Needed Glue for Thin Polystyrene & Rubber Illusionist Instrument - Model Glue Recommendations
apiotlis 15873 11
  • #1 16536421
    apiotlis
    I am an illusionist, I make a small instrument made of polystyrene and rubber. The elements are very thin and complicated. I need a glue that glues the parts well and firmly. It is important that it does not dry too fast so that I have time to spread it over the entire surface of the element, and then connect it thoroughly. Maybe some model glue? Please help :)
  • #2 16536469
    stanislaw1954
    Help: 2003
    Rate: 4624
    Perhaps the cork adhesive - "cola -cork fc". It is similar to butaprene gum for rubber and leather. It can be glued with a cork stopper, but also, for example, plastic slats for walls or corks. For example, it is used with a brush, it waits until it evaporates a bit, if it does not take on the fingers, it presses tightly and already.
  • #3 16536563
  • #5 16538296
    E8600
    Help: 529
    Rate: 2493
    I have a bad feeling about this. I do not believe in magic :) Seriously, only 2 solutions come to me either by gel cyanoacrylate in the gel + activator or some UV-curing adhesive such as UV-locus glue loca used for gluing contacts in phones.
  • #6 16538308
    1 PAWEL
    Help: 674
    Rate: 1364
    I recommend cyanoacrylate adhesive in TESA 57041 gel with activator
    or
    cyanoacrylate adhesive, rare Bond. I was gluing HIPS.
    Apply the adhesive on one surface and press immediately. The thinner the layer, the faster the binding. Surfaces must be dry and clean.
    Unfortunately, it binds quickly.
    And http://www.loctite.pl/kleje-utwardzane-wiatem-6479.htm
  • #7 16539210
    telecaster1951
    Help: 829
    Rate: 818
    odalladoalla wrote:
    Every glue that contains benzene and acetone falls off.
    There is no benzene in any glue on the market!
    odalladoalla wrote:
    Both of them grind polystyrene in the form of "polystyrene", destroying the surface and "evaporating".
    Do you see the difference between polystyrene and styrofoam?
    odalladoalla wrote:
    It is difficult to stick rigid and brittle (polystyrene), with elastic and soft (rubber).
    Banally easily.
    E8600 wrote:
    Gel Cyanoacrylate adhesive + activator
    Why do you need an activator? For rubber and PS? It sticks perfectly.
    There is no such glue. In any case, once you connect this chapel. You can only slightly improve.
    A purely technical matter. A rigid or flexible connection? The joint is to be visible?
    For rigid joints:
    Cyanoacrylate. You clean both surfaces, cover one of them with a thin layer of glue (as thin as possible) and squeeze tightly.
    An epoxy resin. The best two-component. You mix resin with hardener. You cover one surface (cleaned of course) and press the other. After 48 hours, you will not tear.
    For flexible joints:
    Butapren. You distribute on the rubber and wait for partial drying (it must stick to your finger). Then you press the second element. After 24 hours it is stuck together.
  • #8 16540760
  • #9 16540785
    mariuszp19
    Help: 310
    Rate: 408
    I use LOCTITE 406 to connect this type of material. The combination is extremely durable. I glued together the rubber orings and when I tried to burst it broke off in another place, and the joint resisted. Rubber for "plastic" also does not make a problem.
  • #10 16541072
    telecaster1951
    Help: 829
    Rate: 818
    odalladoalla wrote:
    I notice the differences between the chemical composition and the physical FROM the implementation.
    Cool, but who wrote here about polystyrene?
    odalladoalla wrote:
    Have you tested frost resistance, tensile strength, "tightness", 4 times a month certified rubber material samples?
    I do not know, do you want my diploma to see?
    odalladoalla wrote:
    Practices would fail.
    And this is what someone who says about polystyrene, says about polystyrene, says ... They taught me that every polymerist has to get rid of this association as soon as possible.
    I undressed the ripper and put it back together again. The dumbbells are hanging on the cabinets, and the "tightness" or barrier properties I researched with many techniques. Both for rubber and thin film blends. Forgive me, but it can be a drain pipe and not a vulcanizer ...
    odalladoalla wrote:
    And keep the features of both materials used?
    !? I apologize very much, but how do you want to preserve the properties of both glued materials in the joint? The weld and diffusion area of the adhesive have their properties, and the materials outside of this area.
    odalladoalla wrote:
    Good luck with 'Resin' adhesives
    You made me laugh.
    PMMA glued to O-Ring X-ray (you want the composition of the mixture - I did it myself) with a two-component resin. He keeps two years as of now. PVC glued to stainless steel. For 3 years without problems. It all depends on what the author wants to get
    The best cyanoakyl I know.
  • #11 16546146
  • #12 16546313
    mariuszp19
    Help: 310
    Rate: 408
    Adamcyn wrote:
    mariuszp19 wrote:
    I use LOCTITE 406 to combine these types of materials.
    "SG 15 WIKO adhesive = LOCTITE 406 "
    You confirm?
    I do not know how this SG 15, but at one time we tried to break the adhesive joints and Super Glue compared to LOCTITE 406 fell out thin. I emphasize, I do not remember if it was this SG 15. You would have to read the characteristics sheets of both adhesives and compare them.
✨ The discussion revolves around finding an appropriate adhesive for a thin polystyrene (HIPS) and rubber instrument used in illusionist performances. Recommendations include cork adhesive ("cola-cork fc"), cyanoacrylate adhesives (such as TESA 57041 gel and LOCTITE 406), and epoxy resin for rigid joints. Users emphasize the importance of a slower-drying adhesive to allow for proper application and alignment. Concerns are raised about the compatibility of adhesives with both materials, with suggestions for flexible joints using butapren. The conversation highlights the need for careful selection based on the properties of the materials involved.
