Bosch WAE20160EN / 11 FD Maxx 6: Unresponsive Control Panel and Flashing Spin LEDs
AoT_Hunter_PL 15675 5
  • #1 16820126
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Hello, I have a question for old equipment, what is wrong or what the next procedure looks like to check the cause of the problem.
    Previously, the laundry was loaded from what the mother-in-law said the washing machine did not finish it, it was not spun or something fell on the way, at first I thought that maybe it does not connect something at the door but rather it falls off. What I noticed when trying to adjust the next wash.
    After turning the programmer to a given program, the device (Start) cannot be turned on (or the device does not turn on by itself). In short, turning the programmer does nothing.
    In addition, the LEDs in the panel flash vertically: Spin
    [1000, 900, 800, 600, spin spin]
    All except for flashing (900 and 600 off)
    Flashing at hmm level with about 500 ms may be slower.
    The START button LED is off.
    Left panel LEDs (not lit) - I don't know if it should be like that.
    photo borrowed
    I would like to add that the washing machine used to have a fallen fluid and powder collection mechanism (this tray, etc.), so only capsules inside the drum were used until now.
    But despite this she walked like that.
    I am asking for advice what to check, or any error codes, what I can check in electronics. I'm not getting started yet.
    Best regards and thank you.
    Added after 29 [minutes]:
    Hello, I will answer myself:
    https://www.elektroda.pl/rtvforum/topic2284785.html
    In this topic, I used the method of erasing memory.
    So the dial for "6", finger on the spin speed change button, then the dial for "7"
    The washing machine has reset, the program change works, but after setting it to spin, you need to wait a few seconds for something to happen.
    The engine does not spin (no spin), but the rumbling water pump under the drum.
    I don't know if this should be the case, it should be spinning alone.
    Well, but something must have caused this error, I read from another topic Similar to mine:
    https://www.elektroda.pl/rtvforum/topic2442664.html
    that this could be a problem:
    - with engine
    - programmer
    - my thought washing machine has breakdowns sometimes somewhere behind the smyra (no grounding, maybe I will do a zeroing and it will help for electronics)
    I replaced the brushes in the engine but still nothing (they were already out).
    Added after 14 [minutes]:
    Hello and I have a question, you can ask for some service manual of this washing machine or description of fault codes and how to read them.
  • #2 16822210
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Hello, I need a tacho generator for this washing machine engine.
    What models can I fit (when I search)
    I realized that this part does not appear in this model as a typical replacement, i.e. it remains to be picked.
    If someone please ask for something.
    I still have a question whether I can ask for parameters (e.g. catalog) of a good winding
    resistance, inductance?
  • #3 16823270
    wiesiekmisiek
    Help: 259
    Rate: 524
    And with maxx5 does not fit? Recently, I saw entire engines at PLN 50 on OLX. Or maybe it was just enough to reset again after replacing the brushes?
  • #4 16823910
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Maybe it would fit the engines is mass at a good price, only time is chasing me because if I don't do it tomorrow, my mother-in-law is buying a second one. And what to do here when you have the second changes, here to do something to do something and immediately to work and there is no time even to follow the parts, and that they were still in place or on scrap ... I could use the parameters of this coil.
  • #5 16825223
    wiesiekmisiek
    Help: 259
    Rate: 524
    Let my mother-in-law buy a second new one and my friend calmly fix it and sell it in the absence of the mother-in-law.
  • #6 16826319
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Already fixed. A visit to scrap fart helped and there was a Bosch engine for parts, I changed the tachometer, there was a bit of tug, brushes were also useful. Everything is fine (1200 PLN saved at a cost of 10 PLN + fuel).
    In the future, I will have to change the pump and the powder insert.
    Greetings and recommend visiting scrap metal people dump various miracles.
    The problem is that my wife and I were supposed to throw in half because we live together for now;] But the matter is already done and we torture the equipment further.
