Sagemcom Funbox - how to change the name of the WIFI network.
tino2003 9135 14
How can I change the Wi‑Fi network name on an Orange Sagemcom Funbox when the router rejects the new SSID?
Change the SSID to a simple name without spaces, special characters, or Polish letters; the thread says some Funbox units reject names with characters like quotes, underscores, spaces, semicolons, and diacritics, and replacing the space with an underscore fixed it [#16569864][#16569894][#16570049] If the option is still not accepted after that, it may be blocked by the operator or be a firmware bug that should be reported to Orange [#16569995]
  • #1 16569796
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    From today I have such a box from Orange and everything works fine, but I can't change the name of the wifi network, the password changes without a problem and after entering the new wifi name, despite approval, nothing changes.
    Someone has encountered a similar problem, the firmware box is the latest, I tried on 3 different browsers.
    Andrzej Ch.
    Help: 223
    Rate: 394
    Some devices will not accept special characters such as ""; "_" etc.
    Try without special characters using at most "-" without spaces, semicolons, etc.
    DiZMar
    Help: 2892
    Rate: 6652
    And do not use "Polish" letters, i.e. those with "petioles" ą, ć, ę ...
  • #4 16569908
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    I don't have special characters or Polish letters in the name, no matter what I type in, it's not accepted.
  • #5 16569916
    Andrzej Ch.
    Help: 223
    Rate: 394
    Try changing the SSID from a computer connected via LAN instead of wifi. Maybe here is the problem.
  • #6 16569930
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    I am connected via LAN all the time. Even when entering from the phone is the same, after confirming the info "SSID is incorrect"
  • Free Orange technician setup assistance available
    #7 16569932
    DiZMar
    Help: 2892
    Rate: 6652
    On the website: http://www.orange.pl/kid,4000377334,id,4003345984,title,Platna-asysta-techniczna,article.html
    There is info:
    Technical Assistance
    If you were unable to solve the technical problem yourself and need help launching Neostrada or landline service packages (FunPack HD, Neostrada with TV, Neostrada with Unlimited Calls), you can order assistance from a service technician in your home.
    Basic installation assistance for the Internet, TV and telephone is now free of charge and includes:
    modem and decoder installation
    Internet access configuration on a maximum of 3 Customer devices (computer, tablet, phone), provided that they have licensed software and after the Customer's written consent
    registration and launch of Internet access and TV services
    configuration of the telephone purchased in the package with Neostrada (HD telephone, Neofon or Internet Telephony).
    Installation assistance can be ordered by calling the 510 100 100 hotline or in the Orange salon.
    Maybe take advantage of this.
  • Technicians won’t rename the Wi‑Fi network
    #8 16569940
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Technicians who today brought a new contract and equipment after a telephone contact said that such things like changing the name of the network do not do. They are for the correct configuration and proper operation and in this case everything works fine. :D
    If I think of nothing, it will stay that way, but I got used to it a little bit, that the network was called just like my company.
  • Editing the router config file to change SSID
    #9 16569954
    Andrzej Ch.
    Help: 223
    Rate: 394
    There is still such advice, but I do not know if it will work for you. I used to do that with an old Pirelli router. Save the current configuration file, if the created file is readable to you (that is, they are not "bushes" but a text file "), it is enough to find a section with the SSID name that you want to change and simply change it from the level of e.g. a notebook .
    But if the file saves the configuration file using "bushes" then this method is useless
  • #10 16569960
    LucekB
    Help: 143
    Rate: 137
    it should change without a problem, reset with current and if it doesn't help to the funbox factory.
    Or connect your router to the funbox and manage the entire network on it.
    What is Neostrada's option? What technology
  • Funbox SSID still needs separate router setup
    #11 16569993
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Andrzej Ch. wrote:
    just find a section with the SSID name there
    Good idea, the file is readable in the notebook, but is encrypted and visible as a string of letters and numbers:
    DiOTjTIWHJ8WWqcVyo3gdTCKAstRoR / Wi2DQuIK2mMYlLjBbofcnZ5iEjpMfVMKN
    8vB3XLD9JOgHMvsM6n3gLW7MIqrBd5p7CzOgHFFnV / JWzqduSNVDeL7Qyw12ArPO
    U8oZ4tkCZG0 UiJF5lmCrkqBLIdjJMM0LPHC + / + iech0jCzQlyLb o6yh7OhHyqwEU
    Neostrada 80 adsl.
    This is not a solution, because I have a second router connected in another room and I have another network name there, and here I need a different funbox.
    Edit the config file to change SSID name
    #12 16569995
    nutergsm
    Help: 1034
    Rate: 1665
    Operators block some functions so that users do not mix up anything. If this modem has this option, it is probably blocked.
    When it comes to changing the network name, it looks like a firmware bug and should be reported to the operator.
  • #13 16570001
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    In the first funboxes, in fact, such a problem occurred and it was enough to do the update, but I have the latest firmware and you can not do anything with it.
  • #14 16570002
    DiZMar
    Help: 2892
    Rate: 6652
    LucekB wrote:
    ... and if it does not help the funbox factory.
    contact factory support.
  • #15 16570049
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    I don't know how I missed it. Every time I put a space and this was a mistake and it was enough to give the underscore.
    Thank you.
The discussion revolves around a user experiencing difficulties changing the WiFi network name (SSID) on a Sagemcom Funbox provided by Orange. Despite successfully changing the password, attempts to modify the SSID result in an error message stating "SSID is incorrect." Various suggestions are provided, including avoiding special characters and Polish letters, using a LAN connection instead of WiFi, and checking for firmware issues. Some responses indicate that certain functions may be blocked by the operator, and it is suggested to contact technical support for further assistance. Ultimately, the user discovers that the issue was due to inadvertently including a space in the SSID, which was resolved by using an underscore instead.
