Troubleshooting PXE-E61 and PXE-M0F Boot Errors on an Intel Undi PXE 2.0 System
macieklis 74573 13
How can I fix PXE-E61 and PXE-M0F boot errors when the computer suddenly stops booting Windows and falls back to emergency boot?
These errors usually mean the PC is trying to boot from a device that is not bootable or is not being detected correctly, so you should first check the BIOS boot order and inspect the hard drive and cables [#1681771] A reset of the CMOS/BIOS settings may help, but it is mainly a way to restore default configuration, not a guaranteed fix [#1691809] The next step is to check the HDD data/power cable, the disk itself, and other boot devices; if needed, test the drive in another computer, run scandisk, or repair the MBR / reinstall Windows [#1684285] In this thread, resetting CMOS did not solve the problem, but replacing the cable from the disk and reconnecting the CD-ROM made the computer boot normally again [#1709497]
  • #1 1681133
    macieklis
    Rate: 8
    I have problems with my computer, I do not turn it on, I get such errors PXE-E61 and PXE-M0F (the motherboard is probably Intel Undi PXE 2.0 if there is such a disc) and below that the system is blocked and nothing can be done to do.
    Unless I turn it off and on again, I immediately start the emergency windows, what are these errors and how to fix it so that everything is fine? Thanks in advance for your help and best regards
  • #2 1681213
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    Hello ! ... you entered too little data about the hardware, system!
    Besides, what are the messages accompanying these errors?
    You did not change the settings in the bios? Have you changed your network card?
  • #3 1681771
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Probably the text looks like this:
    PXE-E61: Media test failure, check cables
    PXE-MOF: Exiting nVidia boot agent
    Disk Boot Failure, insert system disk and press enter
    Google is your friend:
    http://www.geekstogo.com/forum/PXE_E61_Media_test_failure_check_cable_-t37871.html
    http://www.nocrash.com/ncbbs/msgs/3247.shtml
    and in addition:
    http://www.intel.com/support/motherboards/desktop/sb/cs-002871.htm
    It follows that you are trying to boot from something that cannot boot from (sorry for the construction of the sentence). Check the boot order in the BIOS. Also check tapes and cables, disks, cd drives, and other devices you want to boot from.
  • #4 1684191
    macieklis
    Rate: 8
    ghost666 exactly such errors I mean, but I do not understand what this is about booting booting because I was not going to do anything like that, I do not even know what it is :) )) I don't even know what it could have done, because everything was fine and suddenly something like that.
    Toni_2003, the system is XP, what should you give about the hardware? I did not play anything in bios because I do not look there and I do not have a network card.
  • #5 1684285
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Okay, I thought so ;) . So in turn:
    * Reset the BIOS.
    * Check the hard disk and disk tape.
    Booting is the same as booting the system. The PXE-E61 error indicates that go media (i.e. the middle - in your case the HDD) does not pass the test test failure . The computer advises checking the cables. Take the drive out and attach it to another computer for a thorough Scandisk. Perhaps reinstalling the system would help, and perhaps fixing the MBR would work.
  • #6 1691591
    macieklis
    Rate: 8
    ghost666 and how is bios reset ??? As for the rest of things, I will check as much as possible, ah, and one more thing about fixing the MBR. Maybe you laugh at these questions, but I'm not in it that much, so I do not understand many things, thanks for your understanding and for your help, I GET GREETS
  • #7 1691752
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    As for the bios reset, you must refer to the manual. And instead of repairing mbr-a manually boot from the XP tile and do a repair install or something.
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    This is not really a BIOS reset, but a CMOS reset that stores the system configuration. The BIOS cannot be reset. Get the manual for your motherboard and look for information regarding a jumper called CLEAR CMOS or something similar. You didn't give your motherboard a tag, so I can't give you an exact tag.
    Next, check the cables. We will think about the rest depending on the results of these basic activities
  • #9 1692247
    macieklis
    Rate: 8
    ok, no problem, thanks for this info and I will let you know in a week, because only in a week I will have contact with my broken computer. Regards
  • #10 1709497
    macieklis
    Rate: 8
    Thanks all for help, I even found the jumper responsible for Bios, I did a reset, but it did not help, but I changed the tape from the disk, I disconnected the old one and I connected the CD-ROM and the computer turned on without problems :) Once again, thanks to everyone who gave good advice, it is definitely useful for the future. GREETINGS
  • #11 1709643
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Like I said - boot and cable problems :)
  • #12 1710308
    macieklis
    Rate: 8
    Exactly as you said ghost666, thanks a lot and everyone who advised me something :) Beer for you :) Only such virtual :) ) Regards
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Instead of a beer, this little button "helped" ;) I always click when I manage to finish a topic thanks to someone's help :)
  • #14 1710710
    macieklis
    Rate: 8
    No problem, it's already getting done :)
    Moderated By TONI_2003:
    I close everything explained about it.
The discussion revolves around troubleshooting PXE-E61 and PXE-M0F boot errors on a system likely using Intel Undi PXE 2.0. The user experiences boot failure, indicated by messages such as "Media test failure, check cables" and "Exiting nVidia boot agent." Responses suggest checking the BIOS settings, verifying the boot order, and inspecting hardware connections, particularly the hard disk and cables. Recommendations include resetting the BIOS (CMOS), checking for physical issues with the hard drive, and potentially repairing the Master Boot Record (MBR) using Windows XP installation media. Ultimately, the user resolved the issue by changing the disk cable and connecting a CD-ROM, allowing the computer to boot successfully.
