How to Identify Main and Auxiliary Windings in a Single-Phase Motor
robson631 74729 9
How can I identify the main and auxiliary windings of a single-phase motor when the nameplate is missing?
The working/main winding has lower resistance, and the starting/auxiliary winding has higher resistance [#2491911][#2250970] Measure the winding resistance with an ohmmeter: the pair with the smaller resistance is the working winding, and the pair with the larger resistance is the auxiliary winding [#7293682][#7455025] One reply also notes that the capacitor is used to create a phase shift between the starting and running windings, not to change rotation direction [#2250970] If the motor has four terminals, one example identifies 1–2 as the working winding and 3–4 as the auxiliary winding, then connects power to the working winding and the capacitor in series with the auxiliary winding [#7293682] If the motor only has three wires, one reply says it will rotate in only one direction; reversing requires access to the starter terminals [#4033923]
  • #1 1965973
    robson631
    Rate: 9
    I have a problem with a single-phase motor, i.e. identifying which windings
    is the main one and which is the auxiliary one [the plate is disconnected], which of the windings
    has greater resistance
    Regards
  • #3 2250970
    aga-aga3
    Rate: 20
    Someone was really confusing here because the starting winding always has a GREATER resistance and the capacitor is not used to change the direction of rotation, but creates a phase shift between the starting and running windings, and to increase the starting torque and engine efficiency.
    Capacitorless motors can also rotate left or right.
  • #4 2491911
    warbipower
    Help: 20
    Rate: 58
    Of course, the working winding has lower resistance. For low-voltage enthusiasts, I recommend http://elektryk.ovh.org/silnik_ Jednofazowy.htm
    There is a diagram and it describes how to measure, connect and change the speed in such an engine.
    Regards
  • #5 4033923
    aga-aga3
    Rate: 20
    If 3 cables come out of the engine, it will always rotate in one direction, to change the speed you need to swap the starter terminals - 4 cables must come out
  • #6 7293245
    1.b
    Help: 5
    Rate: 70
    Hello! I have a small problem, namely, I have a centrifuge motor, it has four pins, I don`t know how to connect it, it also has a starting coil, I tried it, but after connecting it, the motor hums and does not rotate! please help. https://obrazki.elektroda.pl/55_1258885915.jpg
  • #7 7293682
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    Let`s determine that 1 and 2 are the working winding (lower resistance) and 3 and 4 are the auxiliary winding (higher resistance).
    You supply power to 1 and 2, and connect the auxiliary 3 to 1 and plug in a capacitor between 2 and 4. If the speeds do not suit you, swap terminals 3 and 4. Try to replace the capacitor (when there is a humming noise).
  • #8 7450665
    dj_west
    Help: 24
    Rate: 10
    Hello!
    And I have the following problem... I got a motor from some Chinese free-standing fan (the rotary type) and there are 4 wires coming out of it. A 1uF/400V capacitor is also visible. I measured and this is what it turned out to be:
    BLUE
    100 ohms
    WHITE
    100 ohms
    RED
    700 Ohms
    BLACK
    The rest of the transition resistance relationships between the wires are simply the sum of the individual resistances (e.g. blue-black is 100+100+700=900 Ohm).
    Anyone willing to help me figure out this engine? :)
    Hmm... I`m starting to suspect that BLACK is common and the rest is simply used to adjust the speed.
  • #9 7455025
    mateuszkonicz
    As far as I know, my friends, the 1-f motor is made of 2 windings:
    working and auxiliary.
    The auxiliary winding has a higher resistance and the working winding has a lower resistance,
    1-f engines had a so-called centrifugal switch that disconnected the auxiliary winding from the working winding. Currently, a capacitor is used instead of a switch. In case of changing the direction of engine rotation, this can be done when the ends of the working and starting windings are connected.
    Your friend is right, these resistances are the fan speeds, the so-called gears, I don`t know how your friend measured the resistances, I mean what colors does this resistance result from?
  • #10 20676160
    RobWan
    Rate: 13
    Not always. If the windings are equal, three wires on the terminal strip are enough.
    Robert
The discussion focuses on identifying the main and auxiliary windings in a single-phase motor, particularly when the motor's plate is disconnected. It is established that the auxiliary winding typically has a greater resistance than the main winding. Various users provide insights on measuring resistance to differentiate the windings, with suggestions to connect the windings and use a capacitor to create a phase shift for improved starting torque. Additionally, some users mention specific wiring configurations and troubleshooting tips for motors with multiple wires, including those from a centrifuge motor and a fan motor. The importance of understanding winding resistance and the role of capacitors in motor operation is emphasized.
