SM-A510F - I can't go back to an older version of Android 6.0.1
Myrasz 5283 15
Can I downgrade my Samsung Galaxy A5 (SM-A510F) from Android 6.0.1 build A510FXXU4BQC1 back to an older 6.0.1 firmware such as A510FXXU3BQB1?
Samsung has blocked downgrading to older firmware versions, so flashing A510FXXU3BQB1 over A510FXXU4BQC1 is no longer allowed in the usual way [#16395013][#16395081] One suggested workaround was to flash the firmware with a PIT file extracted from CSC and use the correct Odin options, since the PIT defines the partitions for the new software [#16395051] Another user said Odin was crashing on hidden.img and that removing hidden.img from the firmware package allowed the older soft to be uploaded [#16395095][#16395215] If the only issue is battery drain after updating, several replies advised waiting for 2–3 charging cycles because the battery use may stabilize after some time [#16395051][#16395417]
  • #1 16394953
    Myrasz
    Help: 10
    Rate: 82
    I am the owner of the Samsung Galaxy A5 (2016). I bought it with preloaded Android 5.1.1 and a brand of the Play network. Unfortunately, the operator did not bother to update to 6.0.1., So I decided to do it on my own, i.e. I downloaded the appropriate soft via SAMFIRM and downloaded it - without any problems. Every now and then updates of the same version of Android (6) come out, but I noticed that some use up the battery more, so using ODINA, I return to the version that suits me. Another update came out this month, but it is using up the battery significantly. So I wanted to upload the previous ROM (I keep previous versions on the disk), but strangely I can't, because there are errors:
    ODIN:
    However, on the phone screen I have the message:
    The only solution is to download the latest version, which unfortunately I do not like, because the battery rains much faster.
    Soft, which I want to upload: A510FXXU3BQB1_A510FOXA3BQB2_A510FXXU3BQB1
    Soft, which can be uploaded: A510FXXU4BQC1_A510FOXA4BQC1_A510FXXU4BQC1
    Is it possible that samsung blocked in any way returns to older versions of the same android? There was no problem with that before. I tried with different versions of ODINA, but it's the same.
  • #2 16395013
    sylweksylwina
    Help: 1881
    Rate: 2348
    It's a fact, not a possibility. Samsung has blocked the option of uploading an older firmware.
  • #3 16395051
    beo
    Level 37  
    Help: 298
    Rate: 237
    Soft uploaded with the extracted PIT file and the appropriate option in Odin? The PIT file sets the partitions for new software.
    Another thing is that you should give some time to the new system. It is possible that after 2-3 charging cycles everything will stabilize.
  • #4 16395057
    Myrasz
    Help: 10
    Rate: 82
    Everything is set up in Odin. Only the last version of the software is uploaded, just like all previous versions (including returning to older versions).
    I hope it will happen.
  • #5 16395067
    beo
    Level 37  
    Help: 298
    Rate: 237
    Have you made root on your system?
  • #6 16395081
    sylweksylwina
    Help: 1881
    Rate: 2348
    It has nothing to do with this situation. Samsung blocked downgrade and that's it.
  • #7 16395095
    siudziu
    Help: 57
    Rate: 113
    I see that soft crashes on hidden.img, I try to remove this file from the software (I do it with a total commander) so far I managed to upload soft after removing the hidden.img file from the soft file. In case of problems write to gg I will try to help.
  • #8 16395137
    beo
    Level 37  
    Help: 298
    Rate: 237
    The root query did not refer to the inability to return to 5. Where is some info about this block?
  • #9 16395179
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2088
    On this version, the battery lasts 3 days with little use of the phone. What does it look like for you?
  • #10 16395213
    Myrasz
    Help: 10
    Rate: 82
    To make it clear - I operate on various Android 6.0.1 updates - I don't want to go back to 5, only to the previous version 6. I don't have root - I don't need it. The phone is so efficient and works smoothly that I have no reason to rummage in it more than on the default settings (or in the developer options).
  • #11 16395215
    siudziu
    Help: 57
    Rate: 113
    Do as I wrote and you should be able to upload the older soft.
  • #12 16395223
    Myrasz
    Help: 10
    Rate: 82
    If little use is also 2-3 days, but with more intensive, in the evening I have about 45-50%. On the previous build: A510FXXU3BQB1_A510FOXA3BQB2_A510FXXU3BQB1, at the end of the day I had 60-70% for the evening. Due to the fact that I charge the phone only at home, on the original charger with the option of quick charging - at the moment I have to do it every day. I do not want to completely discharge at work and I do not risk leaving home for work with less than 70% battery charge.
    Of course I will try, but only in the evening.
  • #13 16395417
    beo
    Level 37  
    Help: 298
    Rate: 237
    Sometimes it is so that the first percentages seem as if they were flying faster, and from 30% for example much slower. Too fast, in my opinion, you assess the performance on new software, the more so because de facto there is no change in the whole number, but security patches. Give him a few days.
  • #14 16397333
    Myrasz
    Help: 10
    Rate: 82
    Unfortunately, Odin crashes after deleting this file - exactly when you selected the soft file:
  • #15 16397354
    beo
    Level 37  
    Help: 298
    Rate: 237
    I see you are using one file rom? Have you tried with 4 files along with PIT extracted from CSC? You wrote that you did it, but from the screen above you can see that it's one file maker. Fast charging is ok, but when we have time, charging should be rather slower. Healthier for the battery.
  • #16 16398262
    Myrasz
    Help: 10
    Rate: 82
    I have not written anywhere that I use multi-file ROMs :) I won't mess up, just wait and watch the phone work.
    I'm closing the topic.
✨ The discussion revolves around the difficulties faced by a Samsung Galaxy A5 (2016) user in downgrading from Android 6.0.1 to a previous version due to Samsung's restrictions on firmware downgrades. The user successfully updated to Android 6.0.1 but encountered battery drain issues with newer updates. Attempts to revert to an older ROM using ODIN resulted in errors, particularly related to the hidden.img file and MD5 hash validation. Participants suggested using a PIT file for proper partition mapping and discussed the impact of charging habits on battery performance. The user clarified they do not require root access and prefer to maintain default settings. Ultimately, the user decided to monitor the phone's performance before taking further action.
