Media-Tech Speaker BOOMBOX BT Repair MT3145 - An unplugged charging socket.
Ewenemento 18831 11
How can I access and repair the charging socket of a Media-Tech BoomBox BT speaker if the socket broke off and fell inside the wooden enclosure?
You need to open the speaker from the loudspeaker/front-panel side, because the front panel is snapped in and can be removed only by force; that gives access to the case and the power socket [#16397324][#16580499] If the micro-USB socket is damaged, you do not need all four pins for charging: find GND and +5V, and solder to the +5V line and ground, while the two middle pins are only for data [#16588276][#16590894][#16935719] If soldering the tiny connector is too difficult, replace the socket or send the unit to service/store for repair or exchange [#16591817][#16829865]
  • #1 16397291
    Ewenemento
    My problem is that I broke off the charging socket that fell inside the loudspeaker. Media-Tech Speaker BOOMBOX BT Repair MT3145 - An unplugged charging socket.
    Unfortunately, the loudspeaker has a wooden casing and it is not possible to "unscrew" it.
    What can I do in this situation? I'm counting on your help.
  • #2 16397324
    januszx3
    Help: 214
    Rate: 420
    Ewenemento wrote:
    I cut off the charging socket that fell inside the loudspeaker
    You can get inside the case and the power socket by removing the loudspeaker, see attachment illustration:
  • #3 16399352
    Ewenemento
    Unfortunately, I do not have this information in the attached manual, you are able to send me a photo if you have it? I would be very grateful :)
  • Front panel is snap-fit and must be pried off
    #4 16580499
    foxxer672
    Help: 47
    Rate: 163
    You can not get to the front panel in this way, any ideas?
    Added after 26 [minutes]:
    The front panel is snapped in, it is removed by force, it can not be done without the edge of the casing
  • #5 16586956
    esk2
    Rate: 10
    I have exactly the same problem, charging first began to stop then the socket completely dropped out. I turned on, soldered a week and dropped out again, now I am looking for a solution to charge and power bypassing the charging socket. Has anyone succeeded?
    because the soldering of these 4 microths is unrealistic without a specialist soldering iron ..
  • #6 16588276
    satanistik
    Help: 61
    Rate: 762
    All four paths are not needed for charging. Probably just find the mass and + 5V. Removing the tile after undressing will make it easier to search for a solution.
  • #7 16590894
    foxxer672
    Help: 47
    Rate: 163
    Finding a place to barter is very simple, around the charging socket is one path + 5V, you should solder to the first foot on its element line, the rest is mass.
  • #8 16591817
    Bosch16
    I also fell out of the socket, I disassembled the speaker but I have to buy a new socket or do someone know what exactly is this model of this micro usb socket?
  • Charging socket replaced under warranty with newer board version
    #9 16829865
    makosuu
    Help: 369
    Rate: 370
    Theme a bit old but I think it is worth mentioning: how the nest has not fallen in (terribly grandfather is) only does not load, it's walkie to the store where you bought and either exchange for a new one at once or (as in me it was) send to the site Media-tech which orders them to replace them for a new one.
    Unfortunately, there is a new version of this tile in the middle, in this place where there is such a plug as it is a button described as REGET, I do not know what it does, I never pressed and instead of cool sounds the speaker has a horrible teacher-babsztyli who speaks with Chinese accent eg The bluetooth device is ready to pair. But the socket is still charging, so maybe the nest has improved. And a really good speaker, especially for 100 zlotys.
  • #10 16935719
    szafran1983
    well the loudspeaker is really good, as to the socket as someone wants it can do it from a small power bank, tiny converter on one finger 18650 and mount it and then it can be charged back :) I unscrewed the 4 screws on the back which fixed the container for 1 battery 18650, from the laptop I connected 5 pieces 18650 :) = 10,000 mAh :) and the sound is not coming off anymore and the sound improvement is because the wheeze was due to the fact that the amplifier got too little power + serves as a powerbank now because there is always a voltage on the USB. The minus is that 30 hours is charged and there is no mini jack 3.5 on the headphones :( and the same advantages, I added professional legs made of elastic rubber and not some foam. The product recognizes as good only yarns did not work but I did it :) at the top I added a tiny microSD box just for the cards :) As for the "reget" button, the English dictionary does not know such a word and when you press it it is simply reset and not reget :) how much is your game because my over 36h :) without charging :) there is a cotak for some ballet
    Added after 15 [minutes]:
    you can always take them to the store :)
    Added after 4 [minutes]:
    the first and last are +/- the central redundant because they are used for data transfer
  • #11 16937689
    makosuu
    Help: 369
    Rate: 370
    Recently I saw it in the store and the button was called RESET and not REGET. But the nasty voice lector is still instead of those cool sounds. But I do not know why this button has never been useful to me: p
  • #12 16949116
    szafran1983
    Heh, it's good that you did not use this button, I do not like it but it's better than it is than some tacky blank. Well, before this teacher I do not remember what was in the previous version because I only had it for a while and exchanged for a new one because I had a faulty display, the bottom part did not display. I got the newest one with a 1400mAh battery and in the previous version it was 2000mAh so a bit of a roller, thankfully as I mentioned and so I modified the batteries or actually changed. Cool is called A 10 is just a different, great housing, more modern look of the front panel and silver instead of orange bass color and what is important about 60 PLN costs, so much cheaper, I do not have a link because with tela writes, greetings colleagues warmly!
    Added after 38 [minutes]:
    the fix is not A 10
    • Media-Tech Speaker BOOMBOX BT Repair MT3145 - An unplugged charging socket. SOUNDBEAT20.jpg (30.28 KB) You must be logged in to download this attachment.
The discussion revolves around the issue of a broken charging socket in the Media-Tech BOOMBOX BT speaker (model MT3145), which has fallen inside the wooden casing. Users suggest various methods to access the internal components, including removing the loudspeaker and forcibly detaching the front panel. Some participants share their experiences with similar problems, discussing temporary solutions like bypassing the charging socket or using alternative power sources, such as a power bank. Others mention the difficulty of soldering the micro USB socket and the potential need for a replacement part. Additionally, there are comments on the speaker's performance and modifications made to enhance its functionality.
