Portable Speaker Project: Understanding Noise Issues with 3W Amplifier & Bluetooth Module
mati_323 4875 10
  • #1 16409811
    mati_323
    Rate: 24
    Hi.
    I'm building a portable speaker.
    I test electronics - a 3W amplifier and a BT module.
    I used it once under an ampli and in a car, everything was fine.
    I want to use it for a portable speaker, but plugged in is terrible.
    They only occur when I play music - only when there is a signal.
    I changed the signal cables 3 times, I gave a 2.2k uF capacitor, with 1k uF it does not help either.
    Directly on the cable, this effect does not occur to the phone, so it is definitely the fault of the module.
    What can be done in this case? Maybe some shielding?
    or maybe the amplifier collects interference during bluetooth transmission?
    can enclose it in a piece of plaque and connect it to the minus of the system?
  • #2 16409995
    szymon122
    Help: 302
    Rate: 755
    Well cool and so what ?!
    You haven't provided any data at all, not even the module model!
    I reported the post, maybe next time people will start thinking ...
  • #4 16410399
    szymon122
    Help: 302
    Rate: 755
    How long is your cable connecting the amplifier to the receiver?
    What is the length between the speakers and the amplifier?
    What capacitors?
    What do you feed it with?
  • #5 16410754
    mati_323
    Rate: 24
    The power supply comes from the package - these are rechargeable batteries from an old laptop battery.
    There is 3 to 4.1V at the output.
    The amplifier works at 5V, it is connected via STEP UP converters.
    The cables are short - max 15 cm. The BT adapter is a little longer.
    Speakers with an amplifier - also not long, but not thick.
    The capacitors are simply desoldered from the old amplifier - they have +/- so electrolytic, if I'm not mistaken.
    What have I done so far and it has not worked? :
    - Bluetooth module power supply from the original battery - cable length 3 cm :)
    - kicking out the converter - I powered the amplifier from the computer's USB
    - as I mentioned earlier, I gave a capacitor before powering the adapter (I did not give a cramp by a boost)
    - I connected the BT adapter to the receiver on my package - noise almost inaudible, negligibly small - volume to max
    What else will I check:
    - I will give kondy before feeding the booster
    - will cover the amp with a piece of sheet metal - I will connect it to the ground of the power supply or signal, I don't know xd
    I would like to add that when I connect the phone directly to the jack - I omit the BT receiver, there are no noise.
    My signal cables are 100% good because I have a cable for applications and power amplifiers made with it
  • #6 16411281
    niebieski55
    Help: 34
    Rate: 81
    It is possible that the signal from the BT module is too big for this amplifier. Try to reduce the signal by adding a resistor, e.g. 100? (you have to choose it experimentally) on each of the outputs of the BT module parallel to the ground. If the sound level is too low, increase the resistor values.
  • #7 16411838
    szymon122
    Help: 302
    Rate: 755
    A better experiment will be to give a potentiometer, sound input to one extreme pin, ground to the other extreme and the output to the amplifier under the middle one.
  • #8 16412018
    mati_323
    Rate: 24
    Szymon but then I have to give a double potentiometer if I'm not mistaken :)
  • #9 16415997
    mati_323
    Rate: 24
    Oki. Neither the resistor nor the potentiometer unfortunately: /
    I tried on 220R, 470R and 10k R, a 10k logarithmic resistor - there is no noise as it is in the extreme left point - i.e. volume 0 xd
  • #10 16416071
    szymon122
    Help: 302
    Rate: 755
    Keep the cables to a minimum. What do you feed it with? Maybe the power source is disturbing. Show a picture of the assembled chip.
  • #11 16416600
    mati_323
    Rate: 24
    Tomorrow I will shorten the cables as soon as I can and take pictures.
    Regards and I wish you a Merry Christmas
✨ The discussion revolves around a user building a portable speaker using a 3W amplifier (PAM8403) and a Bluetooth module. The user experiences significant noise issues when playing music, which do not occur when the amplifier is connected directly to a phone. Various troubleshooting steps have been taken, including changing signal cables, adding capacitors, and testing different power sources. Suggestions from other users include reducing the signal from the Bluetooth module using resistors or a potentiometer, minimizing cable lengths, and considering potential interference from the power supply. The user plans to shorten cables and provide images of the setup for further assistance.
