[Solved] Seat Ibiza 2007: Climatronic Icons Flashing, Hissing Sound, Engine Diagnostics Light
andzej789 11976 11
Why do the Climatronic icons flash and the air conditioning hiss without cooling properly in a 2007 Seat Ibiza, and could this be related to the engine warning light?
The flashing Climatronic icons mean the climate control has stored faults, and the hissing/no-cooling symptom points to low refrigerant in the A/C system, so the next step is diagnostics and an A/C service rather than guessing [#16394577] [#16394606] [#16397031] You can check the climate system from the panel with the key combination, or connect a diagnostic computer to read what the Climatronic sees [#16394577] [#16394578] One reply specifically says the system likely has only residual refrigerant and needs topping up [#16394606] [#16397031] The engine diagnostics light was not clearly tied to the climate fault in the thread, so the practical advice was to read the stored faults first [#16394577] [#16394578] The thread later ends with the A/C being filled and the fault removed [#17299915]
  • #1 16394566
    andzej789
    Rate: 160
    Hello..I noticed that in my Ibi all the icons on the climaronic are flashing when firing ... after setting on the climate below 18 degrees, you can hear such a hiss and the cold air does not flow, only the cool air ...
    Can the engine diagnostics light be connected to this ... after setting the temperature to 27 degrees went out ..
    Will anyone help ... or immediately connect to the computer ??
  • #2 16394577
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Panel flashing is normal and there are errors - I suspect there are a lot of them. As you wrote yourself, first order decent diagnostics. You can do a climate check from the panel - key combination.
  • #3 16394578
    przemek25l
    Help: 124
    Rate: 372
    Connect and read what climatronic system sees the error
  • #4 16394606
    domex32
    Help: 585
    Rate: 2451
    andzej789 wrote:
    You can hear this hissing and the cold air does not go cold but cold
    You need to do air conditioning service, you have residual refrigerant in the system.
  • #5 16396954
    andzej789
    Rate: 160
    By which keys ?? So connect to the computer ?? Residual agent i.e. At the moment everything has returned to normal.
  • #6 16397031
    domex32
    Help: 585
    Rate: 2451
    Yes. Connect to a computer and top up the air conditioning system.
  • #7 16419825
    andzej789
    Rate: 160
    so called air conditioning acquisition?
  • #8 16429235
    andzej789
    Rate: 160
    I connected to a computer. The air conditioning is a pressure sensor, maybe a low pressure, diagnostics is that the second cylinder plugs and that there is a damaged wire or a circuit ...
    I used to exchange candles ... the error was removed and it is still lit ..
  • #9 16431425
    andzej789
    Rate: 160
    Where to look for the reason why the diagnostics glow?
  • #10 16431708
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Do it: make an appointment at a reputable workshop in the area and get a problem diagnosis. The cost should not exceed PLN 150-200. You will save on unnecessarily replaced parts and procedures.
  • #11 16432484
    andzej789
    Rate: 160
    Well ok..plugging under the weight will tell them that the candle will replace it, the error will be removed and after some time I will light the diagnostics again
  • #12 17299915
    andzej789
    Rate: 160
    Air conditioning filled and fault removal ..
The discussion revolves around issues with a 2007 Seat Ibiza's climatronic system, where all icons flash, a hissing sound is heard, and cold air does not flow properly. Users suggest that the flashing icons indicate errors, and recommend connecting to a diagnostic computer to identify issues. Possible causes include low refrigerant levels and a malfunctioning pressure sensor. The author mentions that the engine diagnostics light is related, and after some troubleshooting, the air conditioning system was filled, but the diagnostics light remained on. Recommendations include performing a thorough diagnostic at a reputable workshop to avoid unnecessary repairs.
