Low FPS in CS: GO with i5-4570, 8GB RAM, NVIDIA GTX 1050: New PC Performing Worse than Old
ahaaaaa 12999 12
Why do I get only about 30 FPS in CS:GO on an i5-4570, 8 GB RAM and GTX 1050 PC?
Check for FPS caps and system settings: update the GTX 1050 driver, disable V-Sync, and make sure CS:GO is not limited by an `fps_max` command such as `fps_max 300` [#16912336] [#16912364] [#16912569] Also verify temperatures with HWMonitor, because overheating can reduce performance [#16912569] In CS:GO video options, make sure multicore rendering is turned on [#16921983] If you are on Windows 10, disable Xbox DVR/Game Bar in Settings, which was suggested as another possible cause of low FPS [#17244802]
  • #1 16912313
    ahaaaaa
    Hello, what could be the problem, I have a new computer, such specifications
    Intel (r) Core (tm) i5-4570 3.20 3.20
    8.00 GB RAM
    Nividia GeForce GTX 1050
    The point is that I have very little FPS for such a computer. In CS: GO I have 30 FPS, well something is wrong; / I will add that I had a weaker computer and I had 60 FPS, I don't know what's going on.
  • #2 16912336
    Graba211
    Drivers Updated?
    Temperatures ok?
    Vertical sync turned off?
  • #3 16912340
    ahaaaaa
    And how can I check it? because I am a little dark in these matters
    I was looking at youtube test 200-300 fps; /
    Vertical synchronization disabled
  • #4 16912364
    Graba211
    Graphics card drivers enter the geforce experience and there you have options to check for updates.
    You can use the rest of your computer with SlimDriers or IObit Driver Booster.
    Vertical synchronization - In the NVIDIA Control Panel
  • #5 16912393
    ahaaaaa
    I'm doing it right now! :)
    and I have to add that Brother has the same computer and has 200-300fps ;) on mirage
    Somewhere here ???
  • #6 16912433
    Graba211
    w Geforce Experience
  • #7 16912449
    ahaaaaa
    I checked and I'm getting something :)
    Added after 7 [minutes]:
    40%
    Added after 19 [minutes]:
    I downloaded, see how it goes now ;)
    unfortunately still the same :(
    35 fps on the menu
  • #8 16912569
    Graba211
    there is also a command to unlock fps (fps_max e.g. 300) but this probably won't fix the problem.
    scan the MBAM Andwcleaner computer. And Temp are ok? You can check them with the HWMonitor program.
    This is where my ideas end.
  • #9 16912572
    ahaaaaa
    I have already done this command and temperatures are ok but I will check thanks for all the advice
  • #10 16921983
    Gumipoliku
    But how is that? Do you check the amount of fps in the menu? Max. the number of fps in the menu is identified by another command. Get into the game normally and check there.
    In the in-game video options, of course, do you have multicore rendering turned on?
  • #11 16924064
    MŁODYELEKTRONIK15
    Pupil
    enter the computer-properties classify the system then enter the device manager and update the drivers for the graphics card, monitor and processor and it will be fine ;)
  • #12 17244802
    mieszko09
    Do you have windows 10? Go to settings and disable XBOX DVR in the game, this is a service associated with xbox. Should help.
  • #13 17423188
    chruscik1906
    I am in the same situation as a friend; / i5 7400
The discussion revolves around a user experiencing low FPS (30 FPS) in CS: GO on a new PC with an Intel Core i5-4570, 8GB RAM, and NVIDIA GTX 1050, despite previously achieving 60 FPS on an older, weaker system. Participants suggest checking and updating graphics drivers via GeForce Experience, ensuring vertical sync is disabled, and monitoring system temperatures with HWMonitor. Additional recommendations include disabling Xbox DVR in Windows 10, enabling multicore rendering in-game, and using commands to unlock FPS. The user confirms they have checked temperatures and attempted various solutions but continues to experience low performance.
TL;DR: Fix CS:GO stutter by setting fps_max 300 and checking temps; "scan the MBAM Andwcleaner computer." Update drivers, disable V‑Sync, enable multicore, and turn off Xbox DVR. [Elektroda, Graba211, post #16912569]
Why it matters: This FAQ helps i5‑4570/GTX 1050 owners diagnose why a new PC gets lower FPS than expected.
Why is my new i5‑4570/GTX 1050 only getting ~30–40 FPS in CS:GO?
Common culprits are V‑Sync on, old drivers, disabled multicore rendering, Game DVR overlays, or malware. One user even saw 35 FPS only in the menu. Start by testing an offline match and monitoring temps and usage. Compare with a clean boot and no overlays. If FPS improves after disabling extras, re‑enable features one by one to find the bottleneck. [Elektroda, ahaaaaa, post #16912449]
How do I correctly update my NVIDIA graphics driver?
Use GeForce Experience to check for updates, download, and install the latest Game Ready driver. Choose a clean install if prompted. Reboot after installation. Avoid third‑party driver packs for the GPU; stick to NVIDIA’s tool for reliability. "Graphics card drivers enter the GeForce Experience and there you have options to check for updates." [Elektroda, Graba211, post #16912364]
How do I disable V‑Sync for CS:GO?
Open NVIDIA Control Panel. Under Manage 3D Settings, add csgo.exe and set Vertical Sync to Off. Also verify in-game V‑Sync is disabled. This removes the 60 FPS lock from sync to your display’s refresh rate. Test again in a live match. [Elektroda, Graba211, post #16912336]
What is fps_max and what value should I use?
fps_max is CS:GO’s built‑in frame limiter. Open the console and set: fps_max 300. This removes low caps during testing and helps reveal other bottlenecks. Re‑cap later to control thermals and noise. "There is also a command to unlock fps (fps_max e.g. 300)." [Elektroda, Graba211, post #16912569]
Should I measure FPS in the menu or in an actual match?
Measure during gameplay. Menu FPS uses different rendering behavior and can mislead diagnosis. Load a local match or a live server and use the developer console or a benchmarking map. "Get into the game normally and check there." [Elektroda, Gumipoliku, post #16921983]
How do I enable multicore rendering in CS:GO?
Open CS:GO settings, Video, Advanced. Ensure Multicore Rendering is enabled. This allows the i5‑4570’s cores to feed the GPU better, improving CPU‑bound performance in smoke and firefights. Re‑test after enabling. [Elektroda, Gumipoliku, post #16921983]
Could Xbox Game DVR be lowering my FPS on Windows 10?
Yes. Xbox Game DVR overlays and background capture can cut FPS and add stutter. Disable it in Windows Settings under Gaming or via the Xbox app. Restart CS:GO and compare frametime stability. Users reported improvements after turning it off. [Elektroda, mieszko09, post #17244802]
How can I check temperatures and system health quickly?
Install HWMonitor to read CPU and GPU temperatures while playing. Keep CS:GO running for five minutes, then tab out and review max temps. Also scan for adware with Malwarebytes and AdwCleaner. Overheating or malware can sap FPS. [Elektroda, Graba211, post #16912569]
Is there a simple 3‑step way to update and test my setup?
  1. Update GPU via GeForce Experience, then reboot.
  2. Disable V‑Sync and enable multicore rendering in CS:GO.
  3. Set fps_max 300, launch a match, and record FPS/temps.
    Compare results with your previous baseline after each step. [Elektroda, Graba211, post #16912364]
Device Manager shows drivers for CPU/monitor—should I update those too?
Yes. In Device Manager, update drivers for the graphics adapter, monitor, and processor where available. This can resolve misconfigurations and recognition issues that affect performance and refresh rate settings. Reboot afterward and re‑test FPS. [Elektroda, MŁODYELEKTRONIK15, post #16924064]
My sibling gets 200–300 FPS with the same parts. What should I compare?
Match driver versions, in‑game settings, Windows Game DVR status, V‑Sync, and Nvidia Control Panel profiles. Also compare background apps and overlays. A peer reported 200–300 FPS on Mirage with identical hardware, so configuration differences are likely. [Elektroda, ahaaaaa, post #16912393]
Temperatures look fine, but FPS is still low. What next?
If temps are normal and fps_max is high, focus on software. Disable overlays, scan for adware, and test with a clean boot. Reinstall the GPU driver with a clean install option. As one expert noted, temps and malware checks matter. [Elektroda, Graba211, post #16912569]
Why does the CS:GO menu show only ~35 FPS on my PC?
Menu FPS can be capped or impacted by overlays and is not representative. Use fps_max 300 for testing, then measure in an actual match. If gameplay FPS is normal, ignore menu readings. [Elektroda, Graba211, post #16912569]
Are third‑party driver updaters safe for this issue?
For NVIDIA GPUs, prefer GeForce Experience over third‑party tools. It ensures correct WHQL drivers and easy rollbacks. Use Windows Update or OEM sites for chipset and other devices instead. Keep changes minimal while troubleshooting. [Elektroda, Graba211, post #16912364]
What quick console/settings tweaks help CS:GO on this hardware?
Use fps_max 300, disable V‑Sync, enable multicore rendering, and test in a live match. These steps target common CPU and sync bottlenecks on i5‑4570/GTX 1050 systems. Re‑cap later to your monitor’s refresh. [Elektroda, Gumipoliku, post #16921983]
