Whirlpool AWO / C 61203P Washing Machine: Guide to Replacing Bearings & Cost-Effectiveness
7086 18
How can I replace the bearings in a Whirlpool AWO/C 61203P washing machine with a welded tank, and is it worth repairing?
You can cut the welded tank open, drill about 6 holes for M6 bolts around the tank, replace the bearings and seal, then screw the tank back together using automotive glass glue as the sealant [#16402244] Do not use too many screws, and the repair’s profitability depends mainly on the condition of the drum cross/spider and whether the tank will remain tight after reassembly [#16402244]
  • #1 16402183
    Bridgestone
    Help: 30
    Rate: 105
    Drill fi 6 holes for M6 bolts around the tank, without overdoing it with the number of screws, then cut the tank in half and after replacing the bearings and sealant, twist the tank with the above-mentioned screws using automotive glass glue.
    The question remains what condition the cross will be in and whether it will be tight after twisting the tank.
  • #3 16418172
    Bridgestone
    Help: 30
    Rate: 105
    Check the heater resistance with a multimeter. A functional one should be about 30?. It would also be worth checking if 230V voltage appears in the heater power cables. The heater power measurement should be started after about 10 minutes. from starting a washing program with hot water.
  • #5 16418356
  • #6 16451361
    Mariusz Borusiewicz
    Rate: 24
    The washing machine does not heat up at the beginning of the wash cycle. The heater turns on 5 to 10 minutes after it is started. Write whether the entire washing cycle is washed with cold water.
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    In these washing machines, if there is any reason with the heater, burned out or has a breakdown, the appropriate error will appear.
  • #9 16461271
  • #10 16461306
    Kenworth 18
    Help: 2442
    Rate: 3749
    If you connect the heater wires the other way around, you will not damage anything and the heater will work if it has power. The only question is whether the washing machine powers the heater?
    It is better and faster to check it with a multimeter than to wait half an hour for the washing machine to heat the water, if it heats it.
  • #11 16461335
  • #12 16461381
    Kenworth 18
    Help: 2442
    Rate: 3749
    It is enough to set the multimeter to measure 230V AC and after about 10 minutes from turning on the washing machine for any program with water heating, measure the voltage at the heater connections. The wires do not even need to be disconnected from the heater.
  • #13 16461404
    Kenworth 18
    Help: 2442
    Rate: 3749
    It faded completely? If so, check the relay on the control module.
    The contacts in the relay may have burned out.
  • #15 16461440
    Kenworth 18
    Help: 2442
    Rate: 3749
    To check the relay, it must be desoldered from the module. He must not give the control voltage when it is soldered in the controller because it may damage the controller.
  • #17 16461529
    Kenworth 18
    Help: 2442
    Rate: 3749
    No. This is an anti-interference filter. If it was damaged, the washing machine would not have power.
    The relay is a "rectangle" and there are several of them on the electronic controller board.
    You are waiting for the disassembly of the front grille and electronics that are there.
  • #19 16461588
The discussion revolves around the challenges of replacing bearings in a Whirlpool AWO/C 61203P washing machine, particularly due to the welded tank design. A user seeks advice on disassembling the machine and the cost-effectiveness of repairs. Suggestions include drilling holes for M6 bolts to cut the tank, replacing bearings, and resealing it. The user encounters additional issues with the heater not functioning properly after disassembly, leading to troubleshooting steps involving multimeter checks for resistance and voltage. The conversation highlights the importance of checking the control module relay if the heater does not receive power, as well as the potential for error codes to indicate heater issues.
