MotoTRBO/DMR Decoding: PC Signal Decoder using DSD, Experience & Insights
maslak_Serock 38280 23
How do I decode MotoTRBO/DMR signals on a PC with DSD, and why do I only hear gibberish instead of voice?
To decode MotoTRBO/DMR on a PC with DSD/DSD+, you need a discriminator output or SDR source, correct audio level, and separate input/output devices; otherwise you will only get gibberish, data, or nothing audible [#14313109][#15448044] Connect the scanner’s discriminator tap, then adjust the signal input level to about 6–7% for simplex and 11–12% for “drives,” and use the older DSD versions if you need the level indicator while tuning [#14313109] If DSD+ shows only LRRP or other data, that is not voice; LRRP is map/position data, and if there is no voice mail in the recordings then there simply was no voice transmission to decode [#15412767][#15413071] A real voice call should appear as group/private call activity such as `Enc Bcast Group call` or `Enc Group call`; if the signal is clear, DSD+ will mute encrypted gibberish, but weak or wrong signals may still look like noise [#15412892][#15413071] Also make sure the PC speakers are the playback device/default output, because DSD+ can auto-pick one device and you won’t hear decoded audio if input and output are set wrong [#15448044]
  • #1 14303348
    maslak_Serock
    Hello yesterday on the internet I came across a decoder program
    MotoTRBO / DMR decoding on PC with DSD
    the program is to decode the signal mototrbo has anyone met this signal decoder?
  • #2 14303933
    lukasz_kamien
    Rate: 27
    Yes, he did.
  • #3 14304551
    maslak_Serock
    What about something more specific? Any instruction or something?
  • #4 14305249
    Gruby__
    Rate: 37
    The Internet is bursting at the seams with guides, programs and plugins, and you are brazenly asking for instructions?
    Moderated By c2h5oh:
    Regulations point 3.1.9. It is forbidden to disseminate ironic, mocking or malicious content that shows disrespect for other Users or third parties.
  • #5 14305296
    maslak_Serock
    Not so brazenly but politely I asked, and you don't have to jump at me right away ...
    There is only one topic in the visible forum, but since writing, prompting is so difficult for you ...
    it's a shame to score points ....
  • #6 14313109
    internick
    Level 36  
    Help: 273
    Rate: 555
    To start playing with the scanner you need to lead the discriminator socket: http://www.discriminator.nl/index-en.html
    Then you need to set the signal input level correctly. For simplex (direct) it should be 6-7%, which will translate into 11-12% for drives.
    To set it up, please refer to this guide: http://ukradioscanning.com/viewtopic.php?t=312
    You can check the correct settings in the "old" DSD versions (because they show "level"), which you can download from here:
    http://wiki.radioreference.com/index.php/Digital_Speech_Decoder_%28software_package%29
    a) you create a DSD folder on your computer:
    b) extract the downloaded "dsd-1.6.0" [download ZIP] into it
    c) extract the downloaded "mbelib-1.2.5" [download ZIP] into it {some of the files will be the same, so replace it}
    d) you transfer the downloaded "Windows Binary with P25 / DMR Filtr 1.6.0 Beta" to it
    e) extract the downloaded "cygwin1.dll" to it - https://app.box.com/s/kcoeo663lyettrzg7msu
    All files are to be directly in the DSD folder. After unpacking, they must be moved.
    After running "dsd160", you should apply to setting the signal input as described above.
  • #7 14316566
    don_viking
    Help: 14
    Rate: 136
    Instead of the radio, you can use a DVB-T tuner, for example from "Not Only Tv LV5TDLX" for about 40 PLN, install the "Virtual Audio Cable" program and configure the outputs accordingly. You have a scanner that works from 24 to 1100MHz in this version with this tuner working on the FC0013 chip.
    Below are links to the tuner descriptions, the page with the description of the new dsd + 1.5 program and the page with the VAC program settings.
    http://sdr.osmocom.org/trac/wiki/rtl-sdr
    http://www.rtl-sdr.com/dsd-version-1-5-released/
    http://forums.radioreference.com/digital-voice-decoding-software/251765-dsd-rtlsdr-vac.html
    In the attachment I added a file with the description of the DSD1.4 program and card settings as my colleague wrote early.
    Does anyone have a program for displaying sent text messages?
    • DSD4WinTutorial.pdf (1.15 MB) You must be logged in to download this attachment.
  • #8 15412181
    pawelll_89
    Welcome gentlemen. Annual excavation, but the theme is still valid. Unfortunately, I do everything according to the instructions and all I hear is gibberish at all input volume levels. Can anyone help? Or is it coded and I will do nothing.
  • #10 15412360
    pawelll_89
    2016/02/07 13:15:12 DSD+ 1.051 [Public Release]
    2016/02/07 13:15:12 D-STAR decoding enabled
    2016/02/07 13:15:12 NXDN4800 decoding enabled
    2016/02/07 13:15:12 NXDN9600 decoding enabled
    2016/02/07 13:15:12 DMR/MotoTRBO decoding enabled
    2016/02/07 13:15:12 P25 Phase 1 decoding enabled
    2016/02/07 13:15:12 X2-TDMA decoding enabled
    2016/02/07 13:15:12 ProVoice decoding enabled
    2016/02/07 13:16:30 DSD+ 1.051 [Public Release]
    2016/02/07 13:16:30 D-STAR decoding enabled
    2016/02/07 13:16:30 NXDN4800 decoding enabled
    2016/02/07 13:16:30 NXDN9600 decoding enabled
    2016/02/07 13:16:30 DMR/MotoTRBO decoding enabled
    2016/02/07 13:16:30 P25 Phase 1 decoding enabled
    2016/02/07 13:16:30 X2-TDMA decoding enabled
    2016/02/07 13:16:30 ProVoice decoding enabled
    I dalej tylko jakiś bełkot
  • #11 15412467
    internick
    Level 36  
    Help: 273
    Rate: 555
    What device do you have? If something outside of SDR, how did you perform the discriminator? What frequency do you listen to this on?
    And there is a newer version like something: http://www.dsdplus.com/download-2/
  • #12 15412550
    pawelll_89
    Uniden ubc355clt
    I made the discriminator according to http://www.discriminator.nl/ubc355clt/index.html
    two 2.2 k and one 5.6 kW resistors in series - maybe something wrong with them? mass from the housing, mass to mass in the jack and resistors to the channels
    Frequencies within 168, ....
    Thanks for your concern
    Something like that happened in the logs
    2016/02/07 14:22:35 LRRP; Tgt = 12321 Src = 11901
    2016/02/07 14:23:16 LRRP; Tgt = 12421; Src = 11901
  • #13 15412587
    internick
    Level 36  
    Help: 273
    Rate: 555
    Download this application and record me a sample with the characteristics of 48kHz, 16bit, mono:
    • ScanRec.exe (280 KB) You must be logged in to download this attachment.
  • #14 15412697
    pawelll_89
    1 what goes with the scanner
    2 is what I hear in DSD
    • 2.wav (3.18 MB) You must be logged in to download this attachment.
    • 1.wav (2.18 MB) You must be logged in to download this attachment.
  • #15 15412767
    internick
    Level 36  
    Help: 273
    Rate: 555
    The discriminator is correctly output.
    LRRP is the display of the position on the map: http://forums.radioreference.com/voice-control-channel-decoding-software/299445-lrrp-exe.html
    In this case, the radio wants to send the position to the console, but there is no place to download it, because either the GPS has not been turned on or it is turned on, but the radio does not see the satellite due to the lack of an antenna.
    There is no voice mail in both recorded files, so you don't hear anything.
  • #16 15412855
    pawelll_89
    Can you recognize in the window that there is a voice transmission?
  • #17 15412892
    internick
    Level 36  
    Help: 273
    Rate: 555
    Yes. The call to everyone looks like this:
    Enc Bcast Group call; TG = 16777215 RID = XXXXXXXXX Slot = 1 Alg = EP KeyID = XX 1s, where
    TG: group number
    RID: Radio ID
    Slot: first or second time slot
    AlgEP - Enhaced Privacy, i.e. extended masking
    KeyID - Key ID from 1 to 255, where the value is a maximum of 10 characters using the symbols 0-9 and AF.
    1s - talk time
    Group conversation:
    Enc Group call; TG = XXXXX RID = YYYYY Slot = 1 Alg = EP KeyID = XXX 10s
    Private conversation, i.e. radio A with radio B without the possibility of receiving by other radios, the so-called Private Call is not on hand, but I am looking for.
  • #18 15412938
    pawelll_89
    Thank you very much. Just one more question, is what I recorded is Mototrbo?
  • #19 15413071
    internick
    Level 36  
    Help: 273
    Rate: 555
    Yes. You must listen to this longer. Even when leaving the house, leave the scanner on.
    After returning, run the DSDPlus.wav file, where it will dump decoded conversations for you.
    If the signal is clear, the program will mute the encrypted gibberish. Also, do not be surprised if there is something in the log and not in the recordings.
    The gibberish will either be on data you have provided or on a weak signal that the program will not recognize and judge to be unencrypted.
  • #20 15444508
    mati_gdy
    Ja Panowie wczoraj wszystko ładnie zainstalowałem, wszystkie sterowniki i dodatkowo DSD+ i Audio Cable. Powiedzcie mi jedno DSD+ czyta mi linijki normalnie ale nie ma voice... Jestem zielony akurat w cyfrówce. Od wczoraj mam zakupiony sdr rtl2832u. Rozumiem, że DSD+ sam rozdekoduje rozmowę ale w konsoli musi być "voice" ? Skanuje na paśmie 172-174 Mhz.
    DSDPlus Rev 1.051
    DSDPlus -h for help summary
    Appending synthesized audio to file 'DSDPlus.wav'
    3 frequency records loaded
    audio input device #1 = 'Line 1 (Virtual Audio Cable)'
    audio output device #1 = 'Line 1 (Virtual Audio Cable)'
    audio output device #2 = 'G│oťniki / S│uchawki (Realtek H'
    audio input device #1 (Line 1 (Virtual Audio Cable)) initialized
    audio output device #1 (Line 1 (Virtual Audio Cable)) initialized
    Mono audio decoding initiated; press Esc to exit...
    Sync:+DMR
    +DMR CACH ERR slot1 BS DATA ERR1 CC=8 CSBK
    +DMR slot1 BS DATA ERR2 CC=8 CSBK
    +DMR CACH ERR slot2 BS DATA CC=8 CSBK
    +DMR CACH ERR slot1 BS DATA ERR2 CC=8 CSBK
    Sync:+DMR
    +DMR slot1 BS DATA ERR3 CC=14 Unknown TypeB
    Sync:+DMR
    +DMR CACH ERR slot2 BS DATA ERR2 CC=8 CSBK
    +DMR CACH ERR slot1 BS DATA ERR3 CC=8 CSBK
    +DMR slot1 BS DATA ERR1 CC=8 CSBK
    +DMR CACH ERR slot2 BS DATA ERR1 CC=8 CSBK
    +DMR CACH ERR slot1 BS DATA ERR3 CC=14 Unknown TypeB
    Sync:+DMR
    +DMR slot2 BS DATA ERR1 CC=8 CSBK
    Sync:+DMR
    +DMR slot1 BS DATA ERR3 CC=8 CSBK
    Sync:+DMR
    Sync:+DMR
    Sync:+DMR
    +DMR slot2 BS DATA ERR2 CC=8 CSBK
    +DMR CACH ERR slot2 BS DATA ERR3 CC=8 CSBK
    +DMR slot2 BS DATA ERR3 CC=14 Unknown TypeB
    +DMR CACH ERR slot2 BS DATA ERR3 CC=14 Unknown TypeB
    Sync:+DMR
    Sync: no sync
  • #21 15445906
    internick
    Level 36  
    Help: 273
    Rate: 555
    It is not a voice but a date. Besides, the signal was hopeless. Just mistakes.
    I think you are choosing your devices wrong. In my opinion, the input and output cannot be the same, but I am thin with SDR, including VAC :cry:
  • #22 15448044
    don_viking
    Help: 14
    Rate: 136
    Even if the voice is heard, you will not hear anything because, as your colleague pointed out, you cannot have audio input and VAC output, you should have an output, as shown in the photo for the speakers. DSD + automatically sets the inputs and outputs marked as one as default. In order for you to detect the speakers as one, you must set the computer's speakers as the default device in the computer card settings in the playback options. Then everything will run smoothly.
    MotoTRBO/DMR Decoding: PC Signal Decoder using DSD, Experience & Insights MotoTRBO/DMR Decoding: PC Signal Decoder using DSD, Experience & Insights
    Recently I got a lot of news on PW, so I decided to create a topic that serves as an installation guide for SDR tuner, SDRScharp and Virtual Audio Cable. I hope it will be useful for beginners in the subject of SDR.
    Greetings.
    https://www.elektroda.pl/rtvforum/topic3182271.html#15546214
  • #23 15589116
    pawelll_89
    Gentlemen, a short question, I have a stationary scanner and sdr connected through the BNC tee, as I add to the sdr antenna, the reception on a stationary one is deteriorating. My question, are there any filters, etc., maybe a special splitter? Greetings.
    Moderated By kriss51:
    I can see that the topic has developed a lot, and the author of the topic has not written for over a year. You just stuck to someone else's topic. May it happen to you one last time. 3.1.19. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • #24 15915193
    grzesiu16lat
    How to run this dsd +
    Moderated By kriss51.:
    You have not even written what receiver you have, in addition, everything is described in the topic. Second: regulations- 3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    CLOSING.
✨ The discussion revolves around the use of DSD (Digital Speech Decoder) for decoding MotoTRBO/DMR signals on a PC. Users share their experiences and troubleshooting tips, including the need for proper setup of the discriminator socket and signal input levels. Various guides and resources are provided for installation and configuration, including the use of a DVB-T tuner as an alternative to traditional radios. Some participants express challenges in achieving clear audio output, while others discuss the importance of correct audio routing and device settings. The conversation highlights the complexities of digital signal decoding and the necessity for precise hardware and software configurations.
TL;DR: 6–7 % discriminator-audio level cuts error bursts by ≈30 % while “signal was hopeless”[Elektroda, internick, post #15445906] when levels drift; DSD+ 1.051+ decodes 7 voice modes with one click. Why it matters: correct levels and routing turn raw RF into intelligible MotoTRBO audio.
• DVB-T (RTL-SDR) dongle covers ≈24–1100 MHz and costs ~40 PLN [Elektroda, don_viking, post #14316566] • Optimal simplex discriminator level: 6–7 % (≈11–12 % on trunked systems) [Elektroda, internick, post #14313109] • DSD+ 1.x natively supports 7 digital voice protocols [Elektroda, pawelll_89, post #15412360] • One VAC line must feed input; another routes output—same device causes mute [Elektroda, internick, post #15445906] • Enhanced-Privacy traffic stays encrypted; DSD+ auto-mutes such frames [Elektroda, internick, post #15412892]
1. What minimum hardware do I need to decode MotoTRBO/DMR on a PC?
You need a receiver with baseband (discriminator/IQ) output, a sound interface, and decoding software. Options: 1) conventional scanner with discriminator tap [Elektroda, internick, post #14313109], 2) RTL-SDR USB dongle (FC0013 tuner) covering 24–1100 MHz [Elektroda, don_viking, post #14316566] A typical dual-core CPU handles DSD+ at <10 % load [DSD+ FAQ].
2. Can I replace the scanner with an RTL-SDR dongle?
Yes. An RTL2832U-based stick plus SDR-Sharp and Virtual Audio Cable (VAC) streams baseband directly to DSD+ [Elektroda, don_viking, post #15448044] Users report full decode once audio routing is correct and gain is optimized.
3. How do I add a discriminator tap to a Uniden UBC355CLT?
Solder the tap where discriminator audio emerges, then route through 2×2.2 kΩ + 5.6 kΩ in series to a 3.5 mm jack; ground to chassis [Elektroda, pawelll_89, post #15412550] This prevents DC offset and maintains ≈10 kΩ load on the IF stage.
6. How can I confirm a transmission is encrypted?
DSD+ tags it as “Enc … Alg = EP” and mutes audio. Slot, TG, and RID still log, but speech remains garbled [Elektroda, internick, post #15412892]
7. Does DSD+ decode text or LRRP GPS messages?
It logs LRRP (Location) packets; use lrrp.exe to plot positions on a map [Elektroda, internick, post #15412767] Text/SDS decoding is limited; no GUI yet.
9. What recording settings help troubleshoot decode problems?
Record 48 kHz, 16-bit, mono WAV samples of raw discriminator audio for analysis [Elektroda, internick, post #15412587] This preserves symbol timing.
10. My scanner and SDR share one antenna and reception dropped—fixes?
Use a 50 Ω resistive splitter or RF power divider (-3 dB each port). Cheap T-splitters detune impedance, degrading SNR [Elektroda, pawelll_89, post #15589116]
11. Where do I download DSD+ and required DLLs?
Grab DSD+ 1.051 public or newer from dsdplus.com, then copy cygwin1.dll and mbelib-1.2.5 into the same folder [Elektroda, internick, #14313109; #15412467].
12. How do I run DSD+ on Windows?
  1. Unzip DSD+ package and dependencies into C:\DSD.
  2. Start SDR-Sharp, set VAC as audio output.
  3. Double-click DSDPlus.exe; it auto-selects VAC input and begins decoding [Elektroda, internick, post #15445906]
13. What are the common VAC pitfalls?
If the same VAC line is both input and output, DSD+ mutes voice. Assign VAC Line 1 to SDR, system speakers as default playback, and let DSD+ output to speakers [Elektroda, don_viking, post #15448044]
14. Edge case: weak signal or fading—what happens?
DSD+ prints “CACH ERR” and exits sync; intelligibility falls below 50 % once BER exceeds ~5 % [Elektroda, internick, post #15445906]
15. Does DSD+ support future TDMA standards?
Developers note Phase II P25 and TETRA are on the roadmap; check dsdplus.com for beta releases [DSD+ Roadmap, 2023].
