[Solved] Compressor - What to use to seal the threads in a compressor?
nowy.zielony.pczątku 15162 10
What should I use to seal the threaded connection in a compressor manifold?
Use an anaerobic thread sealant, preferably a weak or medium-strength one, rather than strong compound; it will seal pneumatic threads and still allow disassembly later [#16392414] A specific example mentioned is Loctite 4087, and another user noted that blue Drei Bond also works for pneumatics [#16392196][#16392414] It does not have to be Loctite—any similar anaerobic glue should do [#16392414] Small 5–10 g tubes are enough for one thread, and people reported prices around 10–20 zł in supermarkets/market stores [#16392250][#16392266] One user later confirmed that a regular Castorama thread glue also worked and did not leak [#18597528]
  • #1 16391933
    Rate: 43
    I don't know if it's a good department. If necessary, please transfer. The question as in the title, what to use to seal the thread in the compressor (marked in yellow). I broke it red and now I have to change the whole kit, this splitter. From what I noticed, it is sealed with some yellow glue (it looks like this). I'm afraid that the traditional hemp method may damage this manifold by pressing the thread inward. And the Teflon tape may not demand as it was with what was marked in red.
  • #2 16392152
    mychaj
    Help: 214
    Rate: 941
    If you do not like hemp and Teflon - you are left with: glue or thread string (recently fashionable in supermarkets).
  • #3 16392173
    Rate: 43
    Any specific glue? Because it is intended for pipes from PLN 100 from what I have seen.
  • #5 16392250
    mychaj
    Help: 214
    Rate: 941
    In supermarkets, 10g tubes are 15/20 zeta and they are perfectly fine.
  • #6 16392256
    Rate: 43
    Krzysztof Kamienski wrote:
    PS. Not PLN 100, but PLN 38!
    Give a link where they sell for PLN 38.
  • #7 16392257
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @new.green.from And even on Alle ....... Fr.
  • #8 16392266
    mychaj
    Help: 214
    Rate: 941
    A tube of 5- 10 grams is enough for one thread.
  • #9 16392344
    Rate: 43
    There is no loctite 5776 on the Allegro as it is loctite 577 for 50 PLN and loctite 5776 is available as mentioned before from 100 PLN Link
    Well, unless it's the same as I doubt. Maybe similar but not the same.
    mychaj
    Help: 214
    Rate: 941
    It does not have to be Loctite - just anaerobic glue (many manufacturers) and from the weak or medium series (I use the blue drei bond also for pneumatics), do not use strong ones because if you have to unscrew it, you will soon break the 10/50 gram containers (for all or marketach techniqolla) at 10/20 zeta.
  • #11 18597528
    Rate: 43
    I bought some regular castorama thread glue and it actually works, nothing lets through. Thanks for the advice
The discussion revolves around sealing threads in a compressor, particularly after a component failure. Users express concerns about using traditional hemp or Teflon tape, suggesting alternatives like anaerobic glue. Specific recommendations include using Loctite products, particularly Loctite 577 and Loctite 4087, as well as other brands of anaerobic glue. Users mention the availability of these products in various price ranges, with some finding effective solutions at local supermarkets. The consensus is to avoid strong adhesives to facilitate future disassembly.
