NVIDIA control panel - explanation of functions for program setting.
vygi 12249 5
  • #1 16393952
    vygi
    Hey.
    I am at the stage of fps fighting, I try to set the functions to game settings for maximum performance. I do not know it completely, so do not tell me that to move my head and logic; I look into forums, watch guides and everyone else says. I am asking for a little explanation of individual functions, i.e. which will actually increase the number of fps:
    1. multi-screen acceleration / various graphics processors: multiscreen mode whether jednoekranowy ?
    2. the maximum number of pre-rendered frames: 1 . 2 . 3 whether 4
    3. smoothing the edges - transparency: disable whether multiple sampling
    4. anisotropic filtering: disable . 2x . 4x . 8x whether 16x
    5. texture filtering - negative compensation of the level of detail: allow whether lock
    Thanks.
  • #2 16393966
    Kasek21
    Help: 4981
    Rate: 3547
    Set under application control and graphic settings change in the game itself.
    Of course, smoothing the edges or Filing should be turned off.
    What game is this? What is this computer configuration?
  • #3 16393972
    vygi
    The graphic settings directly in the game are set to the lowest, I just want to know which option in the functions will bring the most performance.
    Computer configuration, or?
  • #5 16398685
    CzakiBest
    Help: 11
    Rate: 30
    Turn off things like V-sync, Anti Aliasing, TXAA, FXAA, MSAA, HBAO +, - anisotropic filtering you can have 16 does not draw frames. Rendered frames 1. Give a picture of the graphic settings of the game I will tell you what to turn off and what to leave to have a good performance. Panel, Nvidi do not have fun because as a colleague above wrote everything you set and so from the panel of the game in the panel Nvidi is automatically rearranged.
