Mondeo mk4 2008 - Inconsistent Speedometer & Display Function: Loose Screw & Potential Solutions
angie-83 30048 6
  • #1 16400652
    angie-83
    Rate: 10
    Hello. I have such a problem here that in Mondeo mk4 2008 the hands have stopped working, and only half of the display between the clocks works. Today I noticed one thing - after unscrewing the right screw from the meter and tilting it by about 1.5 cm, the clocks returned to their work and the whole display works. After tightening, nothing works again. I spun it into parts one and found nothing
    Anyone have any idea? Path, mass on the plate? Or something else?
  • #2 16400658
    emeryt2
    Help: 717
    Rate: 2303
    Connectors on the back of the wardrobe, cold February there or a cracked path - look for cold solders and a magnifying glass of cracked paths throughout.
  • #3 16400711
    angie-83
    Rate: 10
    Tomorrow I will tick the photo, can someone direct where to look?
  • #4 16403098
    kuba021
    Help: 6
    Rate: 18
    Hello. Check the plugs that are on the back of the meter whether they sit well and do not have slack individual wires, the rest as a colleague above wrote
  • #5 16421982
    piotrusia
    Rate: 12
    This socket and plug to clean with contact and carefully under the magnifying glass look through these paths from the back because they like to be sometimes cold February that needs to be improved.
    Mondeo mk4 2008 - Inconsistent Speedometer & Display Function: Loose Screw & Potential Solutions Mondeo mk4 2008 - Inconsistent Speedometer & Display Function: Loose Screw & Potential Solutions
  • #6 18819532
    whitedog1
    Rate: 10
    I had the same cold February on the socket pins.
    • Mondeo mk4 2008 - Inconsistent Speedometer & Display Function: Loose Screw & Potential Solutions 20200715_153737.jpg (1.29 MB) You must be logged in to download this attachment.
  • #7 21550316
    audic5
    Rate: 54
    Hello, very common ladder resistor RN1403 47 Ω x4.
The 2008 Mondeo Mk4 exhibits malfunctioning speedometer hands and partial display operation. The issue temporarily resolves when loosening the right screw on the instrument cluster and slightly tilting it, but returns upon retightening. Diagnostic suggestions focus on inspecting the connectors and solder joints on the back of the instrument cluster for cold solder joints ("cold February") and cracked PCB traces. Cleaning the socket and plug contacts and examining them under magnification is recommended. A common failure point includes the ladder resistor RN1403 (47 Ω x4), which may contribute to display and gauge inconsistencies.
