vw passat b6 2.0 tdi bmp Engine Shaking and Bouncing at Start-Up: Possible Causes?
mar78 14661 9
What can cause a VW Passat B6 2.0 TDI BMP engine to shake and bounce during startup even though it runs smoothly afterward?
The most likely cause is a failing dual-mass flywheel, especially when the engine starts and then runs smoothly with no smoke or driveability problems afterward [#16410328][#16436172] One practical check is to lift the car, have someone start and stop the engine, and listen at the clutch housing; any rattling or abnormal noise points to the dual-mass flywheel and means it should be replaced [#16410328] If you ignore it, you can damage the starter and gearbox [#16410328] Recheck the pump setting and valve timing as well, since one reply suspected an early injection/timing issue [#16408281] Also verify unit injector corrections: they should be similar, and a larger deviation on one injector can cause starting problems [#16420855]
  • #1 16408198
    mar78
    Hello, I have a problem with the passat b6 2.0 tdi bmp engine 140 km DSG mileage 225000 rather reliable, the engine shakes when starting, sometimes it bounces and goes out after adding a second battery, the situation improves but sometimes I bounce and there is no rule 10 times it will light up well and then a few times it will bounce. Timing after replacement and synchronization, the pushers and shaft were also replaced, unit injector gaskets replaced, the starter checked (the engine, when it starts, runs nice evenly, does not smoke cold or warm, pulls well. give unit injectors to check, but according to the computer they are normal, although one has a greater correction. I will be grateful for any suggestions?
  • #2 16408281
    manta 5
    Rate: 17
    Recheck pump setting and valve timing Looks like an early pin.
  • #3 16408363
    mar78
    [quote = "manta 5"] Recheck pump setting and valve timing. Looks like an early pin. [/ quote
    You mean unit injectors? I set them to -180 degrees, I think I should increase this value to 220 degrees.
  • #4 16408459
    manta
    Help: 463
    Rate: 1533
    Two to check.
  • #5 16408756
    mar78
    checked but 100% certain I do not lack any sounds when the engine is running and while driving. I already lack ideas, that's why I wrote here.
  • #6 16410328
    manta
    Help: 463
    Rate: 1533
    Checked ... how? It's hard to verify it on the table, and it is impossible to do on the car. The only thing you can do is lift the car on a lift, the other person starts and stops the engine, and you listen to the clutch housing. Any rattling noises, etc, gives two masses. So for replacement. By ignoring, you destroy the starter and crates.
  • #7 16410729
    mar78
    Everything is correct, it's hard to verify, but I pay 1500 PLN and it will turn out that no improvement, but I'm thinking about buying a new one, but I don't know, I'm standing astride. the ring as for extinguishing, no disturbing noises, Today I improved the setting of the push-ups at -225%, but in my opinion it was even worse, I set it as they were at -180%. I will add that there are no problems while driving,
    Added after 1 [hours] 23 [minutes]:
    I found a video on youtube, my car behaves identically, here they put on two masses, so I think there is an expense coming up, experts please take a look:
    link https://www.youtube.com/watch?v=Uf9J0PZirFw.
  • #8 16420565
    mar78
    No one has had such a case? The car has not been dismantled yet.
  • Inspect the unit injector with the largest correction value
    #9 16420855
  • #10 16436172
    mar78
    however, the dual mass was resolved !!
The discussion revolves around a VW Passat B6 2.0 TDI BMP engine exhibiting shaking and bouncing during start-up, particularly after the addition of a second battery. The engine runs smoothly once started, with no smoke or performance issues noted. Various components have been checked or replaced, including timing, pushers, shaft, and unit injector gaskets. Suggestions include rechecking the pump setting and valve timing, as well as investigating the dual mass flywheel, which may be causing the irregular start-up behavior. A significant correction in one of the unit injectors was also mentioned as a potential issue. The user is considering further diagnostics or replacement of the dual mass flywheel based on similar cases found online.
