SSD Drive Hangs: ADATA Ultimate SU800 128GB, SATA 3 Interface, ASUS M5A78L-M LX3 Motherboard
Darkman1999 10479 10
Why does an ADATA Ultimate SU800 128GB SSD freeze for 20 seconds to 1–2 minutes on an ASUS M5A78L-M LX3 SATA 2 motherboard, and how can I fix it?
No, those long freezes are not normal, and the thread points to a controller/driver problem rather than the SATA 2 speed limit [#16390129] The SSD’s SMART data was reported as okay, and a benchmark screenshot was requested to help diagnose the issue [#16390129][#16391062] The drive had been running in IDE mode at first, and the problem was eventually solved by installing the AMD SATA Controller drivers for the 700 Series chipsets [#16390986][#16391955] After installing those drivers, the SSD worked normally again [#16392198]
  • #1 16390100
    Darkman1999
    I have an SSATA ADATA Ultimate SU800 128GB drive, which has the recommended SATA 3 interface, and my motherboard ASUS m5a78l-m lx3 has SATA 2, this translates into a drop in performance, but is it normal that the disc catches the freeza for 20sec to 1-2 min?
    Is it possible to fix it somehow?
  • #2 16390129
    Kasek21
    Help: 4981
    Rate: 3547
    Darkman1999 wrote:
    but is it normal that the disc catches the freeza for 20sec for 1-2 min?
    No.
    What does the SMART drive look like?
  • #3 16390216
    Darkman1999
    SMART is okay
  • #4 16390641
    sylweksylwina
    Help: 1882
    Rate: 2355
    He can give, and interpretations leave us.
  • #5 16390941
    Darkman1999
    SSD Drive Hangs: ADATA Ultimate SU800 128GB, SATA 3 Interface, ASUS M5A78L-M LX3 Motherboard SSD Drive Hangs: ADATA Ultimate SU800 128GB, SATA 3 Interface, ASUS M5A78L-M LX3 Motherboard
  • #6 16390982
    sylweksylwina
    Help: 1882
    Rate: 2355
    You do not see anything disturbing in SMART. Has the computer been used previously with another disk and the problem did not occur?
  • #7 16390986
    Darkman1999
    The computer worked with HDD and such problems did not occur. I will add from the disk normally. Worked at the beginning in the IDE mode but z.tego.co.wiem AHCI is the basis for SSD
  • #8 16391062
    Dra98
    Help: 1321
    Rate: 1076
    I am asking for a screen from the AS SSD Benchmark test.
    In the CDI you can choose hide the serial number.
  • #9 16391914
    Darkman1999
    The test made under the IDE, under the AHCI could not cope with the computer caught the suspension after the suspension
    Added after 15 [minutes]:
    Unless you install the AMD RAID / AHCI drivers for Win7, maybe they will work on Win 10?
    As for now the drive works in IDE mode normally
  • #11 16392198
    Darkman1999
    I am sorry, I will remember for the future.
    The problem has been solved today, after installing the SATA Controller controllers from AMD for the 700 Series Chipsets.
    Thank everyone for help :)
The discussion revolves around performance issues with an ADATA Ultimate SU800 128GB SSD connected to an ASUS M5A78L-M LX3 motherboard, which supports SATA 2, leading to potential performance drops. The user reports the SSD freezing for 20 seconds to 1-2 minutes. Initial checks of the SMART data show no issues, and the SSD was previously used in IDE mode. The problem was resolved after installing the appropriate AMD SATA controller drivers for the 700 Series Chipsets, which improved the SSD's performance under AHCI mode.
