Livebox 2.0 Login Issue: Recovering Forgotten WiFi Password after Brother's Change
blackb 26595 11
How can I regain access to a Livebox 2.0 when the admin password was changed and I don’t know the Wi‑Fi password?
Reset the Livebox 2.0 with the button on the back to restore factory settings, then log in again and change the password [#16404244] On some Livebox 2.0 units, the default admin password is the first 8 characters of the WPA key, which is printed on the case/label under the password slot [#16403741] After the reset, the settings return to factory defaults, so this default key/password should work again [#16403827] If you also need the Orange login or PPPoE password, you may have to ask Orange for it [#16403896]
  • #1 16403402
    blackb
    Hello, I have a problem with Livebox 2.0 and I can not log into the modem. My brother changed my password but he does not remember how I can get inside because I want to see what is the password for wi fi?
  • #3 16403427
    blackb
    lol, I repeat !! - I CAN NOT LOG IN TO THE PAN BOU A PASS FOR ADMIN IS REQUIRED THAT HAS BEEN CHANGED BY A BRANCH, SO HOW DO I GO TO A FACTORY SETTING?
    I am trying to connect via telnet to the router but I have such a message
    https://gyazo.com/e6cd1731a4729aef7d3ce487264ec0bb
    There's nothing listening on port 23
  • #4 16403511
    CHACA
    Help: 875
    Rate: 457
    By pressing the reset button in the back there is nothing too?
  • #5 16403728
    arcis
    One day one could get a password from the router by debugging htmlu, but on a fun box 2.0 it is already well written .. a little bit of a muggle for such a solution.
    The admin password is reset, I was looking for the login password to the router in the router ..
    I still had a backup file to analyze ...
  • #6 16403741
    LucekB
    Help: 143
    Rate: 137
    ATTENTION! Recently, there is another default admin password for Livebox 2.0.
    The password is the first 8 characters of the WPA key. Look at the message under the password slot on the right.
  • Livebox admin password uses first eight WPA characters
    #7 16403775
    blackb
    Haha good...
    One excludes the other .... I do not know the password for wi fi because it has also been changed or password to admin.
    I've already done it through a reset on the back of the modem, password pulled through the orange page, logged in - I wrote down the login and the password reset because I did not know what is
  • #8 16403784
    simhak
    Help: 109
    Rate: 336
    WPA key was written on the box enclosure ...
  • #9 16403787
    blackb
    Buddy ..... The password has been changed! I did not have this password from the case as well as the admin panel!
  • #10 16403827
    simhak
    Help: 109
    Rate: 336
    Yes, but after the reset, the settings return to the factory, and these are based on the WPA key.
  • #11 16403896
    sylweksylwina
    Help: 1882
    Rate: 2355
    You will be asked to reset the button and ask Orange for a login and ppoe password if you do not have one. The login should be at the contract, the password was generated in the activation process.
    You can change ppoe password by logging in to the Orange website.
  • #12 16404244
    blackb
    I reset the button at the back, logged in to the router page and changed my password there
The discussion revolves around a user experiencing login issues with the Livebox 2.0 modem after a password change by a family member. The user is unable to access the modem's settings to retrieve the WiFi password. Various solutions are proposed, including resetting the modem to factory settings by pressing the reset button, which would restore the default admin password based on the WPA key. Users also mention that the default admin password may now be the first eight characters of the WPA key. After several attempts and suggestions, the user successfully resets the modem and logs into the router page to change the password.
