[Solved] How to set the nvidia control panel for games to squeeze 1000%
FRANCUZ1995 49260 13
How can I configure the NVIDIA Control Panel for games to get the highest possible performance?
There is no special NVIDIA Control Panel setup that will give a huge FPS boost; the thread says the real gains come from GeForce Experience game optimizations and from lowering the game’s own settings and resolution. Use per-application settings in the NVIDIA panel, and if performance got worse after updating drivers, install the drivers from the graphics card manufacturer’s website instead of the newest generic NVIDIA package [#16610983] [#16611090] [#18048017] One reply also suggests testing PhysX on the GPU or on the CPU to see if it helps [#16942052] If you want more performance, reducing the in-game quality settings is the most effective step, because changing the control panel alone usually will not change much [#16942052]
  • NVIDIA control panel cannot boost game performance much
    #1 16610975
    FRANCUZ1995
    Hello, I have a small problem. I would like to know how to set the NVIDIA control panel for games to squeeze as much as it can maximally because the default settings are hopeless and let me experiment a little, I set my own way to give it some 40% efficiency compared to the default settings but I think I can still enter some a small change of about 20% (under the efficiency of course :P )
    That's how my settings look;
    My equipment:
    - FM2A68M-hd + assrock motherboard
    - AMD a8-7600 processor 3.8 ghz GHz 4 core.
    Temp. max. 75 ° (when playing on ultra HD settings in Battlefield1 or Dying Light heats up just to
    around 57 ° for longer playing, when it is at rest, it reaches only 35-38 °) and with it COOLER spartan pro.
    - memory framework RAM Patriot 8 jig GB framework RAM 1600 mhz MHz
    - GTX 1050ti graphics card
    - 500 power supply vat IN
    I care about a quick concrete answer, no unnecessary topics.
  • #3 16611083
    FRANCUZ1995
    sparky7 wrote:
    you checked nvidia experience ?
    There are ready optimizations for games.
    I checked, optimized the battlefield on the lowest and I can play quietly on ultra.
  • #4 16611090
    sparky7
    Help: 6
    Rate: 42
    Battlefield as most games have forums where settings for nvidia experience are described.
    For me, the performance drastically worsened when I installed the latest drivers from nvidia, everything was back to normal when I downloaded the drivers from the graphics manufacturer.
  • #5 16611123
    FRANCUZ1995
    sparky7 wrote:
    Batek like most games has forums where settings for nvidia experience are described
    my performance drastically deteriorated when I installed the latest nvidia controls,
    Does it mean that I have to download drivers from the manufacturer's website simply?
  • Factory Nvidia control panel settings fixed game performance
    #6 16941602
    manyx1
    I would like to thank the author of the topic, who helped me a lot.
    Well, I bought asus gtx 1050 ti oc I installed the latest drivers from the manufacturer's website including the nvidia control panel, I turn on the game and what's up? game boxing ... my older games are caged where on the 1gb card they were fluttering on medium details. I think maybe a slip for exchange? factory card overclocked with 4gb of memory and at the lowest settings of lime.
    I used to combine a lot in the settings in the nvidia panel, I was looking at forums and finally found an electrode here. these settings are great. games are now flying on ultra. if it is still possible to turn them on, ask the author for info "I put a beer :) "I confirm the factory settings in the card control panel, LEGACY! greetings and how I am waiting for info. manyx1(_at_)o2.pl
  • #7 16942030
    enhanced
    Help: 963
    Rate: 883
    But bullshit - why play on the ultra when the control panel switches off to ultra?
    Absurd, but it's important that it works.
    Only what works is high efficiency because it is usually adaptive and that can be different.
  • Lower game settings instead of tweaking Nvidia panel
    #8 16942052
    daminek1234
    Help: 61
    Rate: 88
    FRANCUZ1995 wrote:
    assrock motherboard
    skisłem.
    To achieve higher performance, reduce the settings in the game. Searching at this panel will not change much, because instead of playing the game, you will decrease the graphic settings in the panel. Let me tell you this: I only play in the panel when it comes to older games that can be mulped and on NASA equipment.
    You can alternatively switch PhysX from card to processor or vice versa and see if it gave you something.
    At what resolution do you play? Maybe the descent from FHD to HD will not be so drastic.
  • #9 16942257
    iron64
    Help: 648
    Rate: 313
    Assrock is good, and the idea of settings is of absolute minimum quality, and setting ultra-quality in the game is already a curiosity ;)
  • #10 16942262
    daminek1234
    Help: 61
    Rate: 88
    @ iron64 this is AsRock, not ASSrock. Pupo-rock?
  • #11 16942332
    iron64
    Help: 648
    Rate: 313
    See what the author of the subject wrote and you will know everything.
    I would explain it differently, but let it be ok anyway ;)
  • #12 17649518
    FRANCUZ1995
    It is possible, however, that your problem has disappeared only when you set it because it gives 30 fps some. Although everything is possible.
  • #13 18048017
    S4V1O1
    Maybe in the nividia panel, change the settings for only the application
  • #14 18530029
    FRANCUZ1995
    New equipment purchased
The discussion revolves around optimizing NVIDIA Control Panel settings for gaming performance. The original poster seeks to enhance efficiency beyond their current 40% improvement over default settings. Responses suggest checking NVIDIA Experience for game optimizations and highlight issues with performance after installing the latest NVIDIA drivers, recommending reverting to manufacturer-specific drivers. Users share experiences with different graphics cards, including the ASUS GTX 1050 Ti, and discuss the importance of adjusting in-game settings for better performance. Suggestions include switching PhysX settings and playing at lower resolutions to improve frame rates.
