iPhone 6s Plus Constant Reboots: Possible Battery Issue or App-related? Repair/Replace Advice
weronikaaxxxx 6963 2
  • #1 16968384
    weronikaaxxxx
    I have had my current phone - iPhone 6s Plus for over a week. Already on the first day it turned off by itself while using a certain application. It looks like a black screen, an apple, and a black screen again, and then it turns back on again and again and again. It's quite hard to turn it on. I've already done a hard reset and it's still shutting down. Most often it rains when using one specific application. iTunes sees the iPhone, everything is normal if not for the fact that the phone is restarting itself. I don't know if it's the battery's fault or something else. When I connect it to the charger, nothing happens, it still turns on and off. Is there anything else you can do with it, is it better to repair or replace it?
    Thank you in advance for your help. best regards :)
  • #2 16968449
    E8600
    Help: 529
    Rate: 2520
    More like a service, and it's good.
  • #3 16968726
    RafalB
    Help: 91
    Rate: 222
    At the beginning, it is necessary to check the battery and verify the current consumption of the boards. On your own, you can read information about the battery status (consumption or number of cycles) in the 3uTools or coconutbattery software.
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
