Seat Ibiza 6L - Blower Issues with Climatronic, Error 4F9 and 6Q1907521A Resistor
jarosz19 12270 5
  • #1 16428954
    jarosz19
    Rate: 46
    I have a problem with blowing in Ibiza 6L with climatronic. Shows error 4F9 after clearing the error for some time is calm, however, the fan is constantly working at a constant speed does not respond to the potentiometer. The VCDS shows the voltage changes depending on the position of the potentiometer, however, the output always gives a rigid 12V so on mine for replacement ?? There is a resistor No. 6Q1907521A
  • #2 16428969
    decybel91
    Help: 1024
    Rate: 4231
    Blower resistor.
  • #3 16429568
  • #4 16430517
    jarosz19
    Rate: 46
    Bieda z nędzą wrote:
    decybel91 wrote:
    Blower resistor.
    Is there something like that?
    There is a resistance:
  • #5 16430569
    emeryt2
    Help: 717
    Rate: 2302
    Jarosz, this is not a "resistor", it is an electronic supply controller (blower).
    If you have a little idea about electronics, there is an executive transistor and an operational amplifier inside. Often, the executive transistor, large, mounted on the heat sink (such as something with ribs) is damaged, it is probably necessary to replace.
  • #6 16434018
    jarosz19
    Rate: 46
    After replacing the resistor / regulator the fault has been repaired :)
