Media-Tech MT3145 - replacement of the battery with a permanent power supply
foxxer672 5097 5
  • #1 16581406
    foxxer672
    Help: 47
    Rate: 163
    Anyone know what are the permissible supply voltages of the system implemented in this portable speaker?
    Currently, a Li-Ion 18650 3.7V battery is installed
    Since the laminate is damaged due to the detached MicroUSB input, I would like to make an external power supply for it and I wonder if ordinary USB is not enough, but I have concerns if the 5V voltage will not be too high and no resistor is required, etc.
    Laminate marking: DXP-A10-2.2.PCB.
  • #2 16581639
    Freddy
    Help: 1394
    Rate: 2821
    Standard USB to 5V.
  • #3 16581935
    foxxer672
    Help: 47
    Rate: 163
    Freddy wrote:
    The USB standard is 5V.
  • #4 16582030
    HD-VIDEO
    Help: 1265
    Rate: 1884
    The power supply has to be made 3.7V and the battery removed
    pawelr98
    Help: 413
    Rate: 1155
    18650 cells most often have a voltage range of 3.7-4.2V.
    Any stabilized power supply that gives voltage in this range will do.
    Get the LM317 (set to 4V) or the rare 7804 (I saw such a miracle in my brother's stereo).
    Linear stabilizers require about 2V more at the input. For 4V you will need around 6V at the input.
    Alternatively, just find the + 5V, GND (ground) lines and reconnect the cables to them.
    It would be more elegant because there will still be a battery.
  • #6 16582699
    foxxer672
    Help: 47
    Rate: 163
    Thanks for your help, I'll use the LM317
