Reversing Windings in Unmarked Electric Motor: U1-U2, V1-V2, W1-W2 Connections
daro31ie 26862 14
Can I swap all winding starts and ends on an unmarked three-phase motor when wiring a star/delta starter, and how do I identify U1/U2, V1/V2, and W1/W2 correctly?
Swapping winding starts and ends has no effect on the motor as long as you change all three windings consistently; the key is to swap all beginnings and endings, not just one pair [#16410447] If the motor has no markings, first identify each winding with an ohmmeter, then label the ends as U1/U2, V1/V2, and W1/W2 [#16410494] If the leads are color-coded or bundled in pairs, use that to determine which wires belong together; if not, you must determine all starts or all ends before wiring [#16410551] Once connected, a correctly wired motor should run normally without buzzing or excessive heating [#16410592]
  • #1 16410334
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Gentlemen, one thing bothers me.
    I got a motor after a few dozen kilo winding, which now has no markings on the U1, V1, W1 and U2, V2, W2 cables.
    Please correct me if I am wrong.
    U1 is the beginning of the winding, and U2 is its end.
    Similarly with V1-V2 and W1-W2.
    If I connect the wires from the KM1 contactor to U2-V2-W2 with star supply, and if the wires from the KM3 contactor to U1-V1-W1, and with the triangle
    I will connect the wires from the KM1 contactor to U2-V2-W2 and the wires from the KM3 contactor to U2-V2-W3 will it be any problem for the motor?
    The change consists in swapping the winding beginnings with the ends.
    We never really know if we are dealing with V1 or maybe V2 (if there are no markings)
    Thank you in advance for your response.
    stanislaw1954
    Help: 2013
    Rate: 4675
    Swapping winding starts and ends has no effect on motor operation. It's important to change absolutely all beginnings and endings.
    Radiowiec 2
    Help: 93
    Rate: 236
    I also once got such an engine. How the master turned out so wound up. If I were you, I would do this: he sketched the can on the engine and marked the ends. Then he took an ohmmeter and measured - he found individual windings and then each described U1 the beginning of the first, U-2 the end of the first. V-1 beginning of the second, V-2 end of the second, and W-1 beginning of the third and W-2 end of the second. Now if you take the star-delta switch, it turns out that the input of the three-phase cable is described R, S, T and the outputs for the motor U1 U2, V1 and V2 as well as W1 and W 2. How to connect it should play right away. There is only one "but" ... this engine has such power that it should have and probably has a "sofstart". Then connect as described on this module. Good luck! Best for Christmas! :D
    stanislaw1954
    Help: 2013
    Rate: 4675
    daro31ie wrote:
    which now has no markings on U1, V1, W1 and U2, V2, W2.
    I think that the beginnings and ends are lead out with different colors of wires, or possibly grouped in two triple bundles. If this is not the case then either all starts or all winding ends must be determined.
  • #5 16410563
    daro31ie
    Help: 366
    Rate: 650
    The engine is connected in star and delta.
    It seems to be working properly, but I still have some slight anxiety. This one has a 20A higher power consumption as a twin motor not rewound.
    stanislaw1954
    Help: 2013
    Rate: 4675
    If he has already worked - he works, then everything is fine. If it were wrongly connected, it would "buzz", warm up, etc.
    And what is the current consumed by this and the other motor?
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    Is something wrong, does it heat up at all phases? What comparable star / delta currents in both motors. Check the resistance of the windings, does it work quietly.
  • #8 16410703
    daro31ie
    Help: 366
    Rate: 650
    As it accelerates on the star is an old 45A, and this rewound 65A.
    nikusert wrote:
    Hello .
    When the star or triangle starts, the consumption is similar, but as it accelerates, the one scrolled has a higher consumption on the star and triangle by about 20-30A
  • #9 16410734
    nikusert
    Help: 699
    Rate: 1755
    Is there a nameplate on the old one?. Or both engines have the same number of revolutions. We know how much the old one took before rewinding, does not heat now ?.
  • #10 16410747
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    daro31ie wrote:
    but as it accelerates, the scrolled one has a higher consumption on the star and triangle by about 20-30A
    Unless already burned, give currents of individual phases.
    It will brighten the situation forever.
  • #11 16410814
    sq9fmc
    Help: 129
    Rate: 406
    Such a makeshift solution is to pass through a second motor connected in series with its windings with this tested motor without load. This method reduces the risk of burning the motor in a doubtful winding sequence. Proven in practice.
  • #12 16410952
    Radiowiec 2
    Help: 93
    Rate: 236
    If it is properly connected and such a difference is something "no hell". The only question is WHO he rewound it and with what wire. Because with all respect for professionals but "students" do not go to such serious work, and when he lets go he looks at his hands and pours on his paws. Turn off the engine and take measurements. Something must be wrong, e.g. resistance of individual coils, leakage relative to the housing, and other unforeseen matters. Measure it because you are running a motor and a half company. I hope not!
  • #13 16411977
    daro31ie
    Help: 366
    Rate: 650
    Everything ok. Problem solved.
  • #14 16412073
    vcc
    Help: 163
    Rate: 466
    There is nothing like giving a professional solution, unless it is a state secret which was the cause
  • #15 16412313
    Help: 1405
    Rate: 6430
    And what was the reason for writing posts and this current?
The discussion revolves around the challenges of connecting an unmarked electric motor with missing U1, V1, W1, U2, V2, and W2 markings after rewinding. Participants confirm that swapping the winding starts and ends does not affect motor operation, provided all connections are consistently altered. Suggestions include using an ohmmeter to identify winding ends and beginnings, and ensuring proper connections for star and delta configurations. Concerns about increased power consumption and potential overheating are addressed, with advice to measure winding resistance and current draw to ensure safe operation. Ultimately, the original poster reports that the issue has been resolved.
