JVC KD-R711 Radio Panel Issues: Unresponsive Buttons and Delayed Commands
amivoytec 15246 2
  • #1 16411770
    amivoytec
    Well, when scrolling songs faster, the radio crashed for 10 seconds and from that moment the panel stopped working. The radio is 100% functional, I have a remote control attached and I can control the radio with it, everything is fine, but after a few months it is annoying to turn down the remote control when the phone rings, and you need to quickly turn off the sound. Only the "Eject" button for the CD works from the panel. The rest of the buttons are completely inactive, well sometimes when something is pressed it will react after 10 seconds and the reaction is strange, ie commands are "mixed", for example I will press the next track and it will switch the sound source from USB to FM, etc. - mixed. But 95% of button clicks don't work at all, no response. It is definitely the fault of the panel, because I borrowed a working panel and everything is fine. What could have fallen into it? I also found the problem in the "foreign" Internet, but no solution.
    How to bite it without a scheme?
    This was the case with the first radio, I bought the same second one and the same problem appeared again. Also something strange is happening with the JVC KD-R711 and I have two the same radios to be repaired with the same problem. The problem described was already on the forum before here but no answer, so I am writing a new topic.
    Photo tip:
    Greeting.
  • #2 16411852
    LWD11
    Help: 223
    Rate: 486
    A compact micro button in the panel locks the entire keyboard. Measure which one and replace it with a working one.
