Samsung galaxy s4 does not turn on, does not charge - 0 reactions
zenekxp 6537 2
  • Identifying the overheating motherboard component preventing startup
    #1 16413677
    zenekxp
    Rate: 14
    Hi DIY!
    I got a samsung galaxy s4 problem is that it won't turn on.
    At 99.99% the problem lies on the side of the motherboard ... It illuminated me 2-3 times after connecting to the computer but now it goes out as soon as I connect it, there is no reaction ... under the charger it also does not turn on or nothing.
    I undressed it and looked at the whole motherboard under a microscope but all the elements are okay - you can't see anything being broken, etc.
    I tried to turn it on even pressing the motherboard because maybe something did not connect, but also nothing (I recently had a similar case that did not connect one element on the board and did not want to read sim cards but never mind) ...
    Holding my finger in one place, I felt that one of the elements is getting too warm .. But I can not feel exactly which is heating because they are too small ...
    In the pictures I marked a suspicious place that heats up ...
    I am asking you for help as I can accurately diagnose which element or elements are to blame for not turning on the phone.
    greetings ;)
    nutergsm
    Help: 1034
    Rate: 1665
    Have you checked the battery voltage? Also check the charging voltage. In the attachment you have the service manual.
    • Samsung_i9505_sm.rar (21.08 MB) You must be logged in to download this attachment.
  • #3 16415341
    plustek
    Help: 176
    Rate: 200
    U800 probably fell, a common case in this model.
    • PVI_GT-I9505_NO_VPH_PWR.pdf (7.93 MB) You must be logged in to download this attachment.
    • (14-45) Galaxy S4(GT-I9505) No Power Problem check guide_rev2.0.pdf (291.86 KB) You must be logged in to download this attachment.
