Vw passat CC 2015 - Converting rear lamps from the USA to the EU
Bunny82 6930 8
  • BCM wiring needed for EU rear lamp conversion
    #1 17449534
    Bunny82
    Help: 15
    Rate: 242
    Hello, I am at the CC 2015 workshop. from Canada for the conversion of rear lamps. Fortunately, I was able to convince my client to buy three rear lamps for Europe. My question is whether in this case you need to add cables from BCM to the rear lamps? Just in case, I pulled back 3 cables (2 directions and fog) The switch has been replaced and from the switch from pin 7 I pulled the cable and connected to the BCM on pin C47. I wanted to check the direction in the tail lamps but the directions do not work so I turned on the emergency and the counter started flashing. What could be going on?
  • #2 17450344
    Launch78
    Help: 22
    Rate: 162
    buddy and the module coding did you probably have BCM2.0
  • #3 17451912
    Bunny82
    Help: 15
    Rate: 242
    I have not done coding yet because I wanted to prepare an electrician and connect it and finally do coding. Is this coding done in the gateway or in the central electric unit?
  • #4 17451955
    Launch78
    Help: 22
    Rate: 162
    Central electricity
  • #5 17456903
    Bunny82
    Help: 15
    Rate: 242
    And you can tell me what the encoding for bcm should be with the number as in the attachment. The car is equipped with cornering lights, bi-xenons, rear European lamps, headlight washers and I will remind you tomorrow, it will answer you at most Thanks for your help
    • Vw passat CC 2015 - Converting rear lamps from the USA to the EU 20180922_135157.jpg (981.26 KB) You must be logged in to download this attachment.
  • #6 17459717
    Bunny82
    Help: 15
    Rate: 242
    Which bits to mark in byte 18 to turn on the cornering light and in the rear lamps so that the directions flash without stopping and stopping, please help because by the end of the week I have to give the belt to the customer
  • #7 17472041
    Bunny82
    Help: 15
    Rate: 242
    Sorry, I didn't speak for a while, I struggled with this error and it was only through Odis that I was able to code the bsm. Only the problem of the headlights remained, so in the original the car had headlights with a led strip and now they are without a led strip and includes / W16W bulb LIGHT STOPPED / bulb mounted diagonally to the side as cornering lights H7 / bixenon / here is a link to these lights. I removed the old light driver from the glove box and bought a second one with the numbers 6R0907357 C for these lights. I have a problem with the connection because you need to redo the installation and in my old elsa there is no other diagram but for this old driver or someone has a connection diagram for these lamps in the language English or Polish ?????
  • #8 17474845
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    This daytime bulb by. labels are W 24 W. Need these schematics?
  • #9 17475182
    Bunny82
    Help: 15
    Rate: 242
    I so need this to end this
    Added after 6 [minutes]:
    As I found out that in this Passat there is a reflector with static cornering lighting and not, as in the diagrams in elsa, for dynamic cornering lighting
The discussion revolves around converting the rear lamps of a 2015 VW Passat CC from North American specifications to European standards. The user is seeking guidance on whether additional wiring from the Body Control Module (BCM) to the rear lamps is necessary after replacing the lamps and switch. They have already pulled back three cables for direction indicators and fog lights but are experiencing issues with the direction indicators not functioning correctly, leading to flashing when the emergency lights are activated. Responses highlight the importance of coding the BCM, specifically in the central electric unit, and inquire about the correct coding parameters for features like cornering lights and proper functioning of the rear lamps. The user also faces challenges with headlight compatibility and wiring diagrams for the new light driver.
