rinsing the intake filter twice in warm water and letting it dry, the vacuum returned to full power [#17874120] The manufacturer’s instructions apparently specify cleaning the intake filter and replacing only the outlet filter every 6 months [#17874120]
  • #1 17871330
    Eidems
    Help: 83
    Rate: 253
    Hello. I bought an Amica VM3043 vacuum cleaner, my friend also bought it at the same time. After the purchase, the vacuum cleaner vacuumed very well, had power, easily lifted the carpet. After a few uses, the vacuum cleaner has no power. Cleaned filters, blew everything out with compressed air, nothing. A friend had the same thing, the vacuum cleaner went to the service - they said that the filters needed to be replaced (although after a few vacuuming they were not bad), after replacing the same. Has anyone had the same problem? Everything checked several times and the vacuum cleaner has no power. There are many similar comments on the internet, I don't know if there is anything else I can do?
    Borutka
    Help: 125
    Rate: 414
    Eidems wrote:
    same after replacement.
    So there is no thrust right away, or again after a few vacuumings?
    Turn on the vacuum cleaner without a filter and evaluate the draft. If the draft without the filter is good, then the filter is clogged again and unless it is washable, it cannot be restored to newness by blowing it out.
  • #3 17872193
    Eidems
    Help: 83
    Rate: 253
    Borutka wrote:
    Turn on the vacuum cleaner without a filter and evaluate the draft. I think that the filter is clogged and unless it is washable, it is impossible to restore it with a new filter by blowing it out. Bagless vacuum cleaners with such a principle of operation, unfortunately, do.
    I checked it, without the filter it's even worse
  • #4 17872210
    Borutka
    Help: 125
    Rate: 414
    Well, if possible, run it without the dust container at all. Evaluate engine speed and work and wind. Maybe something in the container is clogged. After that, it will only find the engine. Although it is probably unlikely - maybe the turbine making the thrust is not tightened and slips on the rotor.
  • #5 17872219
    Eidems
    Help: 83
    Rate: 253
    Checked again, without a filter, the vacuum cleaner does not pull at all. The container is pulled out, the engine is running, the speed control works, I put my hand on it very weakly, I feel that it is pulling. I can buy a new filter, only if after a few uses the filter would have to be replaced (PLN 50 to spend every 2 months is probably not an agreement, a vacuum cleaner costs PLN 200). Regards
  • #6 17872252
    rnb_bolii
    Help: 635
    Rate: 1177
    Filter fault. These are the charms of bagless vacuum cleaners that I am not a fan of.
    Clogged crevices. I do not know if you can soak this filter with water, but I once laboriously cleaned the slots under a stream of water in another vacuum cleaner. I dried it and the suction came back.
  • #7 17872354
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    Wait a minute, if a vacuum cleaner without filters still has low suction power, then something is wrong with the turbine / motor. I assume we're blowing off the warranty, which is kind of fictitious anyway from what you're writing. Therefore, I would look inside and check, first of all, whether the turbine is permanently mounted on the motor axis and whether the seal between the turbine and the housing adheres well, whether the rubber / foam or whatever is there has not spilled. And that all housing seals are in contact with each other. I had a case years ago that Zelmer Wodnik lost the tightness between the tank and the cover and the effect was as above. Parameters such as vacuum pressure and air flow should also be distinguished.
    rnb_bolii
    Help: 635
    Rate: 1177
    On the epa12 filter there is a seal that connects the tightness of the container and the vacuum cleaner. Removing the filter causes air to be sucked in from the sides and therefore the suction is weaker. Let the author confirm or take a few photos of the filter from both sides..
  • #9 17872912
    Eidems
    Help: 83
    Rate: 253
    That's exactly how it is.
  • #10 17872919
    Borutka
    Help: 125
    Rate: 414
    I understood that you have two filters. Since a vacuum cleaner without a filter (without a frame) does not work, I suggest sacrificing one filter and punching a paper insert in it so that it does not resist the air. If it still won't pull, then the only thing left to check is the engine. Since the vacuum cleaner is under warranty, and the possibility of self-repair of the engine is small, I suggest not to disassemble the housing hastily.
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    This vacuum cleaner?
    • vm3041-1190215.pdf (890.89 KB) You must be logged in to download this attachment.
  • #12 17874120
    Eidems
    Help: 83
    Rate: 253
    Yes, the vacuum cleaner. Out of curiosity, I downloaded the user manual, an excerpt from it is included below. An interesting fact: the manufacturer provides an interval for replacing the outlet filter (every 6 months) and only cleaning the inlet filter (very strange). According to the instructions, I rinsed the intake filter twice in warm water (previously only with compressed air). After drying it and putting it in the vacuum cleaner, it finally came back to life and pulls like crazy ;) . The exhaust filter has been blown (it is like new). Unfortunately, the construction of the vacuum cleaner is very weak, because such an inlet filter will have to be cleaned every 2/3 of use, and replaced once in a while. The container gets clogged very quickly, after the second vacuuming you have to clean it. But for a vacuum cleaner for PLN 200, I do not require "miracles". Regards
    Amica VM3043 Vacuum Cleaner: Loss of Suction Power After Few Uses - Filter Replacement Ineffective [/text]
  • #13 17941270
    Eidems
    Help: 83
    Rate: 253
    Filter to replace, close.
The Amica VM3043 vacuum cleaner experiences a significant loss of suction power after a few uses, despite initial strong performance. Users have attempted cleaning and replacing filters, but these measures have proven ineffective. Suggestions include testing the vacuum without filters to assess motor performance, checking for clogs in the dust container, and ensuring the turbine is properly mounted. One user found that rinsing the intake filter improved suction, although the vacuum's design necessitates frequent cleaning of the filter and dust container. The manufacturer recommends replacing the outlet filter every six months while only suggesting cleaning for the inlet filter, which has raised concerns about the vacuum's maintenance requirements.
TL;DR: Most VM3043 suction loss comes from a clogged, washable inlet filter; the outlet filter is replaced every 6 months. After rinsing and drying, it "pulls like crazy." [Elektroda, Eidems, post #17874120]
Why it matters: This FAQ helps Amica VM3043 owners fix weak suction after a few uses, fast.
Why did my Amica VM3043 lose suction after a few uses?
The inlet (pre‑motor) filter clogs quickly with fine dust. Blowing it out often isn’t enough. Rinse the inlet filter in warm water, dry completely, and reinstall. Users report full suction returning after proper washing. Empty the container and clear any blockages during this maintenance. [Elektroda, Eidems, post #17874120]
How often should I clean or replace the filters on the VM3043?
Clean the inlet filter every 2–3 uses, or whenever suction drops. Rinse with warm water and dry fully. Replace the exhaust (outlet) filter about every 6 months, per the manual excerpt. Replace the inlet filter if washing no longer restores airflow. [Elektroda, Eidems, post #17874120]
Why is suction weaker when I remove the EPA12/inlet filter?
That filter includes a perimeter seal that completes the airflow path between the container and vacuum body. Removing it lets the motor pull unfiltered side air, reducing nozzle suction. Keep the filter fitted when assessing performance. [Elektroda, rnb_bolii, post #17872387]
How do I clean the Amica VM3043 inlet filter correctly?
Do this when suction drops:
  1. Remove the inlet filter and rinse gently in warm water until the water runs clear.
  2. Let it dry completely; do not reinstall while damp.
  3. Refit the filter and container; test suction and empty the bin. Many owners report full recovery after this rinse‑and‑dry process. [Elektroda, Eidems, post #17874120]
Is the inlet filter actually washable, or should I only blow it out?
Wash it. Compressed air often leaves fine dust embedded in the pleats. Rinsing in warm water, then fully drying, restored strong suction in user tests. “It finally came back to life and pulls like crazy” after washing. [Elektroda, Eidems, post #17874120]
Can I run the VM3043 without the dust container or filter to diagnose suction loss?
You can run it without the dust container to evaluate motor speed and airflow at the intake. If airflow remains weak, focus on the motor, turbine coupling, or internal seals rather than the bin. [Elektroda, Borutka, post #17872210]
How do I check if the motor or turbine is the problem instead of the filter?
If suction stays low with clean filters and an empty bin, inspect the turbine’s mounting and all housing seals. A poor turbine–housing seal or tank–cover leak collapses vacuum. “If a vacuum cleaner without filters still has low suction power, suspect the turbine/motor.” [Elektroda, teskot, post #17872354]
What maintenance costs should I expect for this model?
Plan for about PLN 50 per replacement filter. The vacuum itself cost around PLN 200 at purchase. Washing the inlet filter extends life and reduces replacements, but budget for a new one when washing no longer works. [Elektroda, Eidems, post #17872219]
New filters didn’t fix it—what should I do next?
Wash the inlet filter in warm water, dry it thoroughly, and test again. Ensure the container and air channels are clear. This routine has restored strong suction when replacements alone didn’t help. [Elektroda, Eidems, post #17874120]
Does the dust container clog quickly and affect suction?
Yes. The container’s channels accumulate dust fast, reducing airflow and suction. Owners report needing to clean the container after the second vacuuming. Empty the bin frequently and wipe channels to keep performance stable. [Elektroda, Eidems, post #17874120]
What seals or leak points should I inspect if suction remains low?
Check the turbine‑to‑housing seal, all housing interfaces, and the tank‑to‑cover joint. Degraded foam or rubber reduces tightness and collapses vacuum pressure. Reseat or replace compromised seals to restore airtightness. [Elektroda, teskot, post #17872354]
What’s an edge case where suction won’t return after cleaning and new filters?
A turbine slipping on the motor shaft or failed seals can prevent pressure build‑up. Airflow stays weak despite normal motor speed. Inspect mechanical coupling and sealing surfaces, or pursue warranty service if you can’t disassemble safely. [Elektroda, Borutka, post #17872210]
Any quick tip from experienced users about bagless vacuums like the VM3043?
Clean pleated filters under running water, then dry thoroughly, and expect more frequent upkeep than bagged models. As one member says, “These are the charms of bagless vacuum cleaners.” [Elektroda, rnb_bolii, post #17872252]
