Samsung Galaxy s6 - Flashing buttons, screen lag, battery drain
FreshPrince 4353 7
  • #1 16514593
    FreshPrince
    Rate: 14
    I have a Samsung Galaxy S6 in which on Android 6, the menu buttons (backspace and application) were flashing like a strobe, the phone worked (buttons too), while the touch seemed to be slightly lagging and draining the battery faster. This has not always happened but often. I uploaded a new (4 file) Android 7 and now the buttons do not work at all, but sometimes they light up, the rest remain unchanged, i.e. how light touch lag and battery discharge. In addition, the phone works normally and undergoes all tests etc.
    I looked for it on the internet and found threads on xda and at & t but unfortunately no solution ..
    https://forum.xda-developers.com/galaxy-s6/he...y-s6-soft-keys-flashing-t3369661#post72564396
    https://forums.att.com/t5/Android/S6-Edge-Scr...Touch-Buttons-Flash-continuously/td-p/4883352
    Maybe someone can do something about it?
  • #2 16515134
    nutergsm
    Help: 1034
    Rate: 1665
    Go back to 5.1.1 and wait for the problem with Android 6 and 7 to be resolved.
  • #3 16515578
    FreshPrince
    Rate: 14
    If I want to upload 5 from samfirm I have a fail on Odin, I don't even try to upload it. How to do a downgrade now?
    I need to upload 4 files? If so, will someone send a link to the Polish one?
  • #6 16515665
    nutergsm
    Help: 1034
    Rate: 1665
    Then it's a visit to the site and uploading the firmware box.
  • #7 16515676
    FreshPrince
    Rate: 14
    If odin does not work, there is no other way to downgrade only box?
    Maybe it was important that the phone was from orange (the simlock was previously downloaded by a code in the salon). But I have uploaded no branded sofas anymore and have never had problems and here are such flowers.
    edit:
    Unfortunately, on this system you have entered is also fail.
  • #8 16518062
    FreshPrince
    Rate: 14
    I noticed a dependency, the phone turned off 2 days after starting, it worked without a problem for about 30 minutes, then I connected the charger and the problem started.
The discussion revolves around issues faced by a Samsung Galaxy S6 user, including flashing menu buttons, screen lag, and battery drain after upgrading to Android 7 from Android 6. The user reports that the buttons occasionally light up but do not function, and the touch response remains laggy. Suggestions from other users include downgrading back to Android 5.1.1, with some users experiencing difficulties using Odin for the downgrade process. Alternative solutions mentioned include trying a different version of Android (6.0.1) and considering firmware box uploads if Odin fails. The user also notes a potential correlation between charging the device and the onset of issues.
