IPOX PX-AHD0421H Recorder: Resetting Forgotten Password & Enabling 4-Channel Recording
karol-jaskulski 10014 9
How can I reset a forgotten password on an IPOX PX-AHD0421H recorder so I can add more cameras?
There does not appear to be a simple local reset for this recorder; the battery only resets the clock and date, and one reply says there is no motherboard microswitch to clear the password [#16418919] The forum advice is to contact IPOX technical support or the manufacturer’s paid service to recover or reset access [#16420123][#16423042] One user also suggested trying the password used for remote viewing, if that feature was previously set up [#16423091] The factory password mentioned in the thread is 123456, but it was already not working for the poster [#16418919]
  • #1 16418521
    karol-jaskulski
    Help: 9
    Rate: 8
    I have an IPOX PX-AHD0421H recorder. Once I set up recording on 2 channels, changed the password from the factory 123456 to ??? ( I do not remember).
    Recently I bought 2 cameras, I wanted to record on 4 channels, but I can't log in - I forgot my password. I read that there are some backdoors, e.g. 8888 * day * month * year - but it doesn't work.
    I also tried via telnet. I found passwords on the network:
    - xc3511
    -vixcv
    - 7ujMko0
    It turned out that neither of these passwords also "telnet". The question is, does anyone know how to reset passwords in this recorder?
  • #2 16418885
  • #3 16418919
    karol-jaskulski
    Help: 9
    Rate: 8
    1. The default password is 123456 - it is written in the recorder's manual. The admin password is not working.
    2. After removing the battery from the motherboard, only the clock loses its memory and you have to reset the time and date.
    3. There is no microswitch on the motherboard (I know there is one in bcs) so I can't reset it this way.
    I noticed a sticker TW2704AS-C (V1.3) 1606110992 on the motherboard - maybe it will be a hint
  • #4 16420123
  • #5 16423042
    sosarek
    Help: 9321
    Rate: 15545
    Bogdan K wrote:
    Pull out the battery that supports the settings.
    Do not write nonsense - it only creates complications, even if you cannot use the one-day password and the only thing that remains is a paid service on the manufacturer's website.
    Z
    Pka, Poznań, 60-850
  • #6 16423064
  • #7 16423091
    sosarek
    Help: 9321
    Rate: 15545
    Bogdan K wrote:
    instead of cutting me off
    You misled the Author with your ignorance, which would make it impossible to even use the daily password (some companies are able to provide it even over the phone) - now he will have to send the device back to the service and bear the costs - will you cover it?
    Bogdan K wrote:
    At the moment, the equipment will go to the site anyway
    Now for sure - thanks to your "golden thought".
    All that remains now is to upload the new firmware.
    @ karol-Jaskulski Have you used remote view? If so, try logging in with the password you used for this purpose.
    Z
    Pka, Poznań, 60-850
  • #8 16423119
  • #9 16423145
    sosarek
    Help: 9321
    Rate: 15545
    Bogdan K wrote:
    Speculation and guesswork on your part, not which companies are interesting.
    What speculations and guesses? Who wrote
    You do not know the topic - do not comment and do not mislead.
    Bogdan K wrote:
    Are you sure.
    Yes, and I find no further discussion pointless.
    Z
    Pka, Poznań, 60-850
  • #10 16423446
    raffin
    Help: 86
    Rate: 109
    Bogdan K wrote:
    I propose to write to technical support.
    support (malpa) ipox.pl
    www.ipox.p
    or to the appropriate contact (Technical IP / Service) from the website: http://www.napad.pl/kontakt
The discussion revolves around the IPOX PX-AHD0421H recorder, focusing on issues related to resetting a forgotten password and enabling 4-channel recording. The user initially set a new password but forgot it, and attempts to use known backdoor passwords and telnet access were unsuccessful. Responses suggest checking for a microswitch on the motherboard, removing the battery to reset settings, and contacting technical support for assistance. Some participants express skepticism about the effectiveness of certain solutions and emphasize the importance of saving passwords. The conversation highlights the challenges faced when dealing with security features in electronic devices.
